This is a discussion on Tutorial: Rear tire alignment within the Knowledge Base Articles Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; It sounds spammish but he's got 34 posts in the past, some of which seem spammish while others seem to ...
LinkBack (1) Thread Tools
Old 05-21-2009, 10:57 AM   #21
TonyPSchaefer
Your Friendly Moderator
TonyPSchaefer's Avatar
Friends: 23
Default Re: Tutorial: Rear tire alignment
It sounds spammish but he's got 34 posts in the past, some of which seem spammish while others seem to provide real and helpful information.
I ain't touching it.
TonyPSchaefer is offline
Old 05-21-2009, 11:18 AM   #22
yardman 49
yardman 49's Avatar
Default Re: Tutorial: Rear tire alignment - possible lawsuit
Originally Posted by DaveLadely View Post
Eibach, the company that supplied the progressive springs for the Prius that won its class at Bonneville salt flats, has made both the springs and also front and rear alignment kits for the Prius, for reasonable prices!!
Dave:
Could you please provide some links for information on the Eibach "rear alignment kits"? I see that you've posted similar comments in another post where someone was asking about progressive springs for the Prius.
Thanks
yardman 49 is offline
Old 05-23-2009, 02:02 AM   #23
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Eibach does list an alignment kit for the NHW-20, but no photos or other info:
Eibach Springs - Performance Suspension, Lowering Springs, Shocks, Sway Bars, Coil-Overs and Wheel Spacers!
There is also another kit available from SPC which we have discussed in another thread:
SPC Application Search
dogfriend is offline
Old 05-24-2009, 10:25 AM   #24
DaveLadely
Eibach (www.eibach.com) has inexpensive but high quality front and rear alignment kits which allow much greater adjustment and control over alignment, which is severely restricted in stock form. In addition, they offer high quality progressive springs, at very reasonable price compared to other suppliers, for those who want to greatly improve the handling.
DaveLadely is offline
The Following User Says Thank You to DaveLadely For This Useful Post:
Gadgetdad (05-24-2009)
Old 09-11-2009, 06:54 PM   #25
Dan.
MPG Centurion
Friends: 19
Thread Resurrection... Apologies...
Here's the manual for the Prius (Gen I & Gen II ??) Shim Kit. It's the "align the numbers and cut the bolt holes" type of full plate shim. It does mention that you need to shave off some of the inner ring (look like about 1/8 inch) in order for it to fit. Not quite a "made for Prius" part, but may be close enough.
PS. The word "Copyright" does not appear anywhere in the manual or I wouldn't have posted it.
11011011
Dan. is offline
Old 09-11-2009, 06:57 PM   #26
drees
Off topic, but Copyright is implied whether stated or not.
That said, I doubt they'd mind you posting their user manual since it would only promote sales of their product.
drees is offline
Old 09-11-2009, 07:21 PM   #27
Dan.
MPG Centurion
Friends: 19
True enough... Mods, since the file is not hosted on PriusChat.com you guys are in the clear. Feel free to axe the link to my web server at your discretion.
11011011
Dan. is offline
alignment, rear, tire, tutorial
LinkBack to this Thread: http://priuschat.com/forums/knowledge-base-articles-discussion/43197-tutorial-rear-tire-alignment.html
Tutorial: Rear tire alignment by Wheel alignment This thread Refback 03-29-2008 10:44 AM
