| This is a discussion on -15F outdoor air temps = luke warm cabin heater air temps within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; I posted another thread on here regarding general winter driving tips but I wanted to address this one by itself. ... |
#1 |
| Senior Member Join Date: Mar 2008 Location: Minnesota
My Car: 2002 Prius Model: Package: N/A Thanks: 0
Friends: 1 | I posted another thread on here regarding general winter driving tips but I wanted to address this one by itself. After owning our Prius since May 2008 and putting about 12,000 miles on it 133k total now, we got our first real taste of winter this weekend and cold temps (-15F right now, expected to dip down to almost -30F tonight). The interior cabin heater output cannot output nice hot air now because the engine just can't warm up enough. I tested blocking the radiator tonight using 2 pieces of cardboard, however, short of taking some parts out, I cannot squeeze one nice big piece of cardboard in there. Have people been blocking their whole radiator, part of it, none of it andonly blocking the vents in the grill/bumper (or both) or anything else (hotter thermostat, etc...)? If I remember right, G2 owners use pipe foam insulation on the grill slots, but I haven't heard of G1 owners doing that. While I wouldn't normally mind lower heat output, I do mind it in this car because the interior windows fog up easier than I like (and frost up quick at -15F), and MPG obviously suffers if the engine is not warm enough. Toyota's HVAC systems are normally very well designed and move a lot of air. The G1 seems to be a little bit below average. I need to check the cabin filter again before I officially blame the car, but when I checked it 7 months ago when we got the car, it was clean. It's so cold outside that the radiator hose on the driver side is only luke warm after the car has been driven a while, and the radiator hose on the passenger side is cold. I blocked about 3/4 of hte radiator and drove about 10 miles and it seemed to help a little (and the little blue "cold" light on the dash went out much faster). Anyway, just looking for any tips. I had almost thought low coolant or a blocked radiator, but the coolant level was fine, and if the radiator was actually blocked, one radiator hose would be extremely hot (as opposed to just luke warm). So, it looks like I found one (and only one) thing I don't like about our G1. |
Friends: 0 | Hi Optimus, We actually do not block the radiator, but the grill. This is typically done with plumbing pipe insulation. Split it appart and fit each side into a grill opening. Put knife slices into the foam so it will fit around and grab (a little) the vertical grill struts. Oh, I just realized you are driving a Gen I. On the Gen II's the gap between the radiator and grill, underneath, is aerodynamically blocked. So, blocking the grill prevents air from getting to the radiator (mostly). There is an Australian on-line car magazine called Autospeed, which shows how to mod the Gen 1 the same as the Gen II. Also, there is a guy (John1701 in here) with a web site about the Prius. He is from Minnesota. And at -15 F, you might want to consider a block heater too. These are available from Toyota of Canada, through several outlets on-line. Metro Toyota in Ohio is one of these. |
Friends: 10 | block your radiator and do it anyway you can. because of the lesser degree of waste heat a Pri generates, you will have issues getting AND KEEPING your car warm. we are in the middle of a cold snap (this morning lows were 11ºF that is a mere THIRTY DEGREES BELOW NORMAL). now yesterday on a balmy 21ºF day with a mild 10-15 mph breeze, the Pri struggled to get past 160º. now, i would heat it up to 160, turn on heat (set to 70) it would run about 2 mins and temps would be back to as low a 145º. i have my grill blocked 100% ( i block it as soon as the temps go below 50 been doing it 3 years now, no issues) so besides having difficulty warming up, running the heater GREATLY dissipates heat that is built up. now granted, this is city driving conditions, but even on freeway (average speed for these conditions are only slightly higher at around 35-40 mph but at least no stops) i probably will not see 180 unless i drive for an extended period. my method of blocking (granted some air will leak) is pieces of pipe foam insulation in the grill slots. i do ½" for smaller lower slats split in half and whole ½ for uppers with ends tapered for a better fit. not perfect since several pieces will leak, but without a damper system for better wind blockage, anything else would be inconvenient since i am looking for something simple and easy to remove if temps ever get too high ( have run car with OAT in the upper 50's without issue either...jus watch temps closer is all) **edit** GREAT!! go out to car, its about 10º. start it up to warm it up. switch to heat, car so cold heat no run... so turn off heat in order to warm up car and go inside and before i take two steps out of car, ENGINE SHUTS OFF!! so now i have to run defrost which makes car not heat up!@! man !! **update** ok, getting oil changed today, so drop off SO to work, on way there heat on whole time, max water temp 146. air intake bouncing between 31 to 35 (started at 18 this morning!!). i drop her off, turn off heat, run until car heats up to 175... turn heat back on...in less than 2 mins, temp back down to 155...sooo, as you can see, blocking the grill is PARAMOUNT!!!
