Go Back   PriusChat > Toyota Prius Forums > Prius and Hybrid News
Prius and Hybrid News This is a discussion on Plug-in Supply $6,095 plugin kit DIY within the Prius and Hybrid News forums, part of the Toyota Prius Forums category; Originally Posted by efusco Another e-mail when I asked him to send me an update when they had pricing for ...
phev
Old 08-08-2008, 10:29 AM   #31
hill
High Fiber Member
hill's Avatar
Default Re: pluginsupply 6095 dollars plugin kit DIY
Originally Posted by efusco View Post
Another e-mail when I asked him to send me an update when they had pricing for the Li pack...
I hope to start selling the Li system in August. It will have several features Hymotion does not have like: 1. You keep your spare tire. 2. Three mode operation: stock Prius, Toyota EV (32 mph) and PIS EV (52 mph max). 3. Open source.
Ok, here we are in August ... 1/4 of the way thru the company's statement. Has anyone heard if the Li Pack has materialized yet?
707 area code . . . bay area . . . anyone been there to see one / test drive? That's 16hrs round trip for us ... I'd hate to have to do it myself.
hill is offline
Old 10-27-2008, 10:44 PM   #32
saintjerome
saintjerome's Avatar
Package: #8
I'm having a Plug in Supply added now to my salvaged 2007 Prius with package 8. It will go 15 miles in EV mode up to 52 miles per hour. I'm going to charge it up with a solar array.
saintjerome is offline
Old 10-28-2008, 10:10 AM   #33
DaveinOlyWA
Opps !! I Did it Again!!
DaveinOlyWA's Avatar
Default Re: Plug-in Supply $6,095 plugin kit DIY
wow cool. you need to start another thread, post pics and stats, including mileage, time to charge, electricity rates, length of commute, etc along with personal observations!!
DaveinOlyWA is offline
Old 10-28-2008, 01:00 PM   #34
Flying White Dutchman
yes!!
Old 10-28-2008, 02:00 PM   #35
saintjerome
Package: #8
Here is the latest off of the plug in supply page. This is the kit I am having installed in my salvaged Prius:
Plug-In Supply Inc of Petaluma California is pleased to announce the availability of components and assemblies to build the Prius+ plug-in conversion invented by CalCars to convert a 40+ mpg Prius into a 100+ mpg Prius Plus (plus 1 cent/mile of electricity). With the conversion system installed, a Prius can be driven for the first 10-15 miles on electricity before reverting to standard Prius driving mode.
A PHEV owner plugs in the car overnight to recharge the battery pack. This saves gasoline by substituting cleaner, cheaper, domestic electricity for a portion of the gas that would otherwise be used to propel the vehicle. Electricity from the outlet sells for less than $1 per gas gallon equivalent (GGE).
The Prius+ conversion is the original and most successful non-commercial PHEV conversion for the Toyota Prius car.
Plug-In Supply products allow dealers to complete high-quality PHEV conversions.
The conversion system uses new extended life lead-acid batteries (over 800 cycles), for better battery longevity than was previously available. The combination of longer battery life and lower price improves the affordability of converting a Prius.
The PbA20 PHEV Assembly is a complete, tested, and ready to install pack. It provides access to the spare tire and contains 20 PbA20-12 lead-acid batteries, plus all high voltage components and control electronics in a strong welded steel enclosure. Expect about 10 - 15 miles of EV mode range.
Battery chemistry: Lithium Iron Phosphate (LiFePO4) or Lead Acid (PbA).
Expected battery life: 11+ years for LiFePO4, 2 years for PbA.
System weight: 150 lb for Lithium Iron Phosphate (LiFePO4) and 360 lb for Lead-Acid (PbA).
Battery Pack Mounting Location: under rear cargo deck on top of spare tire. Battery box lifts up on springs to access spare tire.
Capacity: 5kW
Voltage: 256 VDC
Charge time: 4 to 8 hours from any 110 VAC / 15A outlet.
On-board charger mounts under front seats or in cargo area.
The PbA PHEV Assembly is also available without batteries.
Summary of the features of the Plug-In Supply Prius+ PHEV conversion:
Three mode operation, Normal Prius, Enhanced Prius and Electric Vehicle.
Normal Prius is stock performance, PHEV engaged.
Enhanced Prius mode engages auxiliary battery pack to enhance the performance during normal Prius operation.
Electric Vehicle mode means gas engine does not start. To exit this mode car must be brought to a stop, turned off then restarted. Car restarts in normal Prius mode.
Range in EV mode: 10 to 15 miles per charge. Depends on terrain and driving style.
Max speed in EV mode: 52 mph.
The following products are under development for release this year:
PSI Lithium Ion Phosphate Prius+ conversion, featuring the latest batteries from Phoenix Silicon International (PSI). The chassis will provide access to the spare tire and is expected to provide 15 - 20 miles of EV mode operation and last the life of the car.
Plug-In Supply is working closely with CalCars to develop these products to put more plug-ins on the road. Plug-In Supply will donate 5 percent of sales to CalCars.org.
For more information contact:
Telephone (707) 849-2422
Fax (707) 238-1541
saintjerome
Old 10-28-2008, 06:09 PM   #36
miscrms
Plug Envious Member
Very cool! Are you getting this from Steve at Autobeyours? Do you mind sharing what he charges for the kit/install?
Rob
miscrms is offline
new battery outside of warranty (US dollars)? stock Prius Main Forum 6 04-17-2008 05:50 PM
15 thousand dollars and 3 months later... YoDaddyAlex Prius Main Forum 30 03-26-2007 10:32 PM
Someone bought five dollars in gas before I arrived naterprius Fred's House of Pancakes 63 04-26-2006 04:35 PM
FEMA dollars go to the wealthy DaveinOlyWA Fred's House of Pancakes 13 12-25-2005 01:28 PM
New Motorola Razr V3 for under 300 dollars Robert Taylor Audio and Electronics 17 02-24-2005 02:18 AM
