This is a discussion on Shuddering on acceleration within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; Originally Posted by matthis cleaned the throttle body, and added injecter cleaner to the fuel. There was an instant improvement ...
Old 10-14-2009, 01:22 PM   #11
bwilson4web
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 23
Default Re: Shuddering on acceleration
Originally Posted by matthis View Post
cleaned the throttle body, and added injecter cleaner to the fuel. There was an instant improvement from cleaning the throttle body but the problem is still there although less extreme. The problem is now most noticable when stopped in P or D while the HV battery is charging. I'll move on to the ignition coils next!
There is a throttle position sensor, a pair of dual-pots. The NHW11 is notorious for having 'dirty wipers' in the wiper-based, position sensors and this can cause all sorts of grief.
Good Prius friend Hobbit posted a web page on opening one and cleaning. I don't have the URL handy but someone may be able to point you to the page.
Removing and cleaning the throttle body and position encoder is not that hard ... with a Dremil tool, alcohol swabs and a little JB Weld ... probably a 2-4 hour job and a lot cheaper than a replacement throttle body.
GOOD LUCK!
A hybrid specific web site.
bwilson4web is offline
Old 10-22-2009, 10:32 AM   #12
matthis
My Car: Other Hybrid
After cleaning out the coils theres still some problems with the car so i want to replace coils 1 and 2, the existing ones are 'Denso 90919 02229' but I haven't been able to source these. As far as i can gather the engine in the NHW10 and NHW11 is 1NNZ-FXE. Do yo think I could order coils for a NHW11 and use them for my NHW10?
matthis is offline
Old 10-22-2009, 01:38 PM   #13
bwilson4web
03 and 10 Prius
Package: #1
Friends: 23
They should be identical to the:
  • Echo
  • Scion, 1.5L series
  • NHW11
Does the symptom follow the coils (aka., swap with 3 and 4?)
acceleration, shuddering
Acceleration BoilerUp Local Prius Club Main Forum 12 02-04-2008 01:59 PM
Acceleration rfloyd7522 Gen II Prius Main Forum 27 06-27-2007 06:32 PM
Unintended acceleration postjmm Gen II Prius Main Forum 5 07-07-2005 01:15 PM
ICE Shuddering in the Heat geminirat Gen II Prius Main Forum 11 06-08-2005 09:28 PM
Acceleration and mpg alanhu99 Gen II Prius Main Forum 25 03-02-2005 05:44 PM
