| This is a discussion on 2010 Prius Preview: A Hypermiler's perspective within the Prius and Hybrid News forums, part of the News & Newbies category; Originally Posted by MSantos Yet another great piece. Thank you. Thanks! Originally Posted by bwilson4web I enjoyed the write-up especially ... |
| | #11 | ||
| MPG Centurion Join Date: Sep 2005 Location: Houston, Texas
My Car: 2007 Prius Model: Package: #3 Thanks: 12
Friends: 20 | Thanks! Quote:
As for the route, here it is... I'll google map it in a bit perhaps. Start: 7000 North Resort Drive Tucson, AZ, 85750 00.1mi - Turn Left on Kolb. 02.7mi - Turn Right onto Sunrise. 06.3mi - Turn Left on Campbell. 16.7mi - Take I-10 East towards El-Paso. 21.3mi - Take Valencia Exit. 21.6mi - Turn Left on Valencia. 24.6mi - Turn Left on Kolb. 32.3mi - Turn Right on Tanque Verde. 32.9mi - Turn Left on Sabino Canyon. 35.0mi - Take Kolb at fork. 38.4mi - Turn into Hotel. Here's an elevation map of the route. Over 800ft drop from the high to the low!: ![]() Here's the Google Map of the Route. 11011011
__________________ ![]() ![]() Best commute = 14.3mi @ 114 MPG (sg2) Best (non-trivial) tank = 1101mi @ 91.2 MPG (fcd) MPG Centurion-Hybridfest 2007-Prius II-26mi @ 106 MPG (sg2) Dan <11011011> @ CleanMPG.com Last edited by Dan.; 04-04-2009 at 12:01 AM. | ||
| | #12 |
Friends: 37 | Great review Dan, from a perspective perhaps few of us really appreciate, but greatly need. I'm not sure the MPG difference is significant beyond the proof in the pudding that you can approach and or exceed the '09 with minimal practice...letting us know that we should see some huge numbers in the first few months after the '10 hits the streets. |
| | #13 | ||
My Car: 2010 Prius Model: III Package: #1 Thanks: 147
Friends: 20 | Quote:
The cooled exhaust gas may have come into play on the final climb and this remains an area that I have a lot of curiosity. Do you remember your speed on the final climb? The reason I ask is some of my hill climb tests show there are optimum climb speeds on either side of a worst climb speed: At speeds above 70 mph, the NHW11 Prius begins to draw significant power from the traction battery. This extra energy more than compensates for the engine inefficiency at high power settings. Of course the hill has to end before the battery is exhausted. If the ZVW30 cooled exhaust keeps the brake specific fuel consumption in an optimum range even at full throttle, speeding up a 6% grade may be the best way to reach the top with the lowest apparent fuel consumption. The key is accelerating on a flat or descending area to the maximum, safe climb speed and then holding a constant speed when blasting up the hill. Speeding up a hill sounds counter intuitive but the data shows otherwise. NOTE: 525 ft. hills are not that high. Worse, repeated cycles will 'charge heat' the traction batteries. This is really a 'one time' technique and not recommended for hill country.Untested, one might be able to time backing off to let the vehicle momentum crest the hill at final cruise speed. This is a tricky proposition and requires a table to do it right. Still, it is an interesting, future experiment. Bob Wilson | ||
| | #14 | |
The beauty of the EHR combined with the forgiving firmware, combined with the 4 drive modes means that fewer people should find themselves way off the bell curve as far as MPG goes. If your MPG is low, just do a bit more granny driving and put it in ECO mode instead of PWR mode. They even have an "ECO" indicator that drivers can use to train themselves in proper acceleration. My final climb was running at about 1600-1700 rpm, steadily accelerating from 45kph up to about 57kph, then I'd come off the throttle till the engine cut off and decelerate back down to 35-45kph. I'd try to time the "glides" (decelerations) around flats in the terrain. Back to the OP, one thing I didn't mention is the fact that at the bottom of the first big hill was a light. Caught it red on both runs. So almost none of the speed on that decent was used in the rest of the course. I did get a good charge on the pack though. | |
| | #15 |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 216
Friends: 18 | I believe Tucson may have ethanol gas like Phoenix metro. Don't think we see 85 octane here though - only in Colorado. |
| 2010, hypermiler, perspective, preview, prius |
| (National Post) Preview: 2010 Toyota Prius | Tideland Prius | Prius and Hybrid News | 0 | 03-25-2009 01:11 AM |
| 2010 Prius Preview, L.A. WOW it was FUN!! | KK6PD | Gen II Prius Main Forum | 62 | 03-07-2009 11:17 AM |
| 2010 Toyota Prius Preview w/ Video | Tideland Prius | Prius and Hybrid News | 3 | 03-03-2009 08:03 PM |
| 2010 Prius Audio System PReview | Doc Willie | Gen II Prius Audio and Electronics | 25 | 01-19-2009 10:39 PM |
| 2010 Prius Audio System PReview | Doc Willie | Gen III 2010 Prius Main Forum | 0 | 01-13-2009 07:33 PM |
