2001 Battery Question
| Junior Member Join Date: Dec 2009 Location: Iowa
My Car: 2002 Prius Model: I Package: No Package Thanks: 0
Friends: 0 | I am new to this board and new to the Prius. I have bought an '01 to fix up and keep as a daily driver. It was diagnosed by the Toyota dealer as needing the traction battery replaced before I got it. I have been driving it a little and it run on battery alone for about 1 city block when starting from a stop. I was able to find a battery pack from a nearby salvage yard. Before I swap the battery packs, I took the cover off to measure the total voltage which was 289v. 289 volts divided by 38 batteries is 7.06 volts per battery. On 1 side of the battery pack I measured from one terminal block to the next terminal, which is 2 batteries at a time, and measured 15.19 in all but the last 2 which were 15.20 volts. Is this good enough to consider this pack acceptable to install without taking all the terminal blocks off to measure each individual battery? How can I do a simple load test to try and find a weak battery? Thanks |
| Senior Member Join Date: Oct 2009 Location: Vancouver BC
My Car: 2003 Prius Model: N/A Package: Base (Canada) Thanks: 18
Friends: 2 | Welcome! Sounds like those are in good shape. My battery is fine and shows .1 volt difference between the highest and lowest modules. Yours shows .01 difference. Can I have your battery? I don't think you need to do a load test because the voltage is so even. These batteries have a much more robust chemistry than lead acid and the Prius "babies" them. They will wake up nicely after a long time dormant if they have not been discharged too far. Is there any corrosion on the terminals? That's something you should take care of before you put it in. Common problem on the gen 1 in hot or hilly country. It will be interesting to see how bad the original pack is since you are still able to drive it. Is it throwing codes? Check a couple of terminals and pop that baby in there. That's my two cents. |
Friends: 0 | There is green corision on 1 terminal, it's the 1st one closest to the comparment that holds the electronics. It is showing the yellow triangle and the PS but my scangauge II does not show any codes. The main battery appears to be orginal, the previous owner that put most of the miles on it never replaced it. I put it on a battery tender and after a couple days I did get a green light, but I think I might replace it anyway since reading some of the posts that say a weak 12v battery can cause some issues. |
My Car: 2010 Prius Model: III Package: #1 Thanks: 783
Friends: 31 | There is growing evidence that the electrolyte leak from terminals in the NHW11 modules can cause a P3009 code even though the modules still have service life. You may be able to clean the corrosion but more importantly, the electrolyte seepage to the case and restore the pack to service. I would still keep the salvage pack and take time to refurbish it ... clean modules and terminals. You might contact "Re-InVolt" and look at their product offerings. Replacing the NHW11 modules with NHW20 modules would give you an excellent replacement battery. Bob Wilson |
Friends: 0 | I briefly looked at Re involt... Is it a drop in replacement or is there mods that need to be done like to the battery box? |
| | #6 | ||
Friends: 2 | Quote:
It seems strange that you don't get a code on the scanguage though. Does the check engine light stay on while in ready mode? | ||
Friends: 60 | Quote:
It sounds like the OP has a good salvage battery, once the corrosion is cleaned off. OP's post #3 says that a PS warning has appeared. I assume that is on the MFD? That means that the electric power steering has a problem (the Classic Prius electric steering gear is a known fault area), so the vehicle may have more than one issue. Does the steering wheel shake while the car is being driven?
__________________ 2007 Prius 2006 Highlander Hybrid 4WD-i 2004 Prius 2001 Prius (sold Feb. 2008, 75K miles) 2000 Ford Mustang GT conv. | |
Friends: 2 | Mine has the same PS symbol every time the warning lights come on (like when 'im doing "experiments") but my PS is fine and I never get a code. I think that it's just a generic warning screen. Are the symbols greybatt, greyPS, red car! That's what I get any time it goes off which is only when I make it. But if it shakes...that's the "wiper" issue , right Patrick? |
Friends: 0 | Yes, the PS warning is on the MFD. The sterring wheel does not shake but it does have a very slight growl when the wheel is turned to the left a little. |
| 2001, battery, question |
LinkBack to this Thread: http://priuschat.com/forums/generation-1-prius-discussion/75522-2001-battery-question.html | ||||
| Pre-heating the Prius Transaxle and Engine for better fuel economy - Page 5 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com | This thread | Refback | 11-09-2011 02:48 AM | |
| Used 2001 Prius battery dead | BB_auto | Generation 1 Prius Discussion | 13 | 02-01-2010 12:48 AM |
| 2001 starter battery | MikeSF | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 11-10-2009 08:30 PM |
| Hybrid Battery used to cost ~ $8k in 2001? | cycledrum | Generation 1 Prius Discussion | 6 | 09-14-2009 03:04 PM |
| 2001 HV Battery ECU & possibly battery pack | greenbubba | Generation 1 Prius Discussion | 8 | 06-17-2009 01:49 AM |
| 2001-03 battery experiment | bwilson4web | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 12-30-2007 01:52 PM |
