| Generation 1 Prius Discussion This is a discussion on Restoring G1 Drive Batterys within the Generation 1 Prius Discussion forums, part of the Prius Main Forum category; Originally Posted by ChapmanF ... Looking through your picture sequence again, I saw the disappointing result with the heat-sealed stainless ... |
| | #11 | |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 5 | Quote:
Now I've been looking at the 'safety vent' and believe it to be 'too tight.' I would be more interested in a reworked safety vent and that provides a lot more material to work with. But this is tricky stuff. Bob Wilson Last edited by bwilson4web; 06-16-2008 at 08:42 PM. | |
| | #12 | |
| Senior Member Join Date: Mar 2008 Location: Indiana, USA
My Car: 2001 Prius Package: Base Nominated 6 Times in 1 Post TOTM Awards: 0 Friends: 1 | Quote:
An M3x0.35 tap (it seems only right to use metrics -Chap | |
| | #13 | |||
One thought is to fabricate a small cylinder with a center, threaded hole. One end of the cylinder would expand in a cone into a thin disk. These cylinders could be rapidly spun and inserted into a beveled hole and friction heating weld the disk to the battery top. When the disk reaches the top of the battery it would brake to a stop and the weld is complete. The advantage of this approach is a through weld and a threaded cylinder that the pressure would 'force closed.' As the pressure increased the cylinder would more tightly grip the threaded fastener. But this leaves the problem of leakage around the terminals. My thinking is I need pressure testing not only of the relief valve but also of the terminals at higher temperatures, 40-50C. The pressure relief valve set point needs to be less than the terminal leakage pressure so the KOH solution won't bubble out and eat the copper bus terminals. This is not a trivial problem. Bob Wilson ps. The temperature probe hole would be an ideal, threaded cylinder but it is located in the wrong location, a center cell. Last edited by bwilson4web; 06-17-2008 at 01:52 AM. | |||
| Restoring capacity of fuel tank(bladder) | AAWADKE | Prius Main Forum | 10 | 03-26-2007 04:18 PM |
| Drive them if you have them | 2Hybrids | Prius and Hybrid News | 34 | 04-03-2006 03:23 PM |
| Restoring OLD Posts | 200Volts | Prius Main Forum | 3 | 10-11-2005 12:54 PM |
| Restoring signal from JBL Amp: LC6, Cleansweep | tmorrowus | Audio and Electronics | 29 | 08-05-2005 07:42 PM |
| First Drive | Gurmail | Prius Main Forum | 4 | 07-21-2004 11:47 PM |
