Go Back   PriusChat > Toyota Prius Forums > Prius and Hybrid News
Prius and Hybrid News This is a discussion on Plug-in Hybrid Future: Andy Grove get it! within the Prius and Hybrid News forums, part of the Toyota Prius Forums category; Originally Posted by tochatihu For now, the problem is the availability of large rechargeable batteries at acceptable prices. As long ...
andy, future:, grove, hybrid, plug-in
Old 07-14-2008, 09:15 PM   #21
joe1347
joe1347's Avatar
Default Re: Plug-in Hybrid Future: Andy Grove get it!
Originally Posted by tochatihu View Post
For now, the problem is the availability of large rechargeable batteries at acceptable prices. As long as that's the case, more fuel will be saved by 'spreadling them thinly across the fleet'. Which is to say in hybrid vehicles with approximately the battery size of a Prius.
A few PHEVs won't make a difference; will neither help nor hurt the fleet fuel consumption. When the batteries are available, then it will be appropriate to build a large number of PHEVs.
Of course, that's the point of the article. A national effort is required to make the switch to PHEV's.
joe1347 is offline
Old 07-14-2008, 09:39 PM   #22
misslexi
Originally Posted by Rybold View Post
I have always thought that harnessing the ocean's currents is a dependable, always-on source of energy.
Agreed. I've seen sea water eat aluminum and it's alloys for lunch, there are some challenges. And we're kind of setting up shop in someone else's house (fish, whales).
Expect resistance.
misslexi is offline
Old 07-15-2008, 10:08 AM   #23
chogan2
Astute point. But I don't think the differences would necessarily be very large. A hybrid battery allows for more efficient use of gasoline but a PHEV battery allows for substitution of other fuels for gasoline. If the critical shortage is oil, then it's not immediately clear that using a given amount of battery capacity as hybrids would save much more oil.
Here's a numerical example.
For battery size, let me take the Hymotion Prius converion as the template: 5 KWH added to the stock Prius ~1.5KWH battery. But the Prius pack is never fully used. Call it roughly 4:1, PHEV battery size to hybrid battery size. I could believe a larger ratio of both were Li-ion.
For hybrid performance, let me take the Escape, which is the best comparison of an optimized HSD versus straight gas version of the same car. Mileage there is 32 hybrid and (I cheat a bit) 24 straight gas with manual transmission. The gas savings per hybrid amounts to one-fourth of the consumption of one regular ICE Escape.
If the PHEV were used as an EV (ie, electric miles only), the net impact on oil consumption from one PHEV Escape (displacing one ICE Escape, with zero oil use) would be about the same as four Escape hybrids (displacing four ICE Escapes, using three-quarters as much oil each.)
Either way, the net impact of building one PHEV Escape or 4 hybrid Escapes is to reduce oil use by one ICE Escape's worth.
Admittedly I slanted the numbers. But my point is that it may not be too wasteful to put the batteries into PHEVs. If the rate limiting factor is as much consumer acceptance as it is manufacturing capacity, then the more products available, the better.
And, for sure, when Toyota puts a Li-ion battery into the Prius, they ought to let it be charged off the grid, for however many miles it's worth. Just 5 miles of PHEV capacity would cover 12% of US drivers' vehicle miles, based on US DOT data. A 1.5 KWH Li-ion battery ought to give that much range in a Prius.
chogan2 is offline
Old 07-15-2008, 06:40 PM   #24
miscrms
Plug Envious Member
As mentioned before, electric generation capacity is not the problem. Our power plants are sized to meet the maximum instantaneous load demands placed on the system. Even in places where the grid is stretched thin at peak, there is a huge amount of surplus capacity available the rest of the time. To start with, you can probably get by on the fact that most people will tend to charge their cars at night just out of practicality. Eventually you will need a smart charger that knows how much strain there is on the grid and acts accordingly (maybe even giving power back to prevent brown/black outs as in the V2G proposals). Given those requirements there have already been studies to show that most if not all of our light duty vehicular transport could be transitioned to electric without building more power plants.
As far as batteries, I think the answer is simple. Federalize Chevron/Texaco's large scale vehicular NimH patents, and setup government funded large volume production facilities. Li-ion is a great technology, and will probably be one of the keys to eventual long range PHEVs and BEVs, but in the mean time they are overkill for first gen PHEVs and are slowing implementation and increasing cost.
