This is a discussion on Disabling the Reverse Beep within the Knowledge Base Articles Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Gmalis, Those directions don't work for a 2010. You have to go to a dealer and have them reset the ...
LinkBack (7) Thread Tools
Old 07-05-2009, 07:41 PM   #71
Bica2go
Bica2go's Avatar
Package: Navigation
Default Re: Disabling the Reverse Beep
Gmalis,
Those directions don't work for a 2010. You have to go to a dealer and have them reset the beep.
Bica2go is offline
Old 07-05-2009, 10:31 PM   #72
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
Originally Posted by alarants View Post
I have same problem as fwellers:
"I tried this twice on an 08 I just bought last night. It didn't work for me. Both times, after I release the trip/odo button (step6), the dash indicator just goes to TripA.
Does this not work for 08's ? Any suggestions ?"
Can't find the trick? I have 07.
It doesn't work on the European Prius unfortunately.
Originally Posted by gmalis1 View Post
Okay...I must be a confirmed dope.
I tried to disable the backup beep following the above instructions.
I couldn't get it to work.
I am 100% sure I am in ODO mode.
I am 100% sure I held the Trip mode button for at least 10 seconds within six seconds of powering up (I tried at least three times counting to 20).
I am 100% sure I continued to hold the Trip mode button, then shifted to R and then P, then released the Trip mode button.
NOTHING CHANGED whatsoever on my display. NO toggle to "b on" or "b off".
Any comments or suggestions or most wanted...HELP!
Or, is this something that cannot be accomplished in a 2010 Prius?
I did accomplish getting all four doors to open when I open the drivers side door, however. So, I'm not a complete dope.
What Bica2go said. It's only for the Gen 2.
Originally Posted by TabbedOut View Post
Oh no, I don't blame you for anything. I'm sure it's something I did, or failed to do when I attempted this. Now that I've done it though I was hoping that someone had an idea about how to recover from it.
*edit*
well the backup cam is working this morning, but the locks still aren't. Oh well. Thanks for your help.
Hmm... so you can't unlock using the remote?
Tideland Prius is offline
Old 07-06-2009, 05:59 AM   #73
TabbedOut
Package: #8
No, the remote works fine, I was just trying to figure out how to get all of the doors unlocked with the smart key function.
TabbedOut is offline
Old 07-11-2009, 09:07 AM   #74
pickjs
you guys are the best, switched mine over as well. now i won't go crazy when backing up. why did anyone think this was a good idea? should be outside if anything
pickjs is offline
Old 09-03-2009, 07:16 PM   #75
jandrgold
I tried all these steps several times with no luck.
I have a 2010 Prius with the Solar Panel.
When you power the car back on, do you keep your foot on the brake the whole time?
Also, I'm assuming the ODO button you hold down is the Trip button.
Thank you,
Jeffrey
jandrgold is offline
Old 09-03-2009, 08:05 PM   #76
LRKingII
LRKingII's Avatar
Package: Navigation
Thank you,
Jeffrey
Sorry at this time no one has found a way to do it themselves on the 2010s. It must be done by the dealer.
LRKingII is offline
Old 09-03-2009, 08:07 PM   #77
jay_man2
jay_man_also
jay_man2's Avatar
Thank you,
Jeffrey
You have to have the dealer do it for a 2010.
Things that can be customized
Gen III Fix for Reverse Beeps?
jay_man2 is offline
Old 10-01-2009, 12:59 AM   #78
jon_lancaster_toyota
Nate Riesen
jon_lancaster_toyota's Avatar
If you touch the passenger side door or rear hatch relase, you'll unock all of the doors. On the other hand, you could try the method that works with the '10 Prius:
From outside the car, push and hold both the lock & unlock buttons on your key-fob until you hear a series of beeps. Generaly about 5 seconds, the series of beeps indicate the change has been make.
Relock the doors and touch the driver's door handle to see if anything changed.
I apologize, I don't recall for certain weather this will work for your car if it's not a '10 model.
Nathan Riesen
Certified Master Sales Consultant
Sales Society Master
Jon Lancaster Toyota/Scion
3501 Lancaster Drive
Madison, WI 53718
608-243-5551
www.youtube.com/nateriesen
www.jonlancastertoyota.com
nriesen@jonlancaster.net
jon_lancaster_toyota is offline
Old 10-25-2009, 05:20 PM   #79
Wolfie52
Senior "Jr" Member
Wolfie52's Avatar
I've seen tons of people wanting to disable the reverse beep, but frankly I wonder if that is such a great idea.
Several times I have had the shift lever in the "N" position meaning to put it into "P" (by pressing the button), but been distracted and not realizing the car was still in gear, almost rolled into a wall or a car parked in front of me. Having a car in reverse can be even worse because people might expect a car to roll forward, but rarely backward-- making a correct response to an accidental roll problematic.
For me I will put up with the reverse beep. It keeps my mind of the BACK of the car, and I always remember to shift to drive or park when done! It doesn't really bother me once I became accustomed to it.
Wolfie52 is offline
Old 11-05-2009, 06:56 PM   #80
reidhester
Too bad it doesn't work for the '10.
We had an 05 we recently sold and are taking delivery of a 10 this afternoon.
reidhester is offline
beep, disabling, reverse
LinkBack to this Thread: http://priuschat.com/forums/knowledge-base-articles-discussion/37380-disabling-reverse-beep.html
First Prius Experience - Twin Cities Gas Prices This thread Refback 06-23-2009 03:55 PM
First Prius Experience - Tucson Gas Prices This thread Refback 05-21-2009 03:14 PM
jjmerrill's Bookmarks on Delicious This thread Refback 05-04-2009 08:26 PM
AW: We did it! New car at last!!! This thread Refback 09-08-2008 02:27 PM
ammafighter1's Bookmarks on Delicious This thread Refback 08-31-2008 02:59 AM
Discover From Your Favorite Topic or Web Page: beep This thread Refback 03-26-2008 01:42 PM
MacT66's bookmarks tagged with "prius" on del.icio.us This thread Refback 02-08-2008 08:23 AM
Disabling reverse beep, installing backup buzzer Godiva Knowledge Base Articles Discussion 10 12-17-2008 01:07 PM
Is disabling reverse/seatbelt beep reversible? acousticbiker Gen II Prius Main Forum 4 07-08-2006 11:54 PM
Disabling reverse beep/seatbelt beep on an 06' Paradox Gen II Prius Main Forum 31 05-30-2006 10:53 PM
Disabling Beep In Reverse 2006 Howard Gen II Prius Main Forum 16 01-20-2006 12:26 PM
Disabling the reverse beep (and seatbelt beep) dougkm Gen II Prius Main Forum 1 12-01-2003 07:42 AM
