This is a discussion on 2010 Solar Panels to Charge HV Battery Pack within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; After I thought about it, why did'nt Toyota just go ahead and let the solar panels help charge the battery? ...
Old 11-04-2009, 10:16 PM   #1
That_Prius_Car
That_Prius_Car's Avatar
Default 2010 Solar Panels to Charge HV Battery Pack
After I thought about it, why did'nt Toyota just go ahead and let the solar panels help charge the battery? But what I really wanted to ask, is if there is any way to mod the panels to charge the HV battery instead of useing it for the fan.
Thanks.
That_Prius_Car is offline
Old 11-04-2009, 10:21 PM   #2
Paradox
Prius Enthusiast
Paradox's Avatar
Model: V
Package: Adv. Technology
Friends: 9
Default Re: 2010 Solar Panels to Charge HV Battery Pack
Toyota says that when they tried to have the panels charge the batteries the wiring acted like a big antenna and screwed with radio reception etc.
But beyond that, with the size of the panels being used and their power output, they really wouldn't make much of a difference.
Paradox is online now
The Following User Says Thank You to Paradox For This Useful Post:
That_Prius_Car (11-04-2009)
Old 11-04-2009, 10:25 PM   #3
RodJo
RodJo's Avatar
Model: V
Originally Posted by That_Prius_Car View Post
After I thought about it, why did'nt Toyota just go ahead and let the solar panels help charge the battery? But what I really wanted to ask, is if there is any way to mod the panels to charge the HV battery instead of useing it for the A/C.
Thanks.
I think this has been discussed before and the reasons explained. It's been awhile, but as I recall it has to do with the voltage output and electrical interference. Doing a search will find the right threads.
BTW, the solar panels are not used for the A/C. They just run the fan...
RodJo is offline
Old 11-08-2009, 11:30 PM   #4
rctech
Package: Navigation
I'm not sure I buy the electrical interference reasoning. If it's rectified and filtered DC, or even in shielded wiring, any interference should be avoidable (It's not like it should have any ac or HF component, or reverse EMF from motors or relays).
But given the specs of the panel (depending on where you read it: 40-80W), even a full bright sunny 80W output will give you only (W * 0.00134 = HP) 0.107 Horsepower.
Seems small, but the traction battery capacity is roughly only (201.6V * 6.5Ah) 1310Wh (437W for 3hr rate), but only charged to 80% = 1048Wh. Pretty amazing that it can handle pulling over 3000lbs for half a mile (Newton's 1st law helps, i guess).
Max MG output is like 60,000W (80HP).
Really give you some perspective on how hard the traction battery can be worked, for instantaneous 80HP assist.
Of course, we wont be getting anywhere near 80W or 60kW, except in rare "ideal" conditions. And there are always losses in conversions.
Float the 12V battery mabye, but hardly seems worthwhile to use the solar panel to charge the assistive Traction battery
rich
rctech is offline
Old 11-08-2009, 11:58 PM   #5
LakePrius
Model: II
rich
Yeah, makes you realize just how far we have to go until solar cells are an effective way to generate electricity.
LakePrius is offline
Old 11-09-2009, 12:25 AM   #6
fuzzy1
Model: II
I'm not sure I buy the electrical interference reasoning. If it's rectified and filtered DC, or even in shielded wiring, any interference should be avoidable ...
It is avoidable, but it can take a bit of time and resources to get it done right. At release time, it sounded like they ran into a problem, and ran out of time. Punt, try again next year.
fuzzy1 is offline
Old 11-09-2009, 08:54 AM   #7
wogue
Package: C
Hi there,
excuse my questions, I really don't know much about these calculations but:
aren't there little green car-symbols on the multifunktion-display when I regenerate through deceleration or going downhill?
And one car-icon stands for 50Wh. My experience with the prius06 tells me that i can go at least half a mile (800 meters) in EV-mode with three of these green-symbols.
When there are six hrs. sunlight, doesn't that mean the prius would be able to regenerate about 300Wh?
And that should make close to one mile in EV-mode!
So that's not nothing, and I actually hope Toyota soon finds a solution to connect the solar roof to the traction batt.
kr
wogue
wogue is offline
Old 11-09-2009, 09:30 AM   #8
a64pilot
I'm not disputing you, but how do you correlate the regen symbols to anything as far as how far one would propel the car?
a64pilot is offline
Old 11-09-2009, 11:19 AM   #9
ken1784
SuperMID designer
ken1784's Avatar
Package: G
Friends: 8
The 50 or 60W generation is the peak power at noon.
The average wattage will be 20W from 9AM to 3PM, then the total will be 120Wh.
Ken@Japan
ken1784 is offline
Old 11-10-2009, 04:24 AM   #10
rctech
Package: Navigation
Hi there,
kr
wogue
It's relatively easy to regen 6 little cars during a 15minute drive. But it takes ideal conditions to (solar) generate that much power in a 6 hour stretch.
You may have 6 hours of sunlight, but unfortunatly, it's a bit more complicated than that. Mostly because of your location (on earth), weather, and panel aiming. If you live in a hazy area, that is cloudy 50% of the time, and your solar-panel is not perpendicular to the sun's rays... the entire time... you can see how the inefficiencies build up.
Here is a link that gives a bit more ideas and details about solar panels and tips (used it for my son's science-fair project ;-).
Solar 101
(I'm not affiliated with them in any way).
rich
rctech is offline
2010, prius, solar, toyota
Lithium Ion Battery Pack for 2010 Prius - When? drspielman Gen III 2010 Prius Main Forum 2 06-27-2009 08:23 PM
Help w/ solar panels SSimon Environmental Discussion 21 07-16-2008 08:37 PM
Correction: Solar panels to only supply a portion of power for air conditioning on 2010 Prius Danny Prius and Hybrid News 32 07-13-2008 05:30 PM
Solar Panels material_claw Gen II Prius Modifications 18 07-09-2006 10:04 PM
Solar panel to trickle charge the 12V battery? michalopoulosgk Gen II Prius Main Forum 15 10-09-2005 08:42 PM
