Go Back   PriusChat Forums > News & Newbies > Prius and Hybrid News
This is a discussion on 10-Minute Electric Car Charging within the Prius and Hybrid News forums, part of the News & Newbies category; I remember using fast charging on my electric RC cards when I was young. My question is, which is more ...
LinkBack (1) Thread Tools
Old 06-28-2008, 01:57 AM   #11
Mormegil
Mormegil's Avatar
Default Re: 10-Minute Electric Car Charging
My question is, which is more energy efficient? Slow or fast charging?
If an ultra capacitor is required for the "dump" - there must be some energy conversion loss there (maybe negligable?).
What about on the battery itself? Does it use more total amps to charge it the same as a slow/trickle charge?
We know it gets hotter, but that's because the charge happens in 10 minutes. But is this waste heat more or less than the total waste heat during a much longer trickle charge?
I would also expect the power to cost more, as it's going to be at a commercial station and often be at peak hours.
Mormegil is offline
Old 06-29-2008, 04:05 AM   #12
drees
In general, charging faster will be less efficient due to resistance - which in turn will raise the temperature of your conductors and raise resistance some more.
But since all batteries lose some amount of charge over time, charging too slow will also be less efficient.
So there is some sweet spot where charging will be most efficient - it will likely be a fairly wide range of currents.
drees is offline
10-minute, charging, electric
LinkBack to this Thread: http://priuschat.com/forums/prius-hybrid-news/49875-10-minute-electric-car-charging.html
hybrid: Blogs, Photos, Videos and more on Technorati This thread Refback 06-27-2008 11:07 PM
60 Acres a Minute DaveinOlyWA Environmental Discussion 5 02-03-2008 05:41 PM
5 minute trips? eberrong Gen II Prius Main Forum 11 07-09-2007 08:19 PM
Buying Soon, Last Minute Questions ESanders2 Gen II Prius Main Forum 9 04-04-2007 09:22 AM
Electric truck with solar charging. burritos Environmental Discussion 1 03-18-2007 04:19 AM
5-Minute Segment With No Bar NoVaSnow Gen II Prius Main Forum 13 05-18-2006 02:19 PM
