Prius Main Forum This is a discussion on HID headlamp questions. within the Prius Main Forum forums, part of the Toyota Prius Forums category; Just curious, I have an 05 Package #3(BI). According to the sell brochure, HID headlamps with auto-leveling is part of ...
Old 11-10-2005, 12:17 PM   #1
hilore
Just curious,
of a package. Only packge 4 & 6 have them.
Am just abit confused. If I don't have HID headlamp,
what kind of headlamp do I have? What's the different
between the HID headlamp and what I got?
--Hilore
hilore is offline
Old 11-10-2005, 12:26 PM   #2
flareak
Send a message via AIM to flareak Send a message via Yahoo to flareak
you have normal halogen headlights
i'm not sure i can explain the difference of how they work, but HID lights are lights that have a color close to white and its brighter and it travels farther.
flareak is offline
Old 11-10-2005, 02:59 PM   #3
IsrAmeriPrius
Progressive Member
IsrAmeriPrius's Avatar
How Stuff Works
IsrAmeriPrius is offline
Old 11-10-2005, 03:24 PM   #4
Charles Suitt
Charles Suitt's Avatar
Send a message via Yahoo to Charles Suitt
<_< As I understand the HID headlights...
They are "arc lights." High voltage discharges across points producing the blue-white light. HID = High Intensity Discharge. Since the light is extremely bright, A Prius with HID headlights has a "levelling" system which responds to the weight distribution in the car to adjust the headlights vertical positioning to avoid blinding oncoming drivers. The upper horizontal "cutoff" of the light beam is very sharp and clean. Some Prius drivers have reported being "flashed" by oncoming drivers due to the intensity of their HID headlights. There have been reports of HID headlight systems being stolen since they can be modified to produce a stun gun.
OT but related: In my youth, my dad was a movie theater manager and I enjoyed visiting the projection booth. The light source in the projectors was "arc lights" operating on very high DC voltage discharging between two carbon contacts.
As for me, I have Halogen which are plenty bright for my needs, and I have avoided the added mechanical complexity of the levelling system. FYI: Section 8 of your Owner's Manual "DO-IT-YOURSELF MAINTENANCE" briefly comments on the HID headlights (p.303 in the 2004 Manual), mentioning that 20,000 Volts is generated momentarily when the HID lights turn on.
Charles Suitt
Dallas Texas
2007 Touring Edition
(Former Prius: 2004)
Charles Suitt is offline
Old 12-05-2007, 12:43 AM   #5
JaviNOS
Mod Freak
JaviNOS's Avatar
Originally Posted by hilore View Post
Just curious,
--Hilore
Well... in a few words it projects more light (whiter depending on the temperature code) using less energy.
My 2004 did not include this so... I just went on and added the mod... You can get aftermarket HID kits for the Prius @ ebay or any speedshop. The bulb size is H4 and you should get the Hi/Low combination as the Prius uses the same bulb for Hi and Low beam... If you dont you wont have a Hi beam only a low beam.
As for visibility... It is notable right away... as soon as you turn them on at night. Yes it does blind oncomming traffic if you dont point them down since neither your packege nor mine have the autoleveling... It gives the car another look and you can also see better at night and avoid unexpected things because you see more clearly
JaviNOS PRius... The car died (wrecked) on 3/15/08
MODS:
Interior: LED lighting, Custom sound (JL 12" subwoofer. Pioneer components. Kenwood Coax. JL Cleansweep. JL 6ch amp)
Exterior: HID headlights/VVT-i emblem/Sharkfin anthena/LED license plate lighting/LED Signal Mirrors
Performance: TOMs upper stabilizer bar/BT plate/TRD Sportivo suspension kit/Slotted and drilled rotors
Best 51.3 avg MPG
Best tank 510miles
R.I.P. Prius
SELLING PARTS @ PRIVATE SALES SECTION
JaviNOS is offline
Old 12-05-2007, 03:23 PM   #6
subarutoo
subarutoo's Avatar
The easiest way to tell HID or not, is that if you have factory fog lights then, you have HID. They come together as an option.
subarutoo is offline
Old 12-05-2007, 03:56 PM   #7
Bill Merchant
absit invidia
Bill Merchant's Avatar
Nominated 6 Times in 1 Post
Friends: 47
Cool HID Detection
Another way of knowing if you have HID headlamps is if there are yellow "High Voltage" warning labels on the black plastic cowl under the hood. If you have HID lamps, there's a sticker on the black plastic near the lamps.
Bill Merchant is offline
Old 12-05-2007, 06:34 PM   #8
Boo
Boola Boola Member
Boo's Avatar
Friends: 11
Default Brighter Halogens
Notwithstanding that the original post was from 2005, I'm adding my 2 cents anyway:
A better way to get HID-like brightness out of halogens is to get brighter, but legal, halogens like Sylvania/Osram Silverstars (but they only lasted a year for Tideland Prius, but they were always on because of Canada's daytime running lights requirements), or better yet, Philips X-Treme Power which are 80% brighter than the OEM halogens (but we don't have any data yet on how long they last ... Tideland Prius, usbseawolf2000 and I only recently put them on on our Prii). The Philips X-Treme Power bulbs cost around 2 for $47.
Best regards, Tom
Boo is offline
How To: Change Headlamp / Headlight bulb usbseawolf2000 Knowledge Base Articles Discussion 67 08-20-2008 02:21 PM
Headlamp removal Conine Prius Modifications 2 02-14-2007 05:51 PM
Auto Headlamp Feature 0n 2006 prius-yes-dubya-no Prius Main Forum 10 01-02-2006 12:43 PM
headlamp adjustment drecian Prius Main Forum 1 12-05-2005 01:14 AM
[ KB ] How to Turn Fog Lights on independent of the Headlamp Anonymous Knowledge Base Articles Discussion 2 05-31-2005 03:04 PM
