| Prius and Hybrid News This is a discussion on Toyota making progress on plug-in car within the Prius and Hybrid News forums, part of the Toyota Prius Forums category; Originally Posted by hill Hugh? Sooo, a half dozen years ago, the RAV-4EV (with its horrible drag coefficiency) had over ... |
| making, plug-in, progress, toyota |
| | #31 | |
| Member Join Date: May 2008
My Car: 2008 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
I am with the other guy looking at 2012. My next car will be a plug in or an all electric. Hopefully something like the Think Ox. | |
| | #33 |
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Toyota would be foolish beyond belief to eliminate the single biggest operational asset designed into the car. It wasn't a quirk, it was genius. Last edited by 9G-man; 09-02-2008 at 10:12 PM. |
| | #34 | |
I'll pulse and glide on a PHEV grid charge and go way further than those who don't. Exploiting kinetic energy is way more efficient that any electric motor and the only time regen is efficient is if you have to come to a stop. Which of course at some point we must. So it's there to capture that energy. Otherwise regen is nothing more than friction slowing your progress. Last edited by 9G-man; 09-02-2008 at 10:24 PM. | |
| | #35 | ||
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Here's another way to look at it: To maintain a constant average speed on flat ground you only need to compensate for the rolling friction and the wind resistance of the car. This is a fairly small amount of power. A conventional car accomplishes this by running the ICE at low power, where it is terribly inefficient. The Prius, because it's able to easily start and stop the ICE, allows you to give the car a pulse, operating the ICE in a more efficient (higher power output) range, and then shut it off while the car coasts, gradually losing speed due to friction. You are giving the car a larger impetus than it needs to maintain speed, and then letting friction slow it down, and then repeating. This works because the ICE is so much more efficient at the higher power output! But an electric motor is just as efficient at low output as it is at high output, and furthermore, it is much more efficient than an ICE. Therefore an EV can maintain speed by using the actual amount of power needed. There is no gain in efficiency by giving it a large pulse of power and then coasting. Either way you have to overcome friction and wind resistance to keep moving. With an EV there is no efficiency advantage in breaking down the needed energy into brief pulses. You are correct about regen. But that has no bearing on the question of P&G.
__________________ Daniel ---------------------- Primary car: Zap Xebra SD: 100% electric car. 1.9 cents per mile, using electrons generated from water power. (The Prius is my gas guzzler, used when I have to travel farther than 35 miles in a day.) "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck | ||
| | #36 | |
I'm talking about the everyday application where the pulse can be at any rate, for any duration that would be appropriate for the situation or desire of the driver. The glide is what's most important. I'm talking about exploiting hills, and necessary speed variations, planning, using the kinetic energy of a glide, to move forward and even maintain speed in the process. That energy free form of travel will always exceed the efficientcy of any electric motor. That's why I'll go further on a grid charge than those who don't exploit a glide. And you gotta pulse in order to glide. Surely Toyota will be smart not to eliminate that characteristic in the programming of their PHEV. Last edited by 9G-man; 09-03-2008 at 04:18 PM. | |
| | #37 | |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Quote:
Rob | |
| LinkBack to this Thread: http://priuschat.com/forums/prius-hybrid-news/52283-toyota-making-progress-plug-in-car.html | ||||
| Prius: Blogs, Photos, Videos and more on Technorati | This thread | Refback | 08-16-2008 03:27 PM | |
| Toyota cuts 10% of workforce at Lexus-making unit | cwerdna | Other Cars | 0 | 08-06-2008 01:28 AM |
| Toyota Making Money in downturn time | C.RICKEY HIROSE | Prius and Hybrid News | 0 | 05-09-2008 09:39 PM |
| Fancy making your own DIY plug-in Prius? | clett | Prius Modifications | 0 | 03-02-2006 08:48 AM |
| Toyota Prius (Will Toyota start making them in China?) | jbiond2005 | Prius Main Forum | 6 | 08-11-2005 11:58 AM |
| Toyota Eco-Plastic.. Toyota making car parts from vegetables | prius04 | Prius Main Forum | 2 | 01-14-2005 04:22 PM |
