Go Back   PriusChat > Toyota Prius Forums > Prius and Hybrid News
Prius and Hybrid News This is a discussion on Zenn press release confirms EEStor announcement within the Prius and Hybrid News forums, part of the Toyota Prius Forums category; Originally Posted by nyty-nyt The ZENN is a Microcar MC-2 with the electric system swapped into it to replace the ...
confirmation, eestor, zenn
LinkBack (1) Thread Tools
Old 09-20-2008, 06:38 AM   #11
Flying White Dutchman
Friends: 5
Default Re: Zenn press release confirms EEStor announcement
Originally Posted by nyty-nyt View Post
The ZENN is a Microcar MC-2 with the electric system swapped into it to replace the european diesel ICE.
Here are some crash tests on the Microcar from youtube. Presumably the ZENN would behave in a similar fashion.
No wonder they are limited to 25 mph.
petrol not diesel
Flying White Dutchman is online now
Old 09-20-2008, 08:41 AM   #12
DaveinOlyWA
Opps !! I Did it Again!!
DaveinOlyWA's Avatar
Friends: 6
Originally Posted by Devil's Advocate View Post
Why not use a combination Ultra Cap and battery. The UC can recharge in 2 minutes at a charging station then bleed the charge into the battery over time. Unless of course the fast discharge aspects of th UC have been resolved.
very easy question
battery: 5 times more expensive, 3 times heavier... the 54 KWH ultracap already weighs 300 lbs... that is enough...two ultracaps could power even a full sized pickup truck better than 30,000 of the best batteries you could buy...
but in actuality, the question should be asked of Toyota, and the answer is that is does make sense and here is there example using hybrid technology along with batteries AND ultracaps
The Dark Horse in the Race to Power Hybrid Cars: Scientific American
but the eestor announcement is old news. i posted this previously. since this announcement, both eestor and Zenn have gone into information lockdown mode. there has been nothing new at all. this announcement was basically due to an independent lab verifying that eestor's process to design a particle of a chemical that would be used to create the ultracap can be done on a large scale.
the ultracap HAS BEEN BUILT... but up to now only as a smaller capacity prototype. as we all know, having a prototype means nothing unless you can mass produce it cheaply and reliably. (remember the diesel electric hybrids built by the Big 3 in 2000???...)
for the cap to work safely in the larger form factor, the particle must be of a uniform shape and size on a nearly nanometer scale. this is necessary to increase the breakdown voltage (goal is like 600 v which is more than 400% safety margin) in order to insure 1)longevity and 2)a relatively uneventful failure...iow... no fireworks should something go wrong. with its nanometer scale, its supposed to work something like a billion tiny capacitors instead of one very large one. so as you can imagine, the preciseness of the manufacturing process rivals a hard drive or microchip factory setting.
**OFF TOPIC WARNING**
there is a new technology that is just beginning the scientific stage... it is still DECADES away, but it involves nanometer antennas... now as we all know, antennas absorb radio frequency waves and converts then into another form of energy. they have a efficiency rating that is very high,(mid to upper 90's %) especially when compared to other devices that convert energy ala solar photovotaics (the best currently go maybe 20-25% efficient...the "affordable" ones run around 10%)
the problem is that the antenna has to follow the "quarter wave rectification" rule that states the length of the antenna has to be ¼ the length of the wave it is converting....
well, visible light is very very short, which would require an antenna that is by all respect, invisible to the naked eye. well, the reason why scientists are pursuing this is that solar is wonderful, but only available during the day... BUT
1) what if the infra-red radiation could be captured, converted to electricity and then used to charge your EV?? EVEN AT NIGHT?? get the picture?
this reduces ambient temperature of the Earth and gives us another source of energy. but like i said, still decades away...but just gives an idea of what nano-scale technology can do...
My 2006: Last tank 341.6 miles @44.7 pump (43.3 computer) 3.81 cpm
winter mpg 50.44 summer mpg 54.71
lifetime: 34,290.1 miles 52.55 mpg pump (53.78 mpg computer) 5.67 cpm
My 2007 Zenn Driven 5945 miles, 2.01 cpm/ 105 mpg (at $2.05/gal), 4.04 miles/ Kwh
Savings over my Prius $302.66 The Corolla...573.26
The REAL SAVINGS from not driving Corolla 693.39 +Prius= 996.05 (excludes maintenance costs...would be unfair to ICE vehicles)
DaveinOlyWA is offline
Old 09-20-2008, 04:34 PM   #13
Fibb222
Fibb222's Avatar
Thanks Dave, very cool post.
Fibb222 is online now
Old 09-23-2008, 10:12 AM   #14
daniel
Cat Lovers Against the Bomb
daniel's Avatar
the ultracap HAS BEEN BUILT... but up to now only as a smaller capacity prototype. [...]
