| Prius and Hybrid News This is a discussion on Hybrid speedboat within the Prius and Hybrid News forums, part of the Toyota Prius Forums category; Originally Posted by hampdenwireless Hybrid makes far more sense for sailboats. They can make power while under sail and have ... |
| | #11 | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Quote:
It would be great to get rid of the diesel. We have a fabulous diesel engine, but it's still big, smelly, and noisy, plus it requires a big tank of fuel. Tom | |
| | #12 | |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
So, for your keel boat, it would be easy to build a Li-Ion battery pack shaped to fit in the keel. Since you probably have ballast in there now, there would be no weight penalty. The Tesla requires liquid cooling because those laptop Li-Ion batteries (unlike the LiFePO4 pack in my Xebra) are subject to thermal runaway and must be cooled. But in your sailboat, cooling would be easy as the keel is surrounded by sea water, and if conduction through the hull is inadequate, a small pump could deliver cool sea water to a circulating cooling system without the need for a refrigeration unit like the Tesla requires. Of course, when you are becalmed you have no way to charge the batteries. You'd want to design your BMS to conserve some charge for emergency use during calms. Or maybe a small propane-powered Stirling cycle engine (clean and quiet) as an emergency generator.
__________________ Daniel ---------------------- Primary car: Zap Xebra SD: 100% electric car. 1.9 cents per mile, using electrons generated from water power. (The Prius is my gas guzzler, used when I have to travel farther than 35 miles in a day.) "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck | |
| | #13 |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | I like the idea. I have kicked around thoughts like that for a lot of years. I may build another boat along these lines sometime in the future, when I feel like having another big project. Often times a small genset is used for auxiliary power. They are small, self-contained, and reasonably efficient. It doesn't take much power to move a sailboat. As for a weight penalty, as you point out, we have a lot of ballast. Our boat carries 5,000 lbs of lead. Li-Ion batteries are not as dense as lead, so you would need a lot of them, or perhaps a combination of ballast and batteries, but it is certainly possible. There is a power boat on the market that uses this sort of system for propulsion. It has a large coach roof covered with PV panels, which are alleged to provide enough power to move the boat at cruising speed with only the sun. For night, or higher speed, you kick in the genset. It's too new to know how well it works, but the idea is attractive. Tom
| | #14 |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I would anticipate that lithium batteries would not entirely replace your lead ballast. My point was merely that since you already have so much ballast, unlike an electric car, which pays a weight penalty for the batteries, your sailboat would not. I am extremely skeptical of the solar boat. I believe it takes far less energy to move a car on level ground at moderate speeds, than a boat, considering the enormous drag of the water. And we know that a conventional car has not nearly enough surface area for solar panels to provide more than 1 or 2 percent of the energy it needs. But there are plenty of grandiose claims in the EV world, ranging from dreams to scams. |
| yet another diesel vs. hybrid comparison: Chevy Tahoe Hybrid vs. Mercedes GL320 CDI | cwerdna | Prius and Hybrid News | 4 | 05-06-2008 01:56 PM |
| Hybrid Owners Get Lobby in Washington-Petition Hybrid Incentives | hb06 | Prius and Hybrid News | 1 | 10-26-2006 10:56 AM |
| Top 10 Hybrid States and Top 10 Hybrid Metro Areas in 2005 | Tempus | Prius and Hybrid News | 23 | 05-17-2006 01:28 PM |
| Hybrid Tech to break production hybrid speed rec. | Areometer | Prius and Hybrid News | 1 | 01-14-2006 03:24 PM |
| Thieves Taking Hybrid Logo Off Hybrid Cars | prius04 | Prius and Hybrid News | 6 | 03-29-2005 03:14 PM |
