Go Back   PriusChat Forums > Toyota Prius Community > International Owners
This is a discussion on Calling all Aussies and Kiwis !! within the International Owners forums, part of the Toyota Prius Community category; hi justkroozin, welcome to soon prius experience im lovin the car so much. 1st tank (dealer said he gav me ...
Old 06-29-2006, 01:39 AM   #151
cupcake
im lovin the car so much. 1st tank (dealer said he gav me a full tank) ran 700km.
filled up 38L, thats roughly 5.4L/100km very close to the screen figure of 5.6
this new tank is filled with premium unleaded... lets see if i can do better....
thinking about changing the wheels to some chrome of same size.
but i read from some site that the 2006 model has this tyre pressure monitor thing that if u change wheel it will disable this function.... any advice??
cupcake is offline
Old 06-29-2006, 02:10 AM   #152
tripp
tripp's Avatar
Friends: 6
<div class='quotetop'>QUOTE(cupcake @ Jun 28 2006, 11:39 PM) [snapback]278463[/snapback]</div>
Cupcake, the premium gas won't do anything for you in terms of performance. It's just a higher octane rating and probably engine detergents. Using the recommended octane is the way to go and it's cheaper! Regardless of octane all varieties of gasoline have the same energy content. The octane rating describes how combustable the fuel is. The higher the octane rating the less explosive the fuel.
I watched the Oz vs Italy game over the weekend (or was it monday) and turned off the TV disgusted. The FIFA officiating is truely horrid. There need to be two umpires on the field and the diving and theatrics should be reward with yellow cards and ejections.
Cheers,
Tripp
2005 Silver Pkg 3, OEM Block Heater, Coastal Tech EV mod, BT Tech Chassis Stiffener, hell damned infernal reverse beep disabled
Boulder Real Estate
Click the image to open in full size.Howay the Toon!
"Sometimes when you aim for the stars, you hit the moon." -- Ian Holloway
tripp is offline
Old 06-30-2006, 01:07 AM   #153
Aussie56
<div class='quotetop'>QUOTE(tripp @ Jun 29 2006, 01:10 AM) [snapback]278471[/snapback]</div>
Yes, it was a real let down. At the BP Service Station I noticed this BP Ultimate, and it includes detergents etc, although it's 98 Octane. I thought about whether a tank of it would help to clean the engine out or not, but decided to check into compatibility a bit first.
I must bookmark this part of the forum. It's good to be able to compare notes with other Australian drivers.
Actually I was wondering if anyone knows if there is a neat solution for a mobile phone antenna for the Prius, preferably something that can double for radio reception.
We're also planning to go on holiday for a month, and I've read that the 12v battery might not hold its charge for that long, although that was a US model that was being discussed, and there could be some differences. I've never tried to access the 12V battery yet, but I think it's somewhere in the rear compartment.
I've also read about the fact that different tyres can reduce road noise. Does anybody happen to know what the options are in Australia/ NZ? I should probably ask my son that one, because he's in the business.
Aussie56 is offline
Old 06-30-2006, 12:50 PM   #154
tripp
tripp's Avatar
Friends: 6
<div class='quotetop'>QUOTE(Aussie56 @ Jun 29 2006, 11:07 PM) [snapback]278981[/snapback]</div>
The 12V should be fine. I'm sure that there's no difference between yours and ours. However, if you're going to be on holiday for a while turn off the keyless entry. There should be a button beneath the steering column that allows you to turn it off. That system can drain the battery if it's left on for too long. People here on PC have mentioned leaving their cars parked for months at a time with no problems.
What kind of tyres are stock on the Aussie Prius? In the states we get the Goodyear Integrity, which has a low rolling resistance, but is a pretty mediocre tyre. There are a few Michelin tyres that are popular over here as replacements but I don't know if they're available down under.
tripp is offline
Old 06-30-2006, 09:54 PM   #155
Orf
Orf's Avatar
Package: I-Tech
<div class='quotetop'>QUOTE(tripp @ Jun 30 2006, 11:50 AM) [snapback]279172[/snapback]</div>
My 06 came fitted with Michelin Energy 195/60R15 88V XV1 Radial XSE tyres. They give a reasonable ride and are not unduly noisy.
There has been talk of ethanol E10 coming to Tassie. The fuel will be 95 octane. I contacted Toyota about suitability for the Prius and they replied that it was OK to use 95 E10.
Although the manual says to use 95 octane petrol, the dealer filled the car with standard petrol which is 92 octane. I have been using 92 ever since (2 tank fulls).
Australian 09 Gen 3 I-Tech Prius with side strips and rear bumper protector.
Orf is offline
Old 06-30-2006, 11:06 PM   #156
Aussie56
<div class='quotetop'>QUOTE(Orf @ Jun 30 2006, 08:54 PM) [snapback]279452[/snapback]</div>
My 05 Prius came with the same tyres, so they must be standard. They seem reasonably quiet. I don't know if you can get Comforttreads here or not.
