Go Back   PriusChat Forums > Toyota Prius Community > International Owners
This is a discussion on Prius in Singapore within the International Owners forums, part of the Toyota Prius Community category; Hi peterlee, I think leebsq's Prius is a G2 which is different from the G3 that you are thinking of ...
Prius in Singapore
LinkBack (13) Thread Tools
Old 09-07-2009, 08:24 AM   #131
vincent1449p
My Car: 2003 Prius
Default Re: Prius in Singapore
Hi peterlee,
I think leebsq's Prius is a G2 which is different from the G3 that you are thinking of getting.
There is another Singaporean that is already owning a G3 (I think it is from the PI). Perhaps you might want to send a PM to geraldc.
PriusChat Forums - View Profile: geraldc
vincent1449p is offline
Old 09-08-2009, 09:32 AM   #132
Mike Dimmick
Package: T3
As for the MFD question, there is a menu in the 2G Prius which allows the Destination to be set. I'm not sure if anyone has actually done it, though. See here for the steps to get into it.
This menu is totally undocumented, even in the official service manuals. It seems to be a factory menu. I imagine that you could void your warranty if you set something incorrectly and you can't undo it.
I expect that there is a route into the equivalent on the Gen 3 car, but it would have to be some combination of steering wheel button presses since the touch-screen is no longer present on all cars, only those with reversing camera, park assist and/or navigation.
Mike Dimmick is offline
Old 09-09-2009, 03:15 AM   #133
Orf
Orf's Avatar
Package: I-Tech
Nobody has found a way of getting into a menu to allow input of destination in a Gen 3. I have searched for a way but to no avail.
Hi again, Vincent, long time no contact.
Orf is offline
Old 09-10-2009, 05:42 AM   #134
vincent1449p
My Car: 2003 Prius
Ya, it's been a while. So how is your FC tracking? Have you observed any discrepancy between the MFD reading and the lifetime calculation?
Old 09-10-2009, 08:32 AM   #135
Orf
Orf's Avatar
Package: I-Tech
Not really because I reset the MFD at each fill-up. Over 34,000km I had a calculated FC of 5.1 l/100km which is reasonable considering the number of very short trips.
The mapping system I use shows a discrepency between MFD figures per tank full and those calculated from km travelled and fuel used. I put this down to the fact that it is impossible to calculate accurately the fuel used.
I have upgraded to a Gen 3 and am now getting much better FE. Because the Gen 3 keeps MFD readings for Trip A and Trip B displays I can now compare the FC reading since new (trip A) against overall actual fuel used and km driven. When I log all the figures I will let you know the result.
Your FC figures are awesome. Are all Singapore roads down hill?
Australian 09 Gen 3 I-Tech Prius with side strips and rear bumper protector.
Orf is offline
Old 09-11-2009, 07:25 AM   #136
vincent1449p
My Car: 2003 Prius
LOL, how I wish there were all down hill. On the contrary, almost all of my commutes are on flat terrain. There aren't many hills in our small island. The highest hill stands at a mere 163.63 metres (537 ft.). As for the FC figures, I just try to do better then the previous year, sort of competing against myself.
It is good to know that Gen 3 is giving more options to users on how they want to track their FC by having a separate MFD readings for Trip A and Trip B. They should have implemented this in previous generations.
Care for the future
NHW11R '03 since 04 Jan '03
Lifetime 3.97 L/100km (Calculated), 3.7 L/100km (MFD) for 111,627km
Personal best tank 3.45 L/100km, 1380km set on 23 Jun '09
Old 09-11-2009, 10:17 AM   #137
Orf
Orf's Avatar
Package: I-Tech
The way I am operating means I have both trips tied up. Pity they did not display FC with the ODO.
The best FC I have had on a tank of petrol is 4.0l/100km. I achieved that driving on open highways (100km/h) and driving about 100km in a big city.
Having the FC graphically display in 1 minute segments instead of 5 makes it easier to associate driving conditions with the resultant FC.
