This is a discussion on 2002 prius , Help Dash Light within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; Hi I just bought my 2002 toyota prius and i want to know why im getting this dash light every ...
Old 10-03-2009, 01:54 PM   #1
Yakuzahi
My Car: 2002 Prius
Default 2002 prius , Help Dash Light
Hi
I just bought my 2002 toyota prius and i want to know why im getting this dash light every morning (See Pic) .
its look like the over heat light.
the level of the antifreeze is full.
so there is something else i should do?
thanks
Zach
Yakuzahi is offline
Old 10-03-2009, 04:35 PM   #2
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Default Re: 2002 prius , Help Dash Light
Hi Zach,
The blue icon in your photo means that the engine is cold and needs to warm up. As long as that light goes off after a few minutes, no worries.
If you see a red icon that looks like the blue one, then this means the engine is overheating, and you need to stop and figure out why (or at least turn the car off if you can't figure it out.)
Patrick Wong is offline
The Following User Says Thank You to Patrick Wong For This Useful Post:
Yakuzahi (10-03-2009)
Old 10-03-2009, 06:34 PM   #3
Omni-TaG
Omni-TaG's Avatar
Model: I
Package: Base (Canada)
Hi Yakuzahi,
Exacly like Patrick said, Blue thermometer means that the engine is still cold and that the car has to be driven gently until normal operating temperature is reached. So in other words, when you have that icon in your dash board don't "floor" the gas pedal !
If it's not red every thing is ok !
Omni-TaG is offline
The Following User Says Thank You to Omni-TaG For This Useful Post:
2002, dash, light, prius
Engine light is on - 2002 Prius prosec34 Gen II Prius Care, Maintenance and Troubleshooting 9 12-27-2008 11:31 PM
Key warning light on dash thundermustard Gen II Prius Audio and Electronics 15 09-10-2008 12:51 AM
2002 Prius Hybrid Warning Light thebat Gen II Prius Care, Maintenance and Troubleshooting 3 09-05-2008 11:34 AM
Question About Brake Warning Light on 2002 Linda L Gen II Prius Care, Maintenance and Troubleshooting 0 03-23-2008 07:28 PM
2002 12 volt battery and warning light problems?? raven Gen II Prius Care, Maintenance and Troubleshooting 25 02-19-2006 06:59 PM
