| This is a discussion on Toyota's runaway-car worries may not stop at floor mats-LA TIMES within the Prius and Hybrid News forums, part of the News & Newbies category; Originally Posted by Rybold I hope the CHP officers boycott Toyota. Why do I say such harsh words? Because SAFETY ... |
| | #221 | |
My Car: 2008 Prius Model: Package: #2 Thanks: 125
Cripes, when will this absolute nonsense end??? | |
| | #222 |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 128
Friends: 33 | No danger of accidentally locking the steering on a Prius, there is no steering lock. What about that Corolla? When my Prius glides, the engine is off but all the ancillaries still work, what about the Corolla? My choice, move to neutral, maintain power steering and brakes. Not that I have ever or will ever need this. |
| | #223 | |
My Car: 2010 Prius Model: III Package: #1 Thanks: 148
Friends: 20 | Quote:
![]() This is a plot of four runs, GPS recorded data, of high speed, pulse and glide versus the equivalent, cruise control speed. The glide was effected by holding "N" for ~1 second. The pulse happened by shifting into "D" and hitting cruise control resume. You have to hold it in "N" for one second and shifting into "D" works every time with my 2010 Prius. Now if you press and hold "Power" for 3 seconds, the car will shutdown and you will have to come to a complete stop to start it again. I do not recommend using "Power" unless "Neutral" fails ... so far, "Neutral" works every time. Bob Wilson | |
| The Following User Says Thank You to bwilson4web For This Useful Post: | Rybold (11-08-2009) |
| | #224 | |||||||||
| globally warmed member Join Date: May 2008 Location: Southern California
My Car: Other Non-Hybrid Model: Package: N/A Thanks: 96
Friends: 3 | I went and test drove the 2010 Prius today and it shifted between drive and neutral, no problem. I don't get it. When I test drove the 2010 Prius about a month ago, it would not shift back into drive unless the car was at zero mph. Two different Toyota dealers, two different Priuses, and two different results. Quote:
![]() . And here's the money question: You are driving over a patch of ice or very slick road and want as little resistance as possible. In a traditional car, you would either disengage the clutch or shift into neutral. Will "glide" on the Prius offer as little resistance as neutral? (from an intuitive standpoint; not a "I hooked up twenty sensors and computers" standpoint) This actually brings up another question: In my Corolla, I often shift into neutral before going down a steep grade or braking in the rain. The reason for this is that the Corolla transmission, with only four gears and wide gear ratios, the car jerks when downshifting downhill. As a precaution, to prevent the jerk (and potential loss of traction), I disengage the transmission before it has a chance to create a problem. If I am correct, the Prius does not have a transmission. The engine is directly coupled to the drive shaft and a powerful motor assists the engine at low speeds. But even then, does regen ever create a problem while braking downhill ? Quote:
(responding to the graph, something that we discussed in another thread, was that at 52.5mph, wind resistance is significant enough that constant velocity is more efficient (due to greater wind resistance (F=-kx^2) while pulsing above 52.5mph); however while coasting from 30mph to 0mph, wind resistance is low enough that pulse and glide prevails (due to the fact that you can glide for much longer due to minimal wind resistance causing the vehicle to decelerate compared to the rate of deceleration at freeway speeds). And yes, I know very well that everyone here already knows this. I just felt like typing it so I can feel special. . Last edited by Rybold; 11-08-2009 at 02:48 AM. | |||||||||
| | #225 |
| Shuttlecraft Commander Join Date: Jun 2007 Location: Out there, somewhere
Friends: 11 | LA Times follow-up: the plot thickens. |
| The Following User Says Thank You to Doc Willie For This Useful Post: | bwilson4web (11-08-2009) |
| | #226 | ||||
Friends: 10 | Quote:
As for the Prius, feeling a difference between drive and neutral all depends on the load in drive. In neutral there is no load, other than drag and parasitic losses. In drive, if you feather the gas pedal to avoid acceleration and regenerative braking, it feel exactly as it does in neutral. Quote:
__________________ Black 2006 package #7 Northern Michigan | ||||
| The Following User Says Thank You to qbee42 For This Useful Post: | Rybold (11-09-2009) |
| | #227 |
