| This is a discussion on 2003 Prius Traction Battery Swap within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; I have a 2003 with 109k. Runs fine, but dealer said red triangle code indicated the hybrid battery was leaking. ... |
| Junior Member Join Date: Oct 2009 Location: Va
My Car: 2003 Prius Model: N/A Package: N/A Thanks: 0
Friends: 0 | I have a 2003 with 109k. Runs fine, but dealer said red triangle code indicated the hybrid battery was leaking. Anybody know of a website where I can get directions & illustrations on how to remove / install another battery? |
| Junior Member Join Date: Oct 2009 Location: Chicago
My Car: 2001 Prius Model: N/A Package: No Package Thanks: 0
Friends: 0 | Hi. Maybe you have to buy this book: "2001-2003 TOYOTA PRIUS HV BATTERY DISMANTLING MANUAL" (just 9$), it probablly tell you everything about battery, here is a link: http://www.faxonautoliterature.com/p...89%26yr%3D2001 Last edited by marcinchicago39; 11-13-2009 at 12:31 PM. Reason: adding more information |
| Member Join Date: Oct 2009 Location: Vancouver BC
My Car: 2003 Prius Model: N/A Package: Base (Canada) Thanks: 6
Friends: 0 | Leaking battery on a gen1 one is covered under a TSB. Dealership is obligated to fix leaks without charge if under warranty. If this is your regular dealership I would try to get them to do the TSB for free. It's likely that it was leaking already undetected while still under warranty. You are only a bit past warranty so it wouldn't hurt to try. I would be interested to know how they diagnosed the problem. What were the error codes? Never trust a dealer. |
Friends: 14 | The special service campaign (SSC 40G) to prevent or correct electrolyte leakage was posted in this PriusChat thread by patrick Wong: Hybrid battery replacement 2002 Prius It does not specify a time or mileage limit for the free work to be done. |
| 2003, battery, prius, swap, traction |
| Traction Battery Dies in 2009 Prius Pkg 4 | Gary Boyd | Gen II Prius Care, Maintenance and Troubleshooting | 21 | 07-11-2009 09:20 AM |
| 2001 - 2003 Traction Battery For Sale | kuwona | Private Sales | 0 | 06-24-2009 10:55 AM |
| 2003 Prius 12v Battery Disconnect | kenopa | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 02-10-2009 10:54 AM |
| $200+ for 2003 Prius starter battery? | gene4655 | Gen II Prius Main Forum | 2 | 10-25-2007 02:47 PM |
| '98 Prius traction battery dies Down Under | Jack 06 | Gen II Prius Main Forum | 6 | 10-31-2005 03:26 AM |