For example, here are the pack weights and volumes for a 5kWh pack similar to the Hymotion:
Ovonics/Cobasys 9500 NimH (late 90s, large scale NimH used in EV1 & others):
1.234 cu ft, 194.4 lbs
http://www.cobasys.com/pdf/transport...00Brochure.pdf
A123 Li-ion 18650 cells (as used in Tesla)
0.821 cu ft, 118.4 lbs
Product Information - Batteries Servos & Accessories for Electric Flight available at BRCHobbies.com
Its a whole different story when you go to 50kWh BEV packs, but for the small packs needed for first gen PHEVs, I just don't see that there is any need for Li-ion. Is 76 pounds and 0.41 cu ft really going to make or brake the design? In the mean time the Li-ion are much more complicated to deal with, less mature, and much more expensive.
Putting a solar array on your roof, you could drive a Prius sized EV 15,000 miles per year for 1.7-2.1c/mile and that rate is fixed for 20-25 years. Compare that to 8.7c/mile for a Prius at $4/gallon, or 18.2c/mile for an average 22mpg car. Compared to putting gas in a Prius, and assuming gas only stays at $4 per gallon and assuming your solar only lasts 20 years the annualized ROI for the upfront cost of the solar is 10.5%! With gas going up 5% per year, and the solar lasting 25 years its 24.8%!.
Rob
'05 Prius, Driftwood Pearl, Package #4 + leather, Salvage/Rebuild w/ plug envy
miscrms is offline
Old 07-15-2008, 07:54 PM   #25
chogan2
NiMH won't last long enough as a PHEV, if the batteries are run through a full charge/discharge cycle every day. Cobasys claims "more than 1000" 80% charge discharge cycles before failure. That would be 3 years of daily PHEV use. NiMH will work for full EV batteries, where you'll seldom run the battery down to full discharge in a day, but they aren't durable enough for PHEV use. I think the next-generation Li-ion (or something equally durable) is necessary for PHEV.
chogan2 is offline
Old 07-15-2008, 09:24 PM   #26
joe1347
joe1347's Avatar
Rob
Hmmm. A 5 Kw-Hr battery in a short-range plug-in hybrid will get you more than 80 mpg for the typical commuter. So what does the battery for a 5Kw-Hr PHEV cost? I couldn't find a price for the 'favored' A123Systems LiFe3PO4 battery, but 5 Kw-Hr's worth of generic Lithium batteries runs about $3500 (Newark Electronics) and weighs less than 100 lbs. Throw in some power conditioning circuitry and assembly costs and a $5000 per unit cost seems reasonable (no profit)
Now, how about some more fun with math What if the US Govenment changes the CAFE standard to 80mpg for all new cars. What's the additional cost to 'society' of this huge government mandate??? From the calculations above and assuming no economies of scale kick in as lithium battery manufacturing explodes, 100 million cars that now get 80+mpg will cost an additional $500 billion dollars over about 12 years since ~8 million cars are sold in the US per year. This works out to less than $50 billion dollars per year of additional variable cost to start converting the US fleet to 80+mpg. As for how to pay for it, the US uses about 140 billion gallons of gasoline per year. A 30 cents per gallon tax would do it, which doesn't seem too high of a price to pay to lessen our dependence on imported oil, reduce pollution (smog), cut greenhouse emissions, and even better start paying the equivalent of less than $1 a gallon by 'filling up' at home using your own electrical outlet.
So what am I missing? Why didn't Bush push for PHEV's in his speech today? Seems to make more sense than drilling.
"Facts are meaningless. You could use facts to prove anything that's even remotely true." Homer Simpson
joe1347 is offline
Old 07-16-2008, 12:14 AM   #27
drees
All rechargeable batteries have the exact same problem, whether it's NiCd, NiMH or LiIon.
The solution is simple - increase the size of the battery and don't charge/discharge the cells as much, just like they do with every hybrid's batteries today and they are doing with the Tesla, they are planning to do on the Volt, etc.
drees is offline
LA Prius Meet-The Grove hb06 CA - Los Angeles 1 10-05-2007 11:01 PM
LA Times article on future Plug-in Hybrids bankshot Prius and Hybrid News 3 07-20-2007 10:10 PM
Plug-in Prius car's future? Tideland Prius Prius and Hybrid News 2 10-04-2006 06:24 PM
Future Plug-In Pedestal bee13 Fuel Economy 4 07-11-2006 12:18 AM
Toyota Plans for Future: Includes Prius Plug Ins! mkaliski Prius and Hybrid News 2 04-23-2006 04:11 PM
