This is a discussion on Power outage: 1.5 hours within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; Originally Posted by bwilson4web Prius - UPS Project Bob Wilson Bob, Do you know of any reason that your testing ...
Old 11-08-2009, 05:28 PM   #11
jdcollins5
jdcollins5's Avatar
Package: Navigation
Default Re: Power outage: 1.5 hours
Originally Posted by bwilson4web View Post
Bob,
Do you know of any reason that your testing would not have the same results with the Gen III?
Dwight
jdcollins5 is offline
Old 11-08-2009, 05:49 PM   #12
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
Originally Posted by orange4boy View Post
Back on topic...sort of... That's a darn sight cheaper set up than the $50,000 LPG gas gen set someone ordered to be installed here on Bowen Island to power their entire 4500 square foot house during power outages, only to find out later that there is no LPG on the island, only propane by truck. Concrete base poured, wired in, fenced, bolted down, not returnable, not convertible. They found out when the gas fitter arrived to do the final task of connecting to the gas lines. It's hard being rich.
The best parts about using the Prius over a portable gen set...Quieter, much lower emissions, automatic start-stop, no jerry cans.
Would I be safe in assuming you mean't natural gas?
Propane is refered to as LPG here.
patsparks is online now
Old 11-08-2009, 06:06 PM   #13
bwilson4web
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 20
A Gen III should work just as well ... possibly a little better. It looks like the fusible link is now 125A. Also, the 12 DC comes from co-located, traction battery. IMHO, this helps reduce (I**2)R losses.
For my wife's car, I'm thinking about using a 1.5kW, sine-wave inverter along with a quality battery, like the Odyssey. I'll still have to check the sustained power level but I suspect the ZVW30 has more capacity.
My 1 kW, modified sine-wave inverter has a surge capacity of 1.2 kW. Although it works with some motors, it isn't a universal solution and a little more surge capacity would solve the inrush problem of modern power supplies. I have considered a 'stiffening' cap but the energy numbers don't make sense.
A hybrid specific web site.
bwilson4web is offline
The Following User Says Thank You to bwilson4web For This Useful Post:
jdcollins5 (11-08-2009)
Old 11-09-2009, 10:55 PM   #14
orange4boy
My Car: 2003 Prius
Package: Base (Canada)
Oops. Yes, I meant natural gas. (goes back to edit...)
orange4boy is offline
Unread Yesterday, 10:54 PM   #15
nerfer
A young senior member
nerfer's Avatar
Package: #1
I'll start a separate thread.
Sorry about the hijack, Bob.
I don't see your new thread, but I think I know what you're talking about. This company Solar Electrical Vehicles, originally had a system where the solar panels recharged the 12V battery only, in theory lessening the load on the main traction battery, so it would only need to run the wheels, not the fans, lights, etc. They claimed a 10% improvement in fuel efficiency. There was some debate here at PriusChat a year or so ago if that claim was legit.
Apparently they've been enable to extend this to power the traction battery as well, directly powering the vehicle and giving a better performance boost (although you can't drive 30 miles a day on sunlight, as might be implied by a casual reader looking at their bullet points - it would take several days of sunlight to get enough power for that, but if you plug it in, it will go 30 miles on the batteries only).
"We must be the change we seek" - Gandhi
nerfer is offline
Unread Yesterday, 11:12 PM   #16
nerfer
nerfer's Avatar
Package: #1
I'm looking into putting a pure sine-wave inverter on my 2006 Prius.
This one in particular: Pure Sine Wave Power Inverter 600 watt - DonRowe.com
Seems like a good price for 600W sustained, 1KW peak. Since it has overload shutdown, I'm thinking I wouldn't need an extra fuse to protect the Prius system, unless the overload shutdown wouldn't be fast enough.
I don't need a big system, just enough to power the fridge if necessary, but I want a pure sine wave to run a laptop on camping trips and such. Also, I understand the pure sine wave uses less power on some motors than a modified sine wave source. Since I've gone around with a Kill-a-watt to measure most of my appliances, I don't want to throw those numbers out the window with a different sine wave, and find out an appliance I thought I could power now I can't.
So my question is, am I overlooking anything with this inverter? I would also need the cables to the battery (shorter is better), and a way to mount it if carrying it around, but that's about it I think.
I'm going to review your Prius UPS site again and do some more research before plunking down dollars on it (my Christmas present).
nerfer is offline
Unread Today, 01:59 AM   #17
bwilson4web
03 and 10 Prius
Package: #1
Friends: 20
Looks like a plan.
hours, outage, power
Prius owner uses car to power home during power outage... Jon S Gen III 2010 Prius Technical Discussion 8 08-01-2009 12:05 PM
PriusChat Outage - The Inside Scoop Danny PriusChat Website Questions 61 01-12-2008 02:50 PM
Pelosi's first 100 hours dragonfly Fred's House of Pancakes 3 11-11-2006 10:00 PM
Net power = Engine power + Battery Power ? theorist Gen II Prius Technical Discussion 11 05-29-2006 08:15 PM