| ΜΟΛΩΝ ΛΑΒΕ Join Date: Apr 2008 Location: Los Angeles
My Car: 2008 Prius Model: N/A Package: #6 Touring Thanks: 32
Friends: 6 | * Jean Bookout awoke in an Oklahoma hospital a month after a crash in her 2005 Camry. As for its position that brakes can always overcome a vehicle's engine, the safety agency and Toyota now acknowledge that a braking system cannot always counter a wide-open throttle, as is the case in sudden acceleration. It would be great if one of these media outlets could solicit an expert opinion to suggest what a driver should actually do in the event of one of these rare and inexplicable episodes the idea that someone would sit in their car doing nothing but stand on the brakes as the car uncontrollably accelerated is mind boggling i can understand that there may not be enough time and input for someone to realize that by mashing on the brakes they are actually flooring the accelerator but sweet jesus, can't the LA Times at least put in a blurb that says SHIFT TO NEUTRAL or are they worried about liability? |
| | #228 | ||
| Senior Member Join Date: Feb 2009 Location: Western Washington
My Car: 2010 Prius Model: II Package: No Package Thanks: 23
Friends: 0 | Qbee already answered most of the questions directed to me, but here is a bit more. See also the Transmission Question thread for more info about what happens in Neutral. Quote:
On your Corolla, much of the in-gear drag is engine compression braking, also known as pumping loss. When the engine is idling, the pistons pull air past the nearly closed throttle plate, creating a strong vacuum. This process consumes a lot of power, causing a lot of drag, and is an inherent loss mechanism in traditional (Otto cycle) gas engines. The loss is also proportional to engine RPM and displacement, which is why bigger engines are bigger fuel hogs. The Prius uses an Atkinson cycle, which effectively means that its variable intake valve timing produces a variable displacement. When 'Idling', its valves are set for minimum displacement, and the transmission lets it spin at minimum speed (0 rpm when rolling at 0-45 mph, 992 rpm when rolling 46+ mph). Both factors give it a big advantage over your Corolla. Quote:
| The Following User Says Thank You to fuzzy1 For This Useful Post: | Rybold (11-09-2009) |
| | #229 | ||||
This statement flabbergasted me. I must be getting really old. How few minutes, besides 'not enough', does Driver Education take these days? | ||||
| | #230 | |
| Senior Member Join Date: Sep 2005 Location: Outer Banks of NC.. Work in SE Virginia
My Car: 2005 Prius Model: Package: #4 Thanks: 13
Friends: 2 | Quote:
There is nothing new here. The prior incidents were investigated by the NHTSA going back to 2002 as the article said. The article quotes the NHTSA stating that 'no evidence was found....' That's why they closed the cases. The other key point is that the ones who are paying for these crashes, deaths, injuries and damages also are absolutely silent on the matter. The insurance companies have not issued one word on any of these issues. It's the insurance companies and their pit bull the IIHS that would have a vested interest in making these accidents disappear if there was a technology issue causing it. The IIHS has never been hesitant to get on GMA or the Today Show and promote one safer vehicle or technology over another. If there was such a problem and there was a solution to such problem the IIHS would be duty-bound on behalf of its pricipals to broadcast both. Thus since 2002 and over 20 million vehicles the 'reports' of alleged unintended acceleration are all unsubstantiated or if true the cause is unknown. All of them. This is the key fact IMO.
__________________ ![]() 2005 Prius II Seaside AM PokerPrius 2.1 GPC @ 133,000 miles & counting Bob Fogarty Sr. Hybrid Specialist Last edited by DeadPhish; 11-08-2009 at 06:04 PM. | |
| The Following User Says Thank You to DeadPhish For This Useful Post: | Rybold (11-09-2009) |
| floor, matsla, runawaycar, stop, times, toyota, worries |
LinkBack to this Thread: http://priuschat.com/forums/prius-hybrid-news/70822-toyotas-runaway-car-worries-may-not-stop-floor-mats-la-times.html | ||||
| Gen III 2010 Prius Main Forum - PriusChat Forums | This thread | Refback | 10-18-2009 10:53 AM | |
| Floor mats | Dillona | Gen III 2010 Prius Accessories and Modifications | 10 | 08-04-2009 11:24 AM |
| Floor Mats | gkaye777 | Gen II Prius Main Forum | 1 | 08-06-2005 01:40 PM |
| Floor Mats | terkar | Gen II Prius Main Forum | 2 | 05-09-2004 06:03 PM |
| Floor mats | jsorger | Gen II Prius Main Forum | 12 | 03-30-2004 10:05 AM |