Orf is offline
Old 09-14-2009, 01:36 AM   #138
vincent1449p
My Car: 2003 Prius
Cool, I can only get 4.5l/100km @ 100kmh. But I seldom drive above 80kmh because our highways are speed limited at 80kmh and some stretches at 90kmh. If I cross the border to Malaysia, the speed limit is higher at 110kmh and my FC always increases. Attach my FC chart:
Old 11-20-2009, 08:50 AM   #139
vincent1449p
My Car: 2003 Prius
After almost 7 years and 112,000 km, the Master Warning Light and the Hybrid System Warning Light finally pop up while driving. The MIL was not on though. The car sounded and behaved like normal despite the warning. So I pulled over to check what was wrong. After a few restarts, the warning lights would not go off. Since it was near my house, I decided to try driving back home. The car started as per normal and I can switch to the Energy & Consumption Screen by pressing the Info button. The SOC was at 50% and arrows flowing into and out of the HV Bty as per normal. Consumption was also normal. Fuel tank was more than 3/4 full.
At home, I checked the Brake Fluid level, Engine Coolant level Inverter Coolant level and Engine Oil level, all were OK. Then I recalled many posts regarding the sticky Throttle plate. Sure enough, it was very dirty as I have never clean it before. I used a long stick to loosen the Throttle plate. I restarted the engine, the warning lights still appear. Feeling a bit discouraged, I decided to call it a day.
The warning lights were on the whole time when I drive to work the next day. On returning home in the evening, it disappeared when I started the car! I guessed that maybe the car need to be driven so that the ECM would detect that the throttle plate is functioning normally again.
This weekend, I 'll get the Throttle body cleaner and brush to clean it up thoroughly. I 'll also add it into my DIY maintenance lists from now on.
Old 11-20-2009, 12:41 PM   #140
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
mmm.. interesting. Is that issue limited to the NHW-11?
Tideland Prius is offline
prius, singapore
LinkBack to this Thread: http://priuschat.com/forums/international-owners/6539-prius-in-singapore.html
Hybrid - Prius - Page 2 - MyCarForum This thread Refback 11-15-2009 03:52 PM
Hybrid - Prius - MyCarForum This thread Refback 07-13-2009 01:16 PM
The Little Red Dot: Some Prius sites This thread Refback 04-17-2009 04:05 AM
Honda Motorcycles St Louis, Honda Motorcycles Rebel, Honda Motorcycles Tampa Florida - Polarisfib This thread Refback 03-08-2009 05:37 AM
My Car Forum - Singapore Car Forum: Cars: Asian Makes: Japanese Talk: Hybrid - Prius This thread Refback 06-16-2008 03:41 AM
My Car Forum - Singapore Car Forum: Cars: Asian Makes: Japanese Talk: Hybrid - Prius This thread Refback 06-16-2008 01:49 AM
My Car Forum - Singapore Car Forum: Cars: Asian Makes: Japanese Talk: Hybrid - Prius This thread Refback 06-13-2008 10:52 PM
My Car Forum - Singapore Car Forum: Cars: Asian Makes: Japanese Talk: Hybrid - Prius This thread Refback 06-12-2008 02:35 PM
My Car Forum - Singapore Car Forum: Cars: Asian Makes: Japanese Talk: Hybrid - Prius This thread Refback 06-08-2008 05:25 AM
My Car Forum - Singapore Car Forum: Cars: Asian Makes: Japanese Talk: Hybrid - Prius This thread Refback 06-06-2008 01:48 PM
My Car Forum - Singapore Car Forum: Cars: Asian Makes: Japanese Talk: Hybrid - Prius This thread Refback 06-02-2008 10:53 AM
My Car Forum - Singapore Car Forum: Cars: Asian Makes: Japanese Talk: Hybrid - Prius This thread Refback 06-02-2008 09:44 AM
My Car Forum - Singapore Car Forum: Cars: Asian Makes: Japanese Talk: Hybrid - Prius This thread Refback 06-02-2008 09:25 AM
Question for Singapore Prius Owners wjtan International Owners 3 03-04-2007 08:06 AM