__________________ My Blue 2010 : Last tank 541.9 @ 49.48 pump (56.7 MFD) 5.54 CPM, 21 MPH, Lifetime:5442.2 miles 56.5 MPG pump. (62.22 MFD) 4.72 CPM. Summer MPG 57.4 Winter: 49.5 My 2006 SPM: Last tank 376.6 miles @38.21 pump (40.8 MFD) 7.17 cpm winter mpg 49.64 summer mpg 53.41 lifetime: 42,563.5 miles 51.5 mpg pump (52.7 mpg MFD) 5.51 cpm My 2007 Zenn total "fuel cost" $166.58 on "about" 9599.7 miles. 1.74 cents per mile (granted i plug in for free at work!!) My Plate: DUALPWR (Dual Power) Last edited by DaveinOlyWA; 12-16-2008 at 11:30 AM. |
My Car: 2010 Prius Model: III Package: #1 Thanks: 147
Friends: 20 | Here are some other ideas: 2003 Prius - Cold Weather and Transaxle The first year, I used fiberglass re-enforced packing tape to completely seal the lower inlet. But then you have this sticky stuff to take off in the summer. My current practice is a split 'water noodle' held on by bungie cord loops. I live in North Alabama but you may find some of these notes useful: 2003 Prius - Cold Weather and Transaxle BTW, I'm finding the block heater provides a 10-15 C rise in temperature. Better than nothing, we're not talking fully warmed up. GOOD LUCK! Bob Wilson |
Friends: 0 | Hi Bob, At -15 F, one is going to have difficulting with any pressue sensative adhesive. Unless it was applied above freezing. Its best to get the thinner tubing insulaton foam, and either slit it, or seperate at the built-in seam, and stick it into the grillwork. The thinner foam has a wall thickness that will insert between grill bars. With my Gen II I can bridge 1 slot, covering 3 with 3/4" tubing foam. Or with 1/2 " diameter tubing foam, bridge no slots, and insert the foam into two adjoining slots. |
Friends: 20 | Hi, The NHW11, 01-03 has a single horizontal bar in the middle of the front bumper air intake. The NHW20 has the multiple, smaller bars/vent slots. But I'm surprised duct tape wouldn't work even in that cold of weather. Bob Wilson |
Friends: 0 | Hi Bob, It will stick initially, but the bond will be poor, and it will fall off. Its because the surfaces are so cold, that the intimate contact needed to get the microscopic static electricty attraction never occurs. Probably best just to use some ty-wraps (zip-ties) and hold the thick tube insulation on that way. You are using a pool noodle. But, they do sell tubing insulation that thick up here. |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 9
Friends: 12 | Been there, but didn't do it... 3 winters in Minnesota with my Classic Prius were fine. I'm one that never cared for hot from the heater. 4 winters in Minnesota with my Iconic Prius were that way too. Then last year, finally having a scantool available, I gave grille-blocking a shot. The climate here is too cold to show much of a MPG improvement. Efficiency pretty much bottoms out. But can squeeze out more heat that way. Details of what I did are in the User-Guide. . |
| Senior Member Join Date: May 2007 Location: Ontario
My Car: 2007 Prius Model: Package: B Thanks: 0
Friends: 0 | We had the temperature fall to about 18F the other day, and in my 12mile commute the scangauge said that the coolant never went above 68 degrees C. The cabin was freezing even with heat on, and the coolant fell by about five degrees C when I turned the heater on. I used a scraper on the inside of the windshield for the first time since I owned a '65 beetle. This didn't happen last winter, 18F isn't so cold, so I am convinced that my Thermostat is in need of replacement, even tho' I only have 18K miles on the car. I've had Thermostat problems in other cars in the past, albeit at much higher mileage. I'll post if this fixes the problem after tomorrow's service. BTW my fuel efficiency has been much worse for a month or so, and I was wondering why...hopefully I've answered that question.
__________________ Window tint, Scangauge II mounted on a left side ProClip, darned backup beep disabled, Block heater, and Synthetic oil (jury out on that one still) |
Friends: 10 | nyty; what you see is very normal. that is why grill blocking is so important. in F terms, i dont use defrost if i can get away with it until i hit at least 160. but when i turn it on, i immediately start dropping in temperature especially at street speeds. stop at a light, lose another 5-10 degrees, so its a battle to keep the vehicle warm when its cold out. |
| 15f, air, cabin, heater, luke, outdoor, temps, warm |
LinkBack to this Thread: http://priuschat.com/forums/generation-1-prius-discussion/56626-15f-outdoor-air-temps-luke-warm-cabin-heater-air-temps.html | ||||
| Technorati: Discussion about “-15F outdoor air temps = luke warm cabin heater air temps” | This thread | Refback | 12-16-2008 05:30 PM | |
| What happens when you idle for hours at low temps? Read on! | David Beale | Gen II Prius Main Forum | 3 | 03-05-2008 12:18 PM |
| Inverter 1&2 MG 1&2 Temps | hdrygas | Gen II Prius Technical Discussion | 8 | 06-01-2006 02:41 PM |
| MG1 & 2 Motor and inverter temps | efusco | Gen II Prius Main Forum | 18 | 03-26-2006 11:37 PM |
| ICE has started shutting down at low temps | storm petrol | Gen II Prius Main Forum | 6 | 03-03-2006 07:17 AM |
| 0 Degree Temps | tntna | Gen II Prius Main Forum | 17 | 12-27-2004 02:59 AM |
