| Local Clubs, Events, and Road Trips This is a discussion on 06/09/07 - Houston Prius EV + EBH install within the Local Clubs, Events, and Road Trips forums, part of the Toyota Prius Community category; On Saturday June 9th I will attempt a Factory EV install and Engine Block Heater install. If anyone has wanted ... |
| MPG Centurion Join Date: Sep 2005 Location: Houston, Texas
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | On Saturday June 9th I will attempt a Factory EV install and Engine Block Heater install. If anyone has wanted to see one of these procedures, next weekend might be your chance. I can't guarantee success, but we (my neighbor and I) will give it a shot. I've done some recon on this today and was able to pull the ECU plug and also found the spot for the block heater. I've got the wire taps and assuming I can fit the ECU pin in and fish it the wire across the dash, I should be in good shape. The block heater is a Toyota of Canada model and the EV is the Japanese Factory model. Just email, pm, or post to this thread if you want to assist in the surgery. 11011011
__________________ Dan is an official (Honda) Hydrogen Economy Convert! Houston Hybrid and Hypermilers Club <106mpg.com> ![]() ![]() Best commute = 14.3mi @ 114 MPG (sg2) Best (non-trivial) tank = 769mi @ 85.7 MPG (fcd) MPG Centurion-Hybridfest 2007-Prius II-26mi @ 106 MPG (sg2) Dan <11011011> @ CleanMPG.com |
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | <div class='quotetop'>QUOTE(priussoris @ Jun 3 2007, 08:00 PM) [snapback]454660[/snapback]</div> Quote:
On the todo list. 11011011 | |
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | OK... First the good news... EBH works and OEM EV works. Now for the bad news. 1) First stab at EV button wired it exactly, and perfectly backwards . Surprisingly, to me at least, backwards still works. Only problem is you won't get LED. Well I didn't like a ground reversal hard wired to my ECU so out with the wire clips, mosquito spray and camping lamp. Now everything works great.2) Didn't quite get the suggestions on the EBH install right and tried to install it with the rod plugged into the cord. Well with that extra inch of coupling, the block heater won't fit. So after a quick call to FireEngineer I was informed of my error, and got it installed, then plugged in. Problem was the thermal guew went on, then off then back on since I had to re-approach the install path twice. Don't know how much effect it will have. It does work, just don't know if it could be working better. 3) To fish the cord to the grill, I took off some underplaying. In the process I stripped a nut There was a small rock that had fallen right at the thread entrance, and while I took the nut out, the rock scored the threads. So now nut 2 from the left headlight is replaced with one bright yellow tie cord. Tests: EV - Start the car, hit the switch and you get the popdown on the MFD "Cannot switch to EV" cuz I'm in stage one. So it works. LED now works too EBH - It was about 90 ºF (32 ºC) outside when I plugged in the EBH and left it in for 60 minutes. The water temp (via SGII) gradually went up from 107 ºF (42 ºC) to 135 ºF (57 ºC). So about half a degree per minute. Questions: Is anyone running the EBH in the summer? Do you have any data to share as far as what type of measured heat exchange your seeing. If mine is low, I could consider re-installing it, but it's not something I'll do on a whim. Special thanks to FireEngineer, mparrish, and my neighbor for providing the much needed assistance. 11011011 |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | <div class='quotetop'>QUOTE(Dan. @ Jun 10 2007, 01:38 AM) [snapback]459067[/snapback]</div> Quote:
Wayne | |
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | [quote=Skwyre7 @ Jun 11 2007, 01:04 PM) [snapback]459617[/snapback]</div> Quote:
Once you grease the block heater it's real slippery (big surprise huh). It ended up shooting out of my hands more than once, so I lost some of the grease that way... If I had to do it again, here's what I would have tried.
And finally, since I didn't have a jack, I had to improvise. I put some wood on the lawn right by the curb. Then I drove the passenger side wheels onto the boards on the lawn, leaving the driver side wheels on the street. This jacks the car up about 6-8 inches which was JUST enough to fit my frame. Probably to the most fool hearty stunt I've pulled but managed to get it done. By my calculations a blow out wouldn't have killed me, but definitely would have hurt like ***. Ohh.. and there are plenty of sharp pieces of block under there. Got my hands tore up fiddling under there. More later PS.. numbers on in on the first commute post EBH/EV install. 15% jump in FE. Probably at least a 10% sustained increase, but time will tell. Totals for my drive in this morning were 14.3 mi] 80.4 mpg @ 82 ºF (outside air temp). 11011011 | |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | <div class='quotetop'>QUOTE(Dan. @ Jun 11 2007, 02:17 PM) [snapback]459664[/snapback]</div> Quote:
Wayne
__________________ 2005 Salsa Red Package 6 (BC) 2004 Oldsmobile Silhouette "Final 500" mini-van Free engine block heater install, just ask. 126 warmer Prius done to date. Come join us at the ChicagoPriusGroup. | |
| Prius at the Houston Raceway | Ray Moore | Prius Main Forum | 1 | 10-15-2005 11:24 PM |
| Houston...we've got a problem | innov8v | Prius Main Forum | 28 | 07-09-2005 04:24 AM |
| City of Houston Prius | bethmaup | Prius Main Forum | 4 | 07-02-2005 06:37 PM |
| Houston Prius supply improving? | ml194152 | Dealers & Pricing | 21 | 06-28-2005 10:03 PM |
| Houston, TX Prius service - where? | cpwaites | Prius Main Forum | 11 | 03-18-2005 07:28 AM |
