| Prius Main Forum This is a discussion on Fuel Gauge within the Prius Main Forum forums, part of the Toyota Prius Forums category; Possibly a bit off topic, but it seems that years ago they were selling a small half gallon or so ... |
| | #71 | |
| Senior Member Join Date: Sep 2005 Location: Central Texas
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Humm.. something I have heard no one ever mention? I"m not sure how much gas weighs per gallon.. but water is 8.3lbs per gallon. Adding an additional 10 gallon tank would add approx 80 lbs to the rig..... like the trucks to... you would have a switch to change over when the other one runs dry..... this would allow over 1000 miles of driving between fillups... really nice if you find that really low priced station!.. I don't know if there would be issues with vapor etc... all else fails you could tap into the existing system and use without a switch?
__________________ ________________________ 2006 Barcelona Red Prius Pkg #8 with Bisque leather.... Yea Baby, Yea! "The Hot Tamale" And my "other" car...... 2006 Silver Pine Mica Pkg #8 with Bisque leather.... "The Mint Julip" Mods so far: 1. Coastal EV switch "love it" 2. BT stiffening Plate 3. 20" PIAA Silicone rear wiper 4. Zaino "the works" 5. Heat Shield "from Canvas Works" 6. Magnetic Oil plugs - Yes they work and you want them! P.S. How do you know what you've missed? | |
| | #72 | ||
| Prius Hacker Join Date: Mar 2005 Location: Seattle, WA
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Warning... I am an engineer! Quote:
I now have two data pages on my spreadsheet. One calculates the "normal" way where I fill in wach row as I put gas in. (Page "Data" on my spreadsheet.) The scond one calculates how far I went on this tank based on how much gas I put in last time. ("Shifted Data"). I fill in everything as normal, except I put today's odometer reading on the previous tank. The gas I put in today has no miles on it yet. Calculating this way moves the variability away from how much gas I put in, and moves it to how much I had left when I filled. 90% of the time, I fill at the beginning of the trip on my way home from work, when the tank is at one pip. On the "tank miles per allon filled" graph, you can see that the shifted data trendline (the linear one) has a formula of 49MPG(Filled) - 28 Miles. To me this means that I average 49MPG, except I take a 28 mile hit to the tank because of warm-up. Percentage wise, this works out weel with the % of my commute spent warming up (about 8 minutes out of 60). Notice that this trendline is close to the green line, which is just a linear plot of my current MPG average (unshifted, but shifted and unshifted MPG are almost the same).I've also drawn in the 50MPG "target" line. On the non-shifted trendline, it indicates that no matter how much gas I put in, I get 270 miles free, plus 17 miles for every gallon filled. This is obviously a less accurate (logical) way of figuring out how far I can go per tank. For both linear trendlines, the R squared value is barely better than .6, meaning there is alot of fluctuation in my datapoints, but I think it's OK. The polynomial trendline on the shifted data is less clear as far as the formula, but it gives a better R squared value, meaning it fits the data better. Theoretically, I would always want to be on this poly plot, closest to the 50MPG "target" line to get the best MPG. This point is at approx 8.75 Gallons, where I should get 420 miles per tank. This should get me up to 48MPG in theory. Obviously, I need more datapoints.
__________________ 2005 Silver #6 - New on 03/19/2005 - Current Gas Data Mods: No reverse beep | Custom License Frame - buy one! Related Topic | Mud Guards Sig last updated: 11/20/2005 Notable Posts: A discussion about a one page of my mileage sheet. #156977 | ||
| | #73 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I updated the "Tank Miles per Gallons Filled" Chart to include lines for 35 through 60 MPG in 5 MPG increments, and tried to make things a little easier to see. It looks a bit confusing at first sight, but I made the datapoints smaller to be easier on the eyes. The important thing is how the pink line lines up with the teal line, showing how the "shifted" method calculates (seemingly) better per tank MPG. Most of the graphs are based on the "Unshifted" data, however, since it's a lot of work to update them. Are there any more correlations I should plot? |
| | #74 | |
Wow!...I'm not too proud to admit you lost me awhile back! But I do admire your charts.... I know they make sense to you and I appreciate your attempt at explaining them... I suppose If I studied them long enough I might soak up a little bit..... Very impressive..... I assume you work for Toyota.. if you don't, I hope your not working for the enemy!!! ![]() | |
| | #75 | |
As far as the charts, what part do you not understand? I would be more than happy to explain more. By plotting diferent variables vs other variable, we might find some combination of data that shows a good way to improve MPG. (Like my theory of always filling up with 8.75 gallons) | |
| | #76 | |
I've heard about the cutting technology you speak of.. its quite facinating! I will need to study your charts more before I give you some decent feedback.... I need to give them an honest chance... they are quite overwhelming! Thanks... | |
| | #77 |
| Senior Member Join Date: Apr 2004 Location: Great Central Valley, Fresno, CA
My Car: 2007 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | I appreciate revisiting fuel gauge pips. My first pip goes at ca. 125 miles. I drive the same route each day (60 mi round trip) and the central pips "average" about 50 miles + or –. I can easily judge if I am going to earn 600 miles on a tank. Because of repeated discussion here about running out of fuel, I always fill up when the last pip starts blinking. |
| Fuel Gauge/Fuel Filler Pipe | galaxee | Toyota Prius Service Bulletins - TSBs | 7 | 04-04-2006 09:59 AM |
| Fuel Gauge | NJDave | Fuel Economy | 11 | 02-26-2006 02:39 PM |
| Bad fuel gauge | Escalade_on_22s | Prius Main Forum | 13 | 12-16-2005 12:07 PM |
| Fickle Fuel Gauge or Shrinking Fuel Tank? | goldenpanda | Care, Maintenance and Troubleshooting | 4 | 04-05-2005 03:44 PM |
| SSC-40A & fuel gauge? | jsorger | Prius Main Forum | 3 | 03-01-2004 07:10 PM |
