2002 Transmission Issues
| Junior Member Join Date: Sep 2008 Location: Kansas City
My Car: 2002 Prius Model: Package: Base Thanks: 2
Friends: 0 | First time poster, long time Prius owner. This is a very strange and troublesome issue and I'm wondering if anyone else has had a similar issue or would care to comment. My '02 prius recently had to have the main battery pack replaced about 4 months ago. Toyota was very helpful with the entire transaction even though this second GEN I that I have now owned for about 3 years was at 175k and long out of warranty. After replacing the battery pack it was back in great shape, running fine for another 10k. Then a loud clunk and a stutter occurred when my son took off from a stopsign (a little quickly but nothing outrageous). Very gentle accelaration and there is no issue. Hit the gas a bit too hard though and it feels like there is a momentary slippage of the gears. Once up to say 15 mph or higher, it runs like a champ. Highway acceleration to pass and no issues. Now, today it started the clunk/stutter when I was slowing to a little quicker than usual stop due to a driver who apparently never learned about checking his brakelight bulbs. Anyway, thanks to my favorite non-dealer mechanic (he's been wanting to get a look at the little car and checked it over as a favor), a couple of calls and some very quick research he/we now have a theory. There looks from the diagrams that there is a chain assembly in the transmission. Could it be slipping like a 10 speed bike not quite engaged? Toyota does nothing but replace the entire transmission from what I understand. Before going into the dealer, I'd like to be as well informed as possible. Anyone have any ideas? |
Friends: 60 | Is it possible that the clunk is caused by a bad CV joint? Did your mechanic check the two half-shafts? It is true that if the transaxle is the problem, the dealer will replace the entire assembly as they are not able to disassemble and replace components. In that case you might want to consider buying a salvage part rather than spend $6K at the dealer for a new transaxle. |
| Thanked by: | ChuckM (01-19-2010) |
My Car: 2010 Prius Model: III Package: #1 Thanks: 783
Friends: 31 | Don't rule out engine/transmission mounts. Bob Wilson |
| Senior Member Join Date: May 2005
My Car: Model: Package: Thanks: 5
Friends: 0 | |
| Member Join Date: Nov 2006 Location: Indiana
My Car: 2010 Prius Model: II Package: N/A Thanks: 6
Friends: 0 | Am currently working through a failed transaxle on my 2003. Dealer will not replace transaxle subassemblies. Replacement trans quoted at $5650 plus labor, making the decision to repair a no-go. There is no shop I can identify in the midwest that will take on a trans replacement, so time to move on. |
| Ev and Hybrid Enthusiast Join Date: Apr 2009 Location: Fort Worth, TX
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 3
Friends: 5 | It isn't that the dealer is "unable" it is more that they are "unwilling" to do so. Dealers generally don't want to mess with tearing down engines or transmissions. Their techs are just trained to replace them, and sometimes not very well at that. |
In response to your post, however, some dealerships are quite happy repairing engines and transmissions, and do a very good job. | |
Friends: 60 | Quote:
- Please identify those Toyota dealers (name, city/state) who have tech staff competent to repair Prius transaxles (I am not talking about the typical Toyota automatic transaxle or transmission, where I would expect the typical dealership should have competent staff to repair some failures.) - What are the two or three most likely Prius transaxle failure root causes, and what would the Toyota dealer typically charge to repair those root causes? - Can the competent Toyota tech precisely identify the failed Prius transaxle part before the transaxle is disassembled? (In other words, how much risk does the owner assume that the final repair bill will substantially exceed the originally quoted amount?) A new transaxle has an MSRP of $3,460. Excluding the cost of labor to remove and reinstall the transaxle: - Suppose the MG1 or MG2 stator winding has failed. What will the transaxle repair price be? - Given the above, is it economical to repair the transaxle? In post #5 above, kenopa asserted that his dealer wanted to charge $5,650 just for the part, plus labor to replace the transaxle. This is a dealer markup of ~$2,200 over MSRP. - What could the dealer's service manager be thinking to charge such an exorbitant amount? - Is this just a way for the dealership to say, sorry, we are not interested in doing this work for you? Many Classic owners have reported transaxle