| This is a discussion on 2010 Toyota Prius Maintenance Costs within the Prius and Hybrid News forums, part of the News & Newbies category; interesting article: 2010 Toyota Prius Maintenance Cost Varies the 2010s claim less maintenance: no belts, so no timing belt change ... |
| Junior Member Join Date: Apr 2009 Location: Philadelphia, PA
My Car: 2009 Prius Model: Package: N/A Thanks: 8
Friends: 0 | interesting article: 2010 Toyota Prius Maintenance Cost Varies the 2010s claim less maintenance: no belts, so no timing belt change needed fewer oil changes 8 yr warranty |
Friends: 13 | Mostly same rehash of the hybrid battery woes. Only difference is the new electric engine water pump so now no belts to worry about. Wayne |
| Senior Member Join Date: Dec 2008 Location: Monterey
My Car: 2008 Prius Model: Package: #2 Thanks: 7
Friends: 1 | |
My Car: 2001 Prius Model: Package: Pioneer #1 Thanks: 2
Friends: 15 | The SOC limits on the big battery are quite accurate in the article. This is a major accomplishment, as the media has taken years to learn this. The rest of it is quite fluffly. Valve-driving belts have been (dare we say immortal?) chains on Prius since the beginning. Loss of the water-pump belt may reduce maint, or not. Depends on whether Toyota is using a better electric motor there than they did on the inverter side for years Engine coolant thermostat also goes away in 2010. Not that many of those have been replaced in Prius, but the new design is 'elegant' and we've certainly been asking for it for years.Engine oil change interval remains 5k miles (US spec). The coolant recirc is gone, and that will reduce maint if the exhaust heat transfer system (that effectively replaced it) proves reliable. We probably expect the new transaxle design to go forever (or near there) but if I had one I'd still change the transaxle fluid at 60k miles. The NiMH battery got a lot better in 2004 and has remained the same design since AFAIK. You still have to change the brake fluid before it gets to 2% water, or the resulting corrosion will make an expensive repair. ^ that's my 2010 maintenance outlook, and no doubt it would make a poor media-style story.
My Car: 2010 Prius Model: III Package: #1 Thanks: 561
Friends: 27 | Quote:
Bob Wilson | |
| Prius Owner since 2008 Join Date: Aug 2008 Location: Ilirska Bistrica, Slovenia
My Car: 2008 Prius Model: N/A Package: Sol Thanks: 3
Friends: 1 | Quote:
Prius at least has an electric braking, but it is limited in its capacity, so you can still get killed when your hydraulic brakes fail. And they usually fail under extreme conditions when electric braking is not enough. So it is recommended to change brake fluid as recommended. Safety first! | |
| Senior Member Join Date: Sep 2005 Location: Outer Banks of NC.. Work in SE Virginia
My Car: 2005 Prius Model: Package: #4 Thanks: 74
Friends: 3 | Quote:
But there is no recommendation on changing the brake fluid AFAIK is there? I've not seen any in the Maintenance Manual. | |
| 2010, costs, maintenance, prius, toyota |
| Problems with 2001 prius or prius in general and maintenance costs? need help ASAP | pria | Gen II Prius Main Forum | 4 | 05-02-2009 09:09 PM |
| Routine maintenance costs | moxiequz | Gen II Prius Main Forum | 4 | 03-09-2007 12:57 AM |
| any reports studies on maintenance/battery costs | zmre2b | Gen II Prius Main Forum | 2 | 01-12-2006 03:00 PM |
| Maintenance costs | Considering | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 06-03-2005 12:37 AM |
| maintenance costs | etack | Gen II Prius Main Forum | 17 | 03-19-2005 12:02 AM |
