Prius Main Forum This is a discussion on Max MPG readout within the Prius Main Forum forums, part of the Toyota Prius Forums category; When I test drove a Prius in Sept. I was amazed to see it got almost 300mpg when slowing for ...
Old 11-10-2005, 09:46 AM   #1
tootallrls
Send a message via MSN to tootallrls Send a message via Yahoo to tootallrls
When I test drove a Prius in Sept. I was amazed to see it got almost 300mpg when slowing for a stop. I recieved my new 2005 Prius on Oct. 29th, and found the best I can do is 99.9mpg. Did Toyota make a change? My highway mpg is better than my intown mpg. Does the limits change the original mpg claims? I can get 49mpg on the highway, but I struggle to maintain that in town, even with gliding and very slow, controlled driving.
tootallrls is offline
Old 11-10-2005, 09:52 AM   #2
maggieddd
maggieddd's Avatar
No, nothing has changed. You are probably confusing the miles driven and mpg
maggieddd is offline
Old 11-10-2005, 09:57 AM   #3
tootallrls
[snapback]153496[/snapback]
Thanks, but I remember watching the mpg as I drove the car and seeing it go down to 12.8mpg the rising up as the car came over the rise in the road, and when I left off the pedal the mpg went to 286.9mpg.
Old 11-10-2005, 10:01 AM   #4
LaughingMan
LaughingMan's Avatar
If you test drove a standard Prius without any kind of display mod, there's no way for you to see more than 99.9. That's the highest the display goes. 300 MPG? I don't know where you saw that.
You probably need to get used to the car before you can get higher mileages. At first it'll be easier to get higher mileages on the highway because it's fairly straightforward. Just drive it like any other car on the highway, but avoid acceleration, and you'll get close to 50s.
In the city and surface roads, that's where you'll need to learn the proper technique, but it's also where you can get 60, 70 MPG depending on various factors.
Do a search for pulse and glide. It's the central technique for getting high mileages on the Prius at speeds < 40 MPH.
"I thought what I'd do was I'd pretend I was one of those deaf mutes... or should I?"
2005 Seaside Pearl Prius, with Nav. "Tachikoma"
LaughingMan is offline
Old 11-10-2005, 10:04 AM   #5
maggieddd
maggieddd's Avatar
you really must be mistaken. Trust me, maybe you were seeing extra digits? Not sure what to tell you, be nothing has changed with the Prius as far as the fuel economy.
-or-
Toyota made a special Prius and didn't tell us and you happen to test drive it, which I very highly doubt
Old 11-10-2005, 10:07 AM   #6
Maytrix
Maytrix's Avatar
Send a message via MSN to Maytrix
[snapback]153492[/snapback]
In town can be very tricky. Driving consistently at "in town" speeds would yeild you great results, but there are those few things that tend to put a damper on that - stop signs, stop lights, traffic..etc. The biggest killer is starting from a dead stop. The more you can avoid that, the better.
Maytrix is offline
Old 11-10-2005, 10:35 AM   #7
tootallrls
[snapback]153505[/snapback]
Thanks all,,, not sure what I saw then,, BUT,reguardless,, I love my car and wish I could afford a second Prius as I have to share driving time with my wife..
Old 11-10-2005, 10:39 AM   #8
LaughingMan
I think the biggest killer is short trips, meaning 5-10 minutes. It doesn't give the system enough time to warm up and you burn gas for the whole trip.
Old 11-10-2005, 02:03 PM   #9
hdrygas
Curious I get mpg numbers like that on my ScanGage. I am not sure if that is how the mpg data comes from the CAN Bus having been calculate by one of the ECUs or if it derived from other information and calculated in the ScanGage.
hdrygas is offline
Old 11-10-2005, 02:47 PM   #10
tootallrls
[snapback]153636[/snapback]
So, hdrygas, you've seen the high numbers too?
speedometer readout in reverse Rangerdavid Prius Main Forum 10 08-22-2006 06:06 AM
Is there a GPS Altitude Readout? bonanza34g Prius Main Forum 11 04-04-2006 11:00 PM
Outside Temperature Readout Question priusblue Prius Main Forum 2 01-20-2006 11:14 AM
MP3 readout on display HyDee Audio and Electronics 4 11-21-2005 04:41 PM
Current MPG readout question paulisme Audio and Electronics 6 04-18-2004 12:27 PM
