| This is a discussion on What HID replacements to get for best vision? within the Knowledge Base Articles Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I don't need new HID capsules yet but I think I have to worry a bit after 4 years. I ... |
#1 |
My Car: 2004 Prius Model: Package: #9 Thanks: 1
Friends: 0 | I don't need new HID capsules yet but I think I have to worry a bit after 4 years. I see several HID replacement options on the Sigma website, but I have no idea what makes for a better pattern of light than the stock ones. I'd like more side light, but I don't think that's a function of Kelvin rating. Has anyone needed new HIDs yet and found something good?... |
My Car: 2006 Prius Model: Package: #7 Thanks: 94
Friends: 10 | Kelvin rating is a measurement of the color temperature of the light. As the Kelvin rating increases, the color shifts away from red and toward blue. If you need more light than the standard HID lamps, you should seriously consider not driving at night. Tom |
Friends: 0 | |
Friends: 10 | That should mostly be controlled by the reflector. The stock HIDs already throw a lot of light to the sides on high beam. On low beam, you don't want the light over into the other lane. Good HID headlamps, like those on the Prius, have very sharp cutoffs on the low beam setting. Drivers not used to sharp cutoffs sometimes feel that the lights are not bright enough or not wide enough, but they are very bright in the intended area, and very black outside it. This is done by design to keep from blinding oncoming traffic. Cheep high intensity headlamps may appear brighter, but this is done at the expense of throwing light all over the place. Tom
| Senior Member Join Date: Jan 2008 Location: Altadena
Friends: 0 | Last edited by Steamboatsig; 02-24-2008 at 10:12 PM. |
Friends: 35 | Like stated above, it is very unlikely that a bulb change will create more side lighting. Going to a whiter bulb may make the lighting appear brighter but that does not mean it is helping you to see more of the road. In fact sometimes the whiter light can be blinding depending on what it is shining on, expecially fog. I understand the desire to have a white to blue tinted light for purely asthetic reasons as I've had 3 sets of 8k HIDs in my trucks. For safety purposes I think the stock HIDs are great. A shade whiter may look better but I do not think it would be worth the price to swap the stock ones out unless they have burned out.
__________________ 2005 Prius - Upgrades: Kenwood eXcelon KDC-X993, Diamond Audio D9800.2 and D61500.1 (1900w RMS), Diamond Audio D971 7" component set, 2 Diamond Audio D910D4 10" subwoofers (600w/ea). ![]() California Rangeland ConservationCoalition Ranchers, Environmentalists, And Agencies Working Together For The Benefit Of All. |
Friends: 0 | Here's the trick: with the thick posts on either side of the windshield, a lot of the time I feel like I'm turning into a black hole at night, since I have to look out the side window to see what I'm turning into. I'm not as close to the windshield as other folks, since the seat is all the way back. I'd prefer more light off to the side to make it less exciting. What would be ideal is a reflector that pops into place when the turn signal is activated, throwing some extra light in the selected direction. Short of that, I guess a brighter capsule would do but what would fill that job best?...
__________________ 2004 Seaside #9/BC as of 1/3/2004 Oil now any GOOD synthetic I can get on sale Michelin Hydroedge 195/65R15 tires since 2/5/2009 ![]() 90,000 miles as of 8/15/2009 Last edited by mikepaul; 02-25-2008 at 10:30 AM. |
Friends: 35 | Quote:
Friends: 0 | What about putting some sort of shim on the fog lights to make them point outward more. The fogs don't seem to do much mostly because the headlights drown them out, but they do provide light. I know because I covered the headlights and drove around with just the fogs. Someone wanting more side or lateral lighting needs to take the fogs apart and find a way to use washers to point them outward. That should provide sufficient lateral lighting. |
Friends: 0 | Maybe it's the tinted windows screwing me over, if I'm all alone on wanting extra light. Anyway when I need new HID capsules I'll be thinking maximum legal brightness just to see if it helps... |
LinkBack to this Thread: http://priuschat.com/forums/knowledge-base-articles-discussion/43156-what-hid-replacements-get-best-vision.html | ||||
| knowledgebase: Blogs, Photos, Videos and more on Technorati | This thread | Refback | 02-27-2008 09:33 AM | |
