| This is a discussion on How to choose a good used transaxle. Ideas? within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; Originally Posted by orange4boy For now where can I probe with my multimeter to see the voltage without taking it ... |
| | #21 | ||
My Car: 2010 Prius Model: III Package: #1 Thanks: 145
Friends: 20 | Quote:
The only sensible way is to remove the traction battery and put it on a bench. Personally, I would hold off until you have a scanner and manuals. Quote:
Bob Wilson | ||
| | #22 | |
| Member Join Date: Oct 2009 Location: Vancouver BC
My Car: 2003 Prius Model: N/A Package: Base (Canada) Thanks: 5
Friends: 0 | Not necessarily. It may just have been the last nail in the coffin. Here's the story from the fleet manager. Tremblay is their service provider and the car was brought to them with some kind of transmissions problem. The tech entered "transmission wonky" an it was decided then to take it to the dealer: Quote:
| | #23 |
Friends: 20 | Sorry, I forgot to mention the ground fault interruption system. If the resistance to ground of either side of the traction battery falls below several megaohms, it takes power off of the three safety relays to isolate the traction battery on each end and breaks the middle. The system is so sensitive that an electrolyte leak will trip it. You never want to do anything to compromise the insulation and I believe the main power cables are shielded. A photo of the pan would help but I can imagine someone driving over a curb or rock in such a way as to loosen and start to unscrew the plug. Once loosened, the oil would leak out and vibration would cause the plug to unscrew and drop off. Loss of oil and the rest is burnt toast. Bob Wilson |
| | #24 |
Friends: 0 | In a way, I suppose it's a good thing because it's not an MG2 failure/manufacturing defect, just a accidental loss of fluid. One less negative reliability statistic. |
| | #25 |
| Junior Member Join Date: Apr 2006 Location: Russia
My Car: 2001 Prius Model: Package: N/A Thanks: 0
Friends: 0 | is it possible to buy used transaxle including the seller's warranty for some valuable time period in USA ? |
| | #26 |
Friends: 44 | Usually a salvage part has a very limited time warranty, like one week. The buyer is basically assuming the risk of failure. For example, see: http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories |
| | #27 |
Friends: 0 | It would be tough to drop it in, find out it's bad, remove it and get to back to the seller within a week. The last time I replaced a tranny, in a Volvo, there was a one month return policy that I didn't have to use. Things have changed since then. That's why I need to perform as many tests as possible. I'm hoping to find one close so I can pick it up myself. Update: The tranny died of thirst for sure: ![]() Slow leak through that tear...Fast leak out the drain. Happened to me once in my beetle. The oil drain plug let loose "for some reason" *ahem* and I lost 6 litres of oil in 100 feet. The oil light saved my engine and luckily a fire truck passed as I was stopped and cleaned up my mess. |
| | #28 |
Friends: 0 | Found a few at Gundies Auto Recycling which have a 6 month warranty if installed by a certified tech. I have a friend who could sign off on it. 2002 Transmission Toyota Prius 45,000--km--72,464 A B90519 $850.91 2002 Transmission Toyota Prius AUTO (CVT) 77,000--km--123,994 A B90433 $752.91 2002 Transmission Toyota Prius 1.5,AT 93,298--km--150,238 A PS69 $700 Will probably go for the lowest mileage one. Have to pick it up in Bellingham. Found one locally for $900 but with unknown mileage. This one comes with a 4 month warranty. With exchange it's about the same as 850 US. I can look at this one on Wednesday and if it looks good I'll probably get it and save the border hassles. Last edited by orange4boy; 11-02-2009 at 01:19 PM. |
| | #29 |
Friends: 20 | Ok, I'm going to suggest a couple of sensible precautions and why:
GOOD LUCK! Bob Wilson |
| | #30 |
Friends: 0 | I like the idea of a flush but I think I'm going to steer clear of the kerosene and do a very quick fluid change instead. I don't like the idea of a solvent sloshing around and thinning the fluid and eating into who knows what. Drop it in new fluid, drive a couple dozen miles, replace with new. All the other advise, I will take. Clean? I think I'll scrub out the inside of the case with a bit of sandpaper and maybe sandblast the case so it's all spotless. Haha. just kidding. Makes me shudder just to think about it. I think I will start the new thread soon. |
| choose, good, ideas, transaxle |
| Please Help Me Choose a DSLR | Proco | Fred's House of Pancakes | 27 | 09-14-2009 01:49 PM |
| if i replace hybrid battery & transaxle am i good? | myfootsmells | Gen II Prius Technical Discussion | 9 | 07-02-2008 06:44 PM |
| Please help me choose... so confused!!! | azcater | Gen II Prius Main Forum | 7 | 06-16-2008 05:31 PM |
| Help Me Choose | Husker4theSpurs | Gen II Prius Main Forum | 18 | 04-29-2008 06:16 PM |
| This forum has given me several good ideas... | gnagel | Gen II Prius Main Forum | 15 | 05-16-2006 09:24 AM |
