Triangle of death, P3191. On again, off again
| Junior Member Join Date: Jan 2012 Location: Kauai
My Car: 2002 Prius Model: N/A Package: N/A Thanks: 0
Friends: 0 | Is it safe to drive my '02 with the triangle on the dash? I've tried to get rid of it, throttle body cleaned, MAF cleaned, battery seems good (13v, no load). What else can I do to try and get rid of it? BTW, '02 Prius, 183K mi. It runs good, cycles on and off normally (motor to battery, etc.). The code clears it self after sitting about a week w/ occasional starts, then I drive it for about 50-70 miles and the light comes back on...what gives? Any thoughts are appreciated. |
| Thanked by: | andyprius (02-04-2012) |
My Car: 2007 Prius Model: Package: #2 Thanks: 81
And how often have you changed the trans fluid please? Last edited by edthefox5; 01-28-2012 at 09:35 PM. | |
| Battery Curmudgeon Join Date: Mar 2010 Location: Santa Fe, NM
My Car: 2005 Prius Model: N/A Package: #4 Thanks: 235
Friends: 10 | A code will clear itself after 3 starts and offs, so long as an OBD trip is NOT completed. Did you use MAF cleaner or TB/carb cleaner on the MAF? It is interesting that this happens after 50 miles of driving. Is that 50 miles of driving on a single trip, or 50 miles worth of short trips? Does it happen while driving, or on a cold start? There is a long laundry list of possible causes, like throttle motor/sensor, crank+cam position sensors, coolant temp sensor or lack of coolant (do you have your grill blocked?), fuel pump, MAF sensor (bad, not just dirty), ECM.
__________________ 2005 Gen II Tideland Pearl Package #4 2004 Gen II Tideland Pearl Package #9 salvage rebuild project 2000 Red Honda Insight A/C 5 speed 2004 Toyota RAV4 L AWD 5 speed 2001 Toyota Sequoia SR5 4x4 2005 Toyota Sequoia Ltd/2006 SR5 4x4 restoration project |
Friends: 0 | I had the trans fluid done I think about 40K ago, probably need to do it again. As for the battery, I'll go get it checked tomorrow and let you know what they say. The 14v for the battery was when the car was parked ignition off. I may be confused by what no load means. Thanks for advice. |
Friends: 10 | Quote:
Another common emission-related failure is the HCAC valve. An OBD reader might not have the code for it (P1436). Also, have you ever replaced the PCV? | |
My Car: 2012 Prius Plug-in Model: Plug-in Base Package: Base Thanks: 653
Friends: 6 | Quote:
| death, p3191, triangle |
LinkBack to this Thread: http://priuschat.com/forums/generation-1-prius-discussion/102771-triangle-death-p3191-again-off-again.html | ||||
| Thread red triangle/exclamation point and icon on screen | PriusChat Forums | BoardReader | This thread | Refback | 05-17-2012 02:15 PM | |
| Thread Triangle of Death | Pelican Parts Technical BBS | BoardReader | This thread | Refback | 04-11-2012 10:33 AM | |
| Thread red triangle of death | Android Forums | BoardReader | This thread | Refback | 04-05-2012 07:24 AM | |
| Triangle of death and scangauge | wwu123 | Generation 1 Prius Discussion | 65 | 03-02-2012 07:02 PM |
| red triangle of death! | GasSaver1 | Gen II Prius Technical Discussion | 5 | 03-09-2011 12:01 PM |
| Intermittent Red Triangle of Death | scottso5 | Gen II Prius Care, Maintenance and Troubleshooting | 9 | 01-29-2011 06:28 PM |
| Red Triangle of Death | Yarok | Gen II Prius Main Forum | 21 | 11-30-2010 03:59 AM |
| 2002 Triangle of Death - Help please!!! | kirbinster | Gen II Prius Care, Maintenance and Troubleshooting | 10 | 11-17-2008 12:23 AM |