This makes no sense, Dave. Capacitors are measured according to their capacitance, and prefixes such as "super" or "ultra" refer to the category of amount of capacitance. An ultra-capacitor is one with a really huge capacitance. If it's "smaller" it's not "ultra."
EEStor believes that a really really pure form of their dielectric will achieve the level of capacitance that would qualify it for the term "ultra," and with that, be big enough to make an EV running on caps possible. They are making progress towards the level of purity they think they need. But until they do achieve the purity, they cannot build an ultra-cap to test. This is why I am suspicious of them: They are advertising a release date for the car when they have not yet demonstrated that their theory is correct. They have not demonstrated that the dielectric will provide the capacitance they need.
**OFF TOPIC WARNING** there is a new technology that is just beginning the scientific stage... it is still DECADES away, but it involves nanometer antennas... now as we all know, antennas absorb radio frequency waves and converts then into another form of energy. they have a efficiency rating that is very high,(mid to upper 90's %) especially when compared to other devices that convert energy ala solar photovotaics (the best currently go maybe 20-25% efficient...the "affordable" ones run around 10%)
The amount of solar radiation that hits the Earth's surface during the day is immense. I suspect that the amount of infrared radiation bouncing around at night in miniscule.
Additionally, though I am getting into an area I do not understand well, so the following is a suspicion rather than hard fact:
Antennas work because electrons free to move around in a metal will move perpendicular to an electromagnetic field. Thus in a wire exposed to radio waves there will be an alternating electric potential at the ends of the wire. I suspect that this becomes progressively less efficient as the wavelength approaches the size of the atoms in the antenna wire.
I know that the problems of working with VHF are much greater than the problems of working with HF, and that UHF is harder still, and I believe that in applications where visible or near-visible light is used for communications (fiber-optic cable) the detector is not an antenna, but rather a semiconductor analogous to a PV cell.
I conclude that at such wavelengths, antennas are not the most efficient way to go after all. PV cells are.
And you could build PV cells that would capture IR light. maybe current ones already do. The problem is that in the IR range, there just is not very much energy out there. Oh, and of course, each photon of IR has much less energy than one of visible light: longer wavelength = lower frequency = less energy per photon.
Nano-antennas for utilizing IR light sounds to me like a scam.
Meanwhile, there's enough sunlight out there to provide all the power we need. All we have to do is break the political stranglehold that Big Oil has on our country and our world.
We need a technological breakthrough in energy storage. We already have the technology to capture energy from the sun.
Daniel
Primary car: Zap Xebra SD: 100% electric car. 1.9 cents per mile, using electrons generated from water power. (The Prius is my gas guzzler, used when I have to travel farther than 35 miles in a day.)
-- Emma Goldman
-- Otto von Bismarck
daniel is offline
Old 09-30-2008, 09:23 AM   #15
clett
A little more EESTOR news here (they've signed a new licensing deal):
EVWORLD NEWSWIRE: Light Electric Vehicles Signs Exclusive Agreement with EEStor
Highlight of the press-release is:
"EEStor EESUs are expected to provide over 450 watt hours per kilogram and over 700 watt hours per liter, charge in minutes, and, for all practical vehicular purposes, last indefinitely."
If that was true, a 50 kg EESU (ie the same weight and size as the existing Prius NiMH battery), would provide 22.5 kWh of energy, or enough for 100 miles EV range.
I'm reserving judgement until a third party actually gets their hands on a working unit!
clett is offline
Old 09-30-2008, 11:47 AM   #16
DaveinOlyWA
Friends: 6
that would be about right... actually test system is nearly 300 lbs 54 kwh...so weight about the same as most EV's (mines has 6 batts at 81 lbs each or nearly 500 lbs)
LinkBack to this Thread: http://priuschat.com/forums/prius-hybrid-news/52480-zenn-press-release-confirms-eestor-announcement.html
Pending E-mail This thread Refback 08-20-2008 07:01 PM
EEStor press release - level of purity of materials certified by third party Wiyosaya Prius and Hybrid News 4 07-31-2008 05:16 PM
ZENN Motor Company Details Plans for Highway Capable ZENN Powered by EEStor! DaveinOlyWA Other Cars 10 06-02-2008 09:10 AM
Make Your Own Chevy Volt Press Release Stev0 Fred's House of Pancakes 50 01-21-2008 09:24 PM
Pentagon Confirms It Sought To Build A 'Gay Bomb' larkinmj Fred's House of Pancakes 23 06-13-2007 11:40 PM
2007 Toyota Prius Press Release (8/17/06) Vegemann Prius Main Forum 1 08-19-2006 06:32 PM