I've filled up with E10 a few times and noticed no drop off in economy.
Aussie56 is offline
Old 07-01-2006, 11:34 PM   #157
evs
G'day Guys, Anyone know how to turn the reverse beeper off on Aussie spec cars (itech 2006). The US spec instructions don't work I'm afraid <_< (though they do for turning off the seatbelt beep)
evs is offline
Old 07-02-2006, 01:50 AM   #158
tripp
tripp's Avatar
Friends: 6
<div class='quotetop'>QUOTE(Aussie56 @ Jun 30 2006, 09:06 PM) [snapback]279483[/snapback]</div>
E10 is fine for modern cars. Here in the states there are many places where E10 is pretty common, especially in the winter to combat ozone pollution. There is a ding in mileage but it's not too bad. evs, somebody had that some question a while back. They might have posted it in this very thread. I don't know if a solution was ever posted. If you find one post it. The issue seems to come up once every couple on months.
BTW, how do you guys calculate Octane down under? It looks like your octane numbers are a bit higher than our here in the states. I put 85 octane in the car since I'm at a pretty high altitude (1610m above sea level). At sea level the recommended octane is 87.
tripp is offline
Old 07-02-2006, 11:55 AM   #159
sleeka
sleeka's Avatar
Model: V
Package: I-Tech
<div class='quotetop'>QUOTE(Aussie56 @ Jun 30 2006, 03:07 PM) [snapback]278981[/snapback]</div>
Hi, Aussie56.
Welcome to Prius ownership!
Are you anywhere near Brisbane? If so, there are a few other Prius owners here who enjoy their cars and like to talk cars and what we have done to them etc. Please let us know if you would like to join in.
RE: fuels...Shell Optimax (or BP Ultimate) will give a noticeable benefit in economy, but not enough to offset the 10cents extra per litre cost. I am trying E10 at the moment...no difference in either performance or economy, but cheaper per litre. I give ours a fill with Optimax every 4th tankful, primarily to keep the internals clean...it will certainly do that for you!
Sorry, can't help with any advice on the phone antenna at this time.
As you have a base model, your 12v battery (which lives underfloor in the right rear corner) should be fine while on holidays. Only the I-tech in OZ has the keyless entry which could drain the battery over time.
The standard tyres on OZ cars are the Michelin Energy series, which are low rolling resistance (and therefore quiet by nature) variants. Keep the pressures up to 42 Front/40 Rear psi, and they should be at optimum efficiency. By all means, ask your Son for further advice on that one, though.
Regards,
Sleeka.
<div class='quotetop'>QUOTE(evs @ Jul 2 2006, 01:34 PM) [snapback]279918[/snapback]</div>
Hi EVS, and welcome.
No joy with the reverse beeper on OZ cars so far, although many have tried!
Regards,
Sleeka.
<div class='quotetop'>QUOTE(sleeka @ Jul 3 2006, 01:48 AM) [snapback]280101[/snapback]</div>
Hi, Aussie56.
Regards,
Sleeka.
BTW, the steering recall work is underway here in Brisbane...dealers are advising that they need the car for 3 1/2 hours to relace the steering shaft.
Regards,
Sleeka.
'09 Tasman Blue I-tech. 17" BSA Wheels; Side Bump Strips; Illuminated Door Sills; Tinted Windows; Personalised Plates.
Prius Club of Qld....Brisbane.
sleeka is offline
Old 07-02-2006, 06:36 PM   #160
Aussie56
<div class='quotetop'>QUOTE(sleeka @ Jul 2 2006, 10:55 AM) [snapback]280101[/snapback]</div>
Hi, Aussie56.
I live in Central Queensland - Gladstone on weekends and Moura (200km West) during the week. I get to Brisbane infrequently, but don't usually have time to stop and chat. When I go to the Big Smoke, I usually have a number of reasons for going there Actually got my car from Scifleet originally.
<div class='quotetop'>QUOTE(evs @ Jul 1 2006, 10:34 PM) [snapback]279918[/snapback]</div>
No, but if you find out, let me know It's annoying. Interesting to hear that you can disable the seatbelt beep. Must try that.
Aussie56 is offline
Calling all PS3s bigdaddy Fred's House of Pancakes 1 03-24-2007 07:06 AM
London Calling Stev0 Gen II Prius Main Forum 0 10-18-2006 08:20 AM
Aussies or other Non-U.S. with 2006 augustson Gen II Prius Technical Discussion 0 10-07-2006 03:04 PM
I am calling for a boycott! mssmith95 Gen II Prius Main Forum 74 07-06-2006 06:53 PM
Euro/Jap/Aussies: Got floor anchor? naterprius Gen II Prius Main Forum 3 12-29-2004 05:27 PM
