| This is a discussion on Electric boosting Gas Engine in Crusie within the Knowledge Base Articles Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by bruceha_2000 I don't think I can agree with that. <snip> You don't have to agree with it, ... |
| | #11 |
My Car: 2006 Prius Model: Package: #7 Thanks: 367
Friends: 14 | You don't have to agree with it, but it is true. The most efficient transmission is no transmission at all. With a Prius, all of the energy comes from the ICE. The most efficient way to get that energy to the road is through a straight drive with no gears or electric motors. This is why track bicycles have only one fixed gear (and no brakes!). Obviously, you can't drive a car with only one fixed gear. You can't get it up to speed, and even if you could, it would only be the correct gear for one speed and no hills. The same thing is true for the hybrid part of the Prius. The battery and electric motors are all energy wasters. Ideally you don't want to use them. From a practical standpoint, you have to use them for real world driving. The point I am trying to make is that regenerative braking and EV driving are all net wasters of energy. You don't want to use them unless the alternative is worse. Many new Prius owners make the mistake of trying to maximize the use of regenerative braking and EV, which is exactly to opposite of what you want to do for good mileage. Darelldd's comment is correct. Darell, since your comment applies only to drivers of fully electric vehicles, wouldn't it be better for you to just call both of them on the phone, rather than post to this forum. Tom
| | #12 | ||
My Car: 2006 Prius Model: Package: #6 Thanks: 19
Friends: 13 | Quote:
So, you say this form is for the Prius, huh? Quote:
Seriously though, there are hundreds of thousands of us in the US. I kid you not. I'm talking about all motor vehicles that are registered with the DMV with "e" as the propulsion. So that includes all hand-built, custom, low speed AND production cars. Still, a couple more than two. Last edited by darelldd; 09-15-2008 at 04:56 PM. | ||
| | #13 | |
Hopefully Chevy considered the inefficient part. Last edited by 9G-man; 09-15-2008 at 06:36 PM. | |
| | #14 | |
Above 42 MPH, if you have yellow arrows only (electric only) going to the wheels you are achieving a very efficient, high MPG, mode of operation. It should be sought on most any downhill incline, where maintaining speed is desired. The criuse control can do this quite well, at moderate speeds of 60 MPH and less, on declines. So can the driver, by lifting and lightly reapplying gas pedal pressure above 42 MPH. I actively seek this condition on every downhill I drive. I think what these other folks are talking about is the HSD bleeding off excess charge from the battery, which is worthless, other than possibly reflecting being near ''SHM', something focused on by some Prius owners at another site. Called 'Super Highway Mode', it's kinda the highest efficientcy, lowest fuel burn, mode possible with ICE operating, just before it drops off into Warp Stealth Last edited by 9G-man; 09-15-2008 at 06:42 PM. | |
| | #15 |
| Senior Member Join Date: Jun 2004 Location: s.f. bay area
My Car: 2004 Prius Model: N/A Package: #9 Thanks: 10
Friends: 5 | While cruising at highway speeds, i tend to take that whole "tiny burst" screen as a "you're mpg is maxed out for speed"... or most efficient "gear"... gear being your SOC. |
| | #16 |
| Member Join Date: Mar 2005 Location: Eastern North Carolina
My Car: 2005 Prius Model: Package: #7 Thanks: 0
Friends: 0 | OK, since posting this, I've taken to lightly laying foot on gas peddle when crusing at 65mph, and have noticed about a 4 or 5 mpg average increase per tank full. It seems to cause the electric boost to kick in more often, and for longer spells, versus not having foot on gas peddle. And it works on straight flat roads as well as downhill. No one has mentioned the fact there is actually 2-electric motors in this car. That is how you can charge batteries at same time that you can drive with electric power. |
| | #17 | |
| Senior Member Join Date: May 2008 Location: Marietta, Ga
Friends: 1 | Quote:
| | #18 |
| Reduce, Reuse and Conserve Join Date: Feb 2008 Location: South Florida
