| This is a discussion on Please help with issues on a 2001 within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; I bought the car with 60k. I did not change the inverter system coolant while I owned the car.The dealer's ... |
| | #11 |
| Junior Member Join Date: Sep 2009 Location: Florida
My Car: 2001 Prius Model: N/A Package: No Package Thanks: 0
Friends: 0 | I bought the car with 60k. I did not change the inverter system coolant while I owned the car.The dealer's comment was, "it's not like the inverter is gunked up inside with sludge, it's like the lines are caved in and have lessened the flow" They were not able to blow out any junk, he said. I certainly see your point though and it's a good one - things not maintained, don't last. But where were you with this thinking before? I would have been far more impressed if the first time you posted above you made the comment, "Have you changed the coolant as recommended? Because if you haven't I wouldn't bet that the inverter is problem free" Water under the bridge now. Live and learn. I have a good piece of advice for all Prius owners, keep an eye on the functioning of the inverter coolant pump, and change the inverter coolant regularly. The inverter is a part you do not want to have fail. |
| | #12 | ||
Friends: 44 | Quote:
It is certainly possible for the inverter pump to fail even if the coolant had been replaced on schedule. However, knowing that the coolant had not been replaced, there's some likelihood that the narrow aluminum cooling channels within the inverter have become clogged with oxidation. Once you take the car on a long drive in warm weather, you can see whether in fact the inverter is still working OK or not. Your first quote above says that you feel burned by buying a hybrid. Well - if the required maintenance was not performed, I'm not sure why you would feel "burned". The only other hybrid problem that you had was a failed traction battery, replaced under warranty, and this is becoming increasingly common as the Classic fleet ages. (My 2001 battery was also replaced under warranty at ~60K miles.) Nevertheless, you are 100% correct in saying that once the warranty is done, if you have a significant failure and have to depend upon dealer service to install new parts, that poses a big financial liability - a 4-digit repair bill or more. A Prius owner who is not a DIYer and is out of warranty should not be smug. Rather the owner should be nervous and worried. Last edited by Patrick Wong; 09-19-2009 at 10:00 AM. | ||
| | #13 | |
Friends: 20 | Quote:
ADVANTAGES
GOOD LUCK! Bob Wilson | |
| 2001, issues |
LinkBack to this Thread: http://priuschat.com/forums/generation-1-prius-discussion/68919-please-help-issues-2001-a.html | ||||
| 2001 Ford Mustang Problems on Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | 09-27-2009 10:01 PM | |
| HomeLink Issues | DFWPrius2009 | Newbie Forum | 17 | 07-21-2009 02:39 AM |
| Alignment issues? | saechaka | Gen II Prius Care, Maintenance and Troubleshooting | 15 | 11-17-2008 12:48 PM |
| How to check for potential steering/tranny issues in 2001? | xunkn0vvnx | Gen II Prius Main Forum | 6 | 04-16-2008 04:17 PM |
| 2001 prius issues helpppp!! experts | statultra | Gen II Prius Technical Discussion | 9 | 07-23-2007 10:30 PM |
| Safety issues | marty | Gen II Prius Main Forum | 14 | 11-22-2005 12:44 AM |
