If only a Hummer weighed as much as a Prius
| | #11 |
| globally warmed member Join Date: May 2008 Location: Southern California
My Car: Other Non-Hybrid Model: Package: N/A Thanks: 534
Friends: 4 | The article also misses the point that most Hummers will be sitting in junk yards and land fills five years from now. Did they factor that environmental impact into their report? The planet earth has a FINITE amount of oil. If everyone drives a Hummer (including China and India), how long do you think the oil will last? What if everyone drives a Prius? Seems pretty simple to me. |
| | #12 |
| One Mean SOB Join Date: Feb 2008 Location: Los Angeles, CA
My Car: 2008 Prius Model: Package: #2 Thanks: 2
Friends: 0 | Wow! That's the worst most illogical article I've ever read. Must be a philosophy major that wrote it. |
| | #13 | |
| Senior Member Join Date: Feb 2008 Location: Virginia
My Car: 2005 Prius Model: Package: #4 Thanks: 33
Friends: 2 | Quote:
The premise of the article seemed to be something along these lines: "there's a big energy cost to building a new car, but that disappears as soon as the car is resold once". Which is just ... stupid ... there's no other term for it. As one comment at the end of the article pointed out. We actually had an intelligent thread, here, some years back, on the issue of whether replacing an older low-MPG vehicle mileage car with a newer, high-MPG car was an environmentally sound thing to do. Given that almost all the energy use of the typical car is in the gasoline it uses, not in the manufacture and scrapping, the general consensus was that, within reason, trading up to a higher-mpg car typically was an environmentally sound decision. But then that article goes from dumb to dumber, with all the usual propaganda tricks. First, we have to pick a tiny comparison car. The comparison vehicle for the propaganda is a 1998 Toyota Tercel (80 Cu ft interior volume, 9 cu ft trunk space), which as we all know is completely comparable to a Prius (96 cu ft interior vol, 16 cu ft trunk space). Then we have to exaggerate the mileage of the comparison car. The 1998 Tercel with 3 speed automatic got 27 MPG, per the new EPA ratings (see Fuel Economy). The manual got 30. No 1998 Tercel got the 35 mpg the author cites. Then we have to ignore the energy required to produce the comparison and only talk about the energy required to produce a Prius. But here's where it goes from dumb to dumber. Even if you pick a tiny car, exaggerate the mileage, and assume that it took zero energy to build, even if you do all that, you still use less energy driving a Prius. Based on the assertions in the story, you'd still use less energy by building and using a new Prius, for a 150,000 mile vehicle life, than you would by running a string of of these mystical energy-free 35 mpg used cars. Putting that another way, a car fleet consisting of new Prii, replaced every 150,000 miles, would use less energy than a car fleet consisting of mystical zero-manufacture-energy 35 mpg used cars. So even with the assumptions of the article, the arithmetic does not work out to support the author's point. Which is just stupid squared, to construct your propaganda so that it doesn't make your point. Anyway, on a smarter note, can anyone here find a reference for how much energy it takes to produce a lead-acid car battery? I already know that, lifetime, the Prius uses less total metal for batteries than a traditional car does. (Why? Because the typical car goes through 3 50 lb lead-acid starting batteries in its lifetime, based on industry statistics. The total amount of lead in those 3 batteries (about 75 lbs) is greater than the 30 lbs nickel in the Prius traction battery plus the (my guess, lifetime) 16 lbs of lead in the Prius 12V battery). I assume lead's a lot easier to smelt than nickel, but I can't find any reference to tell me how much less energy it takes to produce a pound of lead than to produce a pound of nickel. Last edited by chogan2; 05-20-2008 at 12:40 PM. | |
| | #14 |
| Honda Enzyte Driver Join Date: Oct 2006 Location: Lewisville, TX (Dallas area)
My Car: Other Hybrid Model: Package: N/A Thanks: 756
Friends: 4 | So if I buy a used car, it's greener because half of it is not going to fall apart? |
| | #15 |
| Engineer Join Date: Apr 2007 Location: Atlanta, GA
My Car: 2007 Prius Model: Package: #1 Thanks: 0
Friends: 0 | Umm, anyone care to read: Pacific Institute Even the new analysis can be flawed... considering the much lower efficiency of automation in the past. However, having more workers on an assembly line vs. robots does decrease the carbon footprint of mfg... |
| | #16 | |
| High Fiber Member Join Date: Jun 2005 Location: South OC So Cal & the Flathead Valley MT
My Car: 2004 Prius Model: N/A Package: #9 Thanks: 126
Friends: 24 | Quote:
Funny that Hummers and their ilk, being such wonderfully popular (according to the GM ad man) & efficient vehicles, are just sitting on lots accross the nation ... even to the point where GM has to put 'em on extra parking lots at hotels http://photos1.blogger.com/hello/115...24/Hummer2.jpg while prospective Prius owners have to wait for deliver. I don't get it! | |
| | #17 |
| S is for Super! Join Date: Mar 2008 Location: SoCal/AZ/NV
Friends: 6 | ^lol^ yes yes from a 11mpg h2 to a 15mpg caddy ext, and now to my japanese princess the 40+mpg prius LOL |
| | #18 |
| Senior Member Join Date: Aug 2005 Location: Baltimore MD
My Car: Other Non-Hybrid Model: Package: Thanks: 247
Friends: 0 | I read and was quite upset. The Prius pays back ALL of the cost of making it in somewhere betweeen 40,000 and 100,000 miles. Probobly closer to half the number these idiots are quoting. It will last far longer. Driving a 10mpg hummer could produce more co2 out its tailpipe <let alone what it cost to make> in just ONE YEAR of driving. |
| | #19 | |
| Senior Member Join Date: Jan 2008 Location: Minnesnowta
My Car: Other Non-Hybrid Model: Package: Thanks: 204
Friends: 6 | Quote:
I've been discussing a thread over at gminsidenews that Gm basically should kill the H2. It's a complete waste. For me I'd jump all over a used car that gets 35MPG for $4500 versus buying a new hybrid car for about $28,000. But, My S-10 is paid for and all I have is typical maintenence and fuel costs and thats it. | |
| | #20 | |
| Member Join Date: Jul 2007 Location: Newport News, VA
As for the idea of the carbon footprint being paid for by the first owner, I took the best way out of this, by buying a used Prius. The main reason, as I have also explained on GMInsideNews, is that, despite whatever admiration I might have for Toyota devising this car, I was absolutely not going to hand Japan Inc. $25,000.
__________________ Never try to keep up with the Joneses...drag them down to your level, its cheaper! | |
LinkBack to this Thread: http://priuschat.com/forums/prius-hybrid-ev-alt-fuel-news/47578-if-only-hummer-weighed-much-prius.html | ||||
| Jeremy Clarkson on the Prius - MY350Z.COM Forums | This thread | Refback | 07-08-2011 02:18 AM | |
| Prius vs Hummer? Take that, Hummer!! | abq sfr | Prius, Hybrid, EV and Alt-Fuel News | 25 | 11-10-2011 03:25 PM |
| Prius vs Hummer | Renocat | Gen II Prius Main Forum | 26 | 09-29-2006 10:09 AM |
| Hummer and the Prius | wan | Gen II Prius Main Forum | 23 | 09-10-2006 02:55 PM |
| Hummer vs. Prius | jrohland | Prius, Hybrid, EV and Alt-Fuel News | 15 | 12-08-2005 02:20 AM |
| More Prius v Hummer | David | Gen II Prius Main Forum | 1 | 03-08-2004 11:04 PM |