Friends: 0 | In reference to fuel economy using Electric Boost, here is what I have found: I have done some extensive testing in the real world to see how different driving techniques/speeds affect mileage. here in FL on flat level ground and driving with cruise control on locked at 45mph (daytime driving with lights off and AC off), I can repeatedly get 73-89mph assuming one to three almost stops during that run. An almost stop means its a red light up ahead and I time it just so I can release the cruise, roll just long enough to manually accelerate back up to 45 then re-engage cruise, thus not having to stop the car and start from a dead stop. I do this trip very often. For every MPH over 45 you go, you start to loose MPG's. On the highway, I get an average of 48MPG with AC on, from Fort Lauderdale to Atlanta, GA at 64MPH, the same drive with AC off boosts upwards to 51-54 and that variable depends upon wind speed. If its a windy day, I see a drastic reduction of MPG if I'm driving into it. If its at my back, of course I can see as much as 2-3 MPG increase. You will see some increases at 55MPH, but if its a long trip like the 710 mile run I have done, its virtually unbearable at 55MPG. It's just way too slow. For every electronic device you have running in the car, is more power you take from the Hybrid system so every small amount you take, you sacrifice MPG's. The only one I can measure a difference on is the AC system. The headlights I can see a difference on the Scangauge due to the increased amps the car is drawing, but have not been able to notice a difference in fuel consumption except with my AC system tests. The more power you have stored in the hybrid battery, the more the car's computer tries to expend the energy. Ideally you would get the best mileage if your hybrid battery's SOC (State of Charge) is at the highest it can be on your display meaning all green or full to down one bar. At full, your SOC is around 76-78%, at empty, your SOC is no less than 40%. The computer will not allow the SOC to drop below 40% nor get above 78%. This is to make your NiMh hybrid battery last the life of the car as the plates inside the battery tend to develop sulfation at lower and higher charge states. Essentially, your hybrid battery will last 10+ years with this type of charging control, however you will notice its capacity diminish over the years but it should not affect MPG too much but I would presume there will be a measureable difference if you someone like me who watches every system in detail along the way. Driving up and down mountains in the N. GA area, I have been able to achieve 54-65 MPG by coasting down the mountains and using its enertia to get partway back up the mountain and then using the accellerator pedal as an assist only. I sometimes will use Neutral to coast down when the hybrid battery is at or close to full as this will give me maximum speed down without the hybrid drag and get me higher up the mountain next, then I put it into drive to get the rest of the way up, however you have to be alert and do this only on straight runs, some mountains have curves on them and you really don't want the car to take off to fast around those curves as it can prove to be very dangerous. Another thing you can do, is drive in the lane to the left or right of a semi just a tiny bit behind it. You want to keep your Prius in the pull of the Semi as to reduce wind resistance. I did this for a few hundred miles and achieved 75MPG at 65MPH. The MFD reported 89MPG the entire time, however real world calculations have shown 75MPG. All in all, over 10,400 miles I have averaged a lifetime MPG of 48.9MPG. I don't exceed 64MPH and I try to coast and regenerate energy whenever possible. I have no modifications made to this 2008 Package 5 car. Tire Pressure is maintained at 38 front, 35 rear topped off monthly. So to sum it all up, get the most MPG by maintaining a constant 45mpg on flat level ground and don't ever stop! Your next break is at 55 and then at 64. Speeds below 42MPH work the same as speeds above 64MPH, you loose economy with speeds below 42 just not as rapidly as you do with speeds above 64. Anything over 64 the curve goes WAY DOWN! At 80 you will be lucky to average 36MPG and don't crash at 80 or you will litereally be at one with your car. So there you have it!
__________________ anti-gas South Florida --------------------------------------------------- 2008 Package 5, with NAV, Weather Tech Floor liners, front, rear and cargo liner, door edge molding, 40psi tires, Custom made denim seat covers that cover everything, Dashmat, Mobil 1 Synthetic Oil, Llumar Window Tint, Over the headrest DVD player for the little one, ScanGaugeII with BlendMount, Flux Capacitor for Time Travel Mode |
| boosting, crusie, electric, engine |
| Does the electric engine have more torque or gasoline? | Jaqueh2 | Gen II Prius Technical Discussion | 9 | 07-19-2007 10:16 PM |
| Engine idle changeover (ICE to ELECTRIC) | smokey1 | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 03-06-2007 01:11 PM |
| Do Hypemilers Really Need the electric engine? | driveprius | Gen II Prius Fuel Economy | 6 | 01-30-2006 11:11 PM |
| Toyota Boosting Prius Production | Mitchla | Prius and Hybrid News | 0 | 08-05-2004 01:30 PM |
| Boosting Fuel Efficiency : Kerry: Billions for car industry | jkash | Prius and Hybrid News | 19 | 08-03-2004 01:34 PM |
