| Generation 1 Prius Discussion This is a discussion on 2003 prius not starting within the Generation 1 Prius Discussion forums, part of the Prius Main Forum category; Hi! My '03 Prius is sick...It will start normally, then the gas engine will cough and cut off, leaving only ... |
| 2003, troubleshooting |
| Junior Member Join Date: Jul 2008 Location: Durham, NC
My Car: 2003 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi! My '03 Prius is sick...It will start normally, then the gas engine will cough and cut off, leaving only the electric engine running. The triangle and the engine light are on. Something similar happened a few months ago (on earth day, ironically) and the next day it started fine, so i never got it checked out. This time it has been 24 hours and it still isn't working so i'm guessing it isn't going to fix its self this time. It has 94,000 miles and has never had any major problems and still has the original battery. The battery could possibly be low because I drove from central texas to north carolina a little over a month ago, it was parked for 2 weeks and have been driving it fairly infrequently since (2-3 times a week), however the battery doesn't seem to be low, all the lights and the radio are working. Could a battery issue cause the gas engine to fail? Also, this happened the next time i started it after getting gas, could it be caused by bad gas? It almost seems like a problem with the fuel injector but I thought that Prius' didn't have a traditional fuel injector. Any one have similar experiences or ideas? I would at least like to have a vague idea of what is going on before i take it to the dealer. |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 23 | I suggest that you take your car to the dealer so that the DTC (fault codes) can be retrieved. However, if the service writer tells you that your car needs a new engine ECU or a new fuel tank, consult with us again before you accept those very expensive repairs. If this work has not been recently done, I suggest that you consider having your engine tuned up: - replace the iridium spark plugs and engine air filter - clean the throttle body interior and throttle plate - change the engine oil and oil filter, make sure that 5W-30 viscosity is used A weak 12V auxiliary battery would not cause the gasoline engine to stop running. If bad gas was the issue, I would have expected the car to be affected soon after you left the gas station. The Prius engine has four fuel injectors of traditional design.
__________________ 2006 Highlander Hybrid 4WD-i 2004 Prius 2001 Prius (sold Feb. 2008, 75K miles) 2000 Ford Mustang GT conv. Last edited by Patrick Wong; 07-23-2008 at 05:49 PM. |
| Senior Member Join Date: Nov 2007
My Car: 2002 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I hate to prejudge your problem, but I've had a very similar problem with ours every once in a while. It seems if I leave our 02 Prius alone without starting it in the sunshine for a week or so...it tends to do the same thing. I've come to the conclusion that after the first time, that it was bad gas, or gas that had gone bad in the fuel rail/injector areas of the engine. I just disconnected the 12V battery to reset the computer, and after a few resets , it cleared the problem and we haven't had any trouble since. There is also a problem that happens when the engine has been overfilled with oil.
__________________ |
| | #6 | ||
My Car: 2002 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote: Good call!! Quote:
We try to buy the best regular unleaded possible, but it seems to shellac quickly in all of our vehicles at our altitude/temperature, and that problem is not specially inherent to just the Prius either. Some of our other vehicles "balk" with strong gas ever so often. We've tried to buy from different places, but can't seem to store gas for more than 30 days without problems, and even less if it's in a vehicle. | ||
| Need Help: iPod2Car with 2003 Prius | miPrius | Audio and Electronics | 4 | 08-04-2008 02:27 PM |
| prius II from 2003 | Flying White Dutchman | Care, Maintenance and Troubleshooting | 2 | 01-10-2008 09:45 AM |
| WTB 2003 Prius in SoCal | catfromtex | Private Sales | 3 | 10-04-2006 10:50 AM |
| Noise when starting 2003 Prius | Nobody Special | Care, Maintenance and Troubleshooting | 3 | 11-23-2005 04:00 PM |
| 2003 Prius/pimped out car | djkidmike | Prius Main Forum | 15 | 07-29-2005 12:21 PM |
