Go Back   PriusChat > Toyota Prius Forums > Prius Main Forum > Generation 1 Prius Discussion
Generation 1 Prius Discussion This is a discussion on Here we go, first problem, no display! within the Generation 1 Prius Discussion forums, part of the Prius Main Forum category; Originally Posted by SparrowHawk60 It's not a dimmer switch problem. I'd bet the wife is no dimmer than you. And ...
display!, problem
Old 06-24-2008, 05:21 PM   #11
patsparks
Uneducated bird-brain Aussie
patsparks's Avatar
Friends: 13
Default Re: Here we go, first problem, no display!
I'd bet the wife is no dimmer than you. And there's no loose nut behind the wheel either!
I hope that was meant to be funny, because it gave me a laugh, thanks.
Good luck with a swift resolution. Never heard of this one before.
patsparks is offline
Old 06-25-2008, 11:05 AM   #12
SparrowHawk60
Happy to be green!
SparrowHawk60's Avatar
Send a message via AIM to SparrowHawk60
We've got an answer from Toyota, seems the "cluster" will have to be replaced! Doesn't give me any peace of mind that this car will not be problematic. We've had it since March and there is a bit less than 4000 miles on the car.
Dealership has been pretty good about it all, they've given us a loaner (a Corolla) to use will our Prius is in for repairs.
We've been told it will take about a week to have the problem fixed. The cluster will also have to be reprogrammed so the mileage will be our best guess.
I fly this plane for my country, when it stops flying it's not my fault, it's the countrys." CDR Fred "Bear" Vogt. The Last Skipper of VF-33's, F-4's.
SparrowHawk60 is offline
2004 Multifunction Display (MFD) problem/lockup = solved! joules Prius Main Forum 0 01-20-2008 07:49 PM
AUX2CAR display problem paulccullen Audio and Electronics 3 11-16-2006 12:09 AM
Oddest 'Problem' with Speedometer Display smarano Prius Main Forum 13 10-19-2006 02:31 AM
Climate System Problem (Thought to be MFD Problem) losaltosprius Care, Maintenance and Troubleshooting 2 03-17-2005 06:08 PM
Problem with energy display Ray Moore Prius Main Forum 5 04-16-2004 02:41 PM