failures outside the 5 year / 60K mile powertrain warranty, and have been asked to pay for a new transaxle. A few 2G owners have had transaxle failures outside warranty and again were asked to pay for a new transaxle. Here's a current example of a very simple transaxle repair. A wiring harness connector socket on the front of the transaxle was broken due to front-end accident damage. The OP's Toyota dealer service dept wanted to replace the entire transaxle, rather than replace the socket: I was robbed...... The OP towed the car to an independent Prius specialist for repair. This is a very important issue for Classic and older 2G owners whose cars' powertrain warranties have expired. The 7-9 year old car with 100K+ miles on the odometer has a market value of <=$5K. If the owner is confronted with a Toyota dealer repair quote of $5-6K (or even much more, in kenopa's case) to replace the transaxle, that is a very tough nut to swallow and it probably makes more sense to tow the car to the salvage yard (unless a salvage transaxle can be located along with an independent willing to install it.) I know of no case where a Toyota dealer's service dept has offered to repair a failed transaxle, and there have been a good number documented here on PriusChat as well as the Yahoo Prius forum. Since you know Toyota dealers who are willing to perform transaxle repair, please provide answers to the above rather than continue to keep us in suspense. Last edited by Patrick Wong; 02-21-2010 at 06:59 AM. | |
| | #9 | |||||||||||||||
You had stated: Quote:
So let's keep the focus on that. Agreed? To begin with, Toyota service information shows how to diagnose the motors in the Gen 1 transaxle, and how to replace them separately. As far as I know, Toyota does not offer training on the disassembly of the transaxle, which is not surprising, as it is not complicated, and is clearly explained in the service information. As well, you can find parts listings for both Gen 1 motor assemblies, as well as various components such as the PSD, gears, chain, bearings, and so on. But if, as you claim, Toyota dealerships "are not able to disassemble and replace components", then Toyota would surely have not invested time and money to make the service information and the parts available. Feel free to research this for yourself. Quote:
After all, we're all interested in accurate information. Right? Quote:
For the Gen II, there is no clear trend. But your question has nothing to do with your complaint. You've stated that if the transaxle is the problem, the dealer will replace the entire assembly as they are not able to disassemble and replace components. I've already provided enough information to help you learn for yourself that this is not so. Quote:
By the way, if my posts trouble you, please feel free to ignore them. Really, I won't mind. But if I see something posted that I know to be untrue, I may point that out, so that forum readers do not remain misinformed. What's wrong with that? | |||||||||||||||
I should have said that the dealer service department most likely will not recommend repair of the failed Prius transaxle. This is based upon my observations of a few dozen reported failures where a new transaxle was recommended, rather than the service dept offering to repair the old. If you know a specific situation where a Toyota dealership has actually repaired a Prius transaxle, I would be interested in hearing the details including the root cause of the failure and the repair price. Last edited by Patrick Wong; 02-22-2010 at 11:18 AM. | |
| 2002, issues, transmission |
LinkBack to this Thread: http://priuschat.com/forums/generation-1-prius-discussion/74920-2002-transmission-issues.html | ||||
| Pre-heating the Prius Transaxle and Engine for better fuel economy - Page 2 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com | This thread | Refback | 07-13-2011 11:21 PM | |
| Pre-heating the Prius Transaxle and Engine for better fuel economy - Page 5 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com | This thread | Refback | 02-24-2011 02:32 PM | |
| HELP!!! Steering issues with 2002 Prius | awestrom | Generation 1 Prius Discussion | 3 | 11-22-2009 09:50 PM |
| Best longer life tires for 2002 Prius? Size issues? | grbs5000 | Local Prius Club Main Forum | 1 | 06-10-2009 11:49 PM |
| main battery replacement issues for 2002 Prius, 80K miles | elendilmir | Gen II Prius Technical Discussion | 7 | 05-14-2008 05:25 PM |
| SERIOUS issues with my 2002 | whyuh | Gen II Prius Care, Maintenance and Troubleshooting | 19 | 04-12-2008 11:29 AM |
| Transmission Oil??? | chasabel | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 07-13-2007 09:35 PM |
