Classic Prius Repairs
| View Poll Results: Classic Prius Owners only: Which failure has your car experienced? | |||
| Transaxle | | 8 | 7.08% |
| Inverter | | 9 | 7.96% |
| Traction battery | | 29 | 25.66% |
| Engine ECU | | 11 | 9.73% |
| Hybrid vehicle ECU | | 7 | 6.19% |
| Electric steering gear | | 24 | 21.24% |
| MFD | | 1 | 0.88% |
| Front Struts &/or Rear Shocks | | 13 | 11.50% |
| Other Failure | | 38 | 33.63% |
| No Failures | | 29 | 25.66% |
| Multiple Choice Poll. Voters: 113. You may not vote on this poll | |||
| | #41 |
| Junior Member Join Date: Jun 2011 Location: Syracuse, NY
My Car: 2002 Prius Model: I Package: N/A Thanks: 0
Friends: 0 | I have replaced front wheel bearings, rack & pinion (when the car had approx. 30,000 miles on it) and TIRES!!! I'm always buying tires - no matter how I inflate them! The best set of tires so far have been Nokian tires but now trying Hankook winter tires. Code 3191 has popped up several times (I've had the throttle body cleaned. New codes as of yesterday are P0420, P0440, P1636 - which I'm being told means I need a new catalytic converter at $1371.72!!!! I have 179051 miles on my 2002. All of a sudden I'm finding lots of rust (the car had been rust-proofed) and have found that several other 2002 Prius in the area have rust in the exact same place - over the windshield in 2 places. I love my Prius and it will be a sad day when I have to put her down! |
| | #42 |
| Die Hard DIYer/Hobbyist Join Date: Jul 2011 Location: Bowling Green, KY
My Car: 2001 Prius Model: N/A Package: Base Thanks: 214
Friends: 0 | I have an '01, originally purchased by an elderly man in Indiana. CarFax shows all scheduled maintenance was completed by the dealer as scheduled. No failures reported on the Car Fax. I have had the car since Apr of '08 (86,000 miles on the odo) and it has performed exceptionally well. It now reads 107,+++ on the odo and I have had no issues with it so far. Still on the original traction battery. I replaced the 12V but just as a precaution (it still read good). I replaced one rear wheel bearing (also as a precaution because I thought I heard it humming a little). I'm about to pass it on to my 16 yr old son. Hopefully it will perform the same for him but, if not, I (and he) has all of you fine folks to help me with whatever issues may arise. I would like to thank Patrick for starting and consistently reinvigorating this post. I have learned so much from Prius Chat. |
| | #43 |
| Senior Member Join Date: Dec 2009 Location: Longmont, CO.
My Car: 2006 Prius Model: N/A Package: N/A Thanks: 17
Friends: 3 | Me too! Absolutely Patrick gives the best advice, even more so than a dealer would.. Update: Sold the 03 but still have have the 06 prius. The 03 still ran good however, only thing the air conditioner was inop. seems to have blown a pipe inside the drivers side dash area. As mentioned before, the 03 was a great car but it was of course way out of warranty, soon needing a new HV Battery pack among other things, so I traded with the dealer (while it was still good) for nothing less than an 05 Mustang GT 4.6L V8 EFI! Talk about two extremes huh. The Mustang is only the weekend driver now at 20mpg, but sure is a blast to drive. Of course the 06 is still the main work/commute/shopping car at 52+/- mpg and only sees the gas station every two weeks! Two extremes? yup
__________________ 2006 Prius (MPG 49-57) 115FWHP 1997 Harley Sportster 883 (MPG 38-45) 55RWHP - Fast 1989 Harley Spinger Softail 93ci. (MPG 35-42) 75RWHP - Pretty Fast 2005 Mustang GT 4.6l V8 EFI (MPG 18-21) 300RWHP - Very Fast 1972 Chevelle SS-454 454ci. (MPG 10-18) 480RWHP - Neck Breaking Fast! Last edited by w2co; 03-04-2012 at 11:01 AM. |
| | #44 |
| Junior Member Join Date: Dec 2011 Location: Piscataway, nj
My Car: 2002 Prius Model: ----USA ONLY---- Package: ----USA---- Thanks: 0
Friends: 0 | from reading all these failures, it makes me wanna sell my 02 prius. are gen2 more reliable than gen1's overall? Last edited by Saquibs2004; 03-03-2012 at 11:41 PM. |
| | #45 |
Friends: 0 | Is there a way to monitor inverter coolant temp? I think the inverter failures might be caused by people not changing their inverter coolant every 30k miles and not monitoring the inverter coolant temp. Last edited by Saquibs2004; 03-04-2012 at 12:33 AM. |
| | #46 |
Friends: 3 | The HV packs are more reliable in Gen2, they don't leak electrolyte out of the pos. terminals. Also the running soc levels are higher in gen2 from my observations, the 03 always was 59 or less, very hard to get it to 60 soc and keep it there. The 06 gen2 it's easy to get over 60 soc and usually runs about 62.5, this around town. On the highway it can drop to 55 or less but always comes back up quickly from regen braking or even cruising at 65 and holding it in the mode where the ice is running the wheels but also charging, but this is a slower charge rate than braking. Example: I can get soc up to 62-65 going downhill and braking slightly in the gen2. I like to park it overnight at 61-62, it'll last being parked for days at that level and still retain a good level. The transaxles in Gen1 are prone to failure although mine never had any problems. I did change the trans oil at 30kmi., but that doesn't really guarantee protection from failure, only makes sure there's nothing going on and you can catch a potential problem waiting to happen. The way you drive it may also play a big factor. Saquibs: The only way I have measured inv. coolant temp as well as many other parameters was with AE scantool software and the enhanced Toyota interface. Techstream of course can as well but that is more$$. I'm sure something else can although haven't been keeping up with it. Maybe there's an Xgauge for scangaugeII by now for gen2/3 but not sure. There's a thread that has the current list of working Xgauge settings thanks to Vincent for gen1's xgauges. I'm sure there's a list for gen2.. |
| | #47 | |
| | #48 |
Friends: 3 | Well I don't think you can go wrong with scanguageII. I've had one in the 06 monitoring soc, btv, rpm, and running avgmpg. The avg mpg gauge always has a little lower avg than the mpg in the MFD. Toyota's gimmick to make it look better than it really is? Maybe.. |
| | #49 |
Friends: 3 | One time when I brought the gen2 in to the dealer for something, I think it was the inv. coolant pump campaign, I forgot to remove the scangaugeII, and they were giving me stares and "what the heck" looks. Oh well... |
| | #50 | |
| classic, prius, repairs |
LinkBack to this Thread: http://priuschat.com/forums/generation-1-prius-discussion/45766-classic-prius-repairs.html | ||||
| Generation 1 Prius Discussion on PriusChat Forums | BoardReader | This thread | Refback | 12-20-2011 07:50 PM | |
| Service/Repairs in Miami | jsloman247 | Gen II Prius Technical Discussion | 1 | 10-08-2007 12:42 PM |
| Dealer repairs? | plantz | Gen II Prius Care, Maintenance and Troubleshooting | 11 | 10-03-2006 07:21 PM |
| Repairs | RSB | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 11-29-2005 11:40 AM |
| Excessive Repairs | Marty Wexler | Gen II Prius Main Forum | 2 | 07-21-2005 12:32 AM |
| Repairs and Recalls | Kurt | Gen II Prius Main Forum | 5 | 04-15-2005 04:06 PM |
