Prius Main Forum This is a discussion on Front Tire Wear within the Prius Main Forum forums, part of the Toyota Prius Forums category; I just find it hard to believe the Prius and 3 sets of tires can all be bad. I have ...
Old 12-21-2005, 03:59 PM   #11
Schmika
Schmika's Avatar
I just find it hard to believe the Prius and 3 sets of tires can all be bad. I have been wrong before though...sometime in 1997 I think.
Schmika is offline
Old 12-21-2005, 04:46 PM   #12
galaxee
running WOT until out of fuel
galaxee's Avatar
Nominated 5 Times in 3 Posts
Friends: 21
[snapback]177032[/snapback]
galaxee is online now
Old 12-21-2005, 10:59 PM   #13
NuShrike
my other Mobile Suit is a ...
NuShrike's Avatar
I'm on 26K miles on the OEM tires. Not bald yet and I think they all pass the penny test still too.
They certainly do wear faster than the performance/OEM tires I've used on my Civic. I wonder if the extra body-roll of the Prius has something to do with this.
NuShrike is offline
Old 06-18-2006, 07:35 PM   #14
blondie
<div class='quotetop'>QUOTE(fishertheband @ Dec 21 2005, 12:51 AM) [snapback]176655[/snapback]</div>
Hi,
I posted here about 6 monts ago about my front tires wearing out after 15,000. The dealer then replaced all four and 4,000 later the fronts were worn out again (inside and ouside edges bald.)
The dealer replaced the front tires yet again and I had followed the suggestions here to inflate the fronts to 40psi, which I did...and it helped! I got nearly 4.600 miles this time before the front tires were bald again.
Today I went to Goodyear and bought 4 new tires and had them allign the front end. They said the allignment was 'out' around 27%.
Should this next set show normal (almost no) wear in 5,000 miles I'm going to have a little chat with my dealer. I would probably ask for a refund on my pre-paid service plan. (I also had my 1st 'out of dealer' oil change and after only 3,000 miles I was a quart and a half low....hmmmmm.) Luckily I'm in a position where I can chat with the heads of Toyota corporate should the dealer blow me off.
I'll let you all know what happens in a few months.
BTW - To answer some 'suggestions' in advance I received from some rather angry posters about this subject last time.
NO! I am not driving too fast.
NO! My mountain driving (curves) only involved around 260 miles per every 4,000 the car is driven.
NO! I do not regularly run into curbs, let the PSI get too low, or take the car off road.
And finally NO! I am not unhappy with the car in any way shape or form. This is just one little 'glitch" I've had with my Prius.
blondie is offline
Old 06-18-2006, 11:04 PM   #15
kn6vv
kn6vv's Avatar
Package: #8
Sorry to hear your alignment being out so bad! I guess my question now for all the Priuschat readers is their own Prius experience with alignment and tire wear.
I'm reading a number of posts on various threads on Priuschat.com about premature tire wear, needed shim kits for the rear alignment, and overall bad alignment problems and associated tire wear.
1) Are these isolated problems or common among Prius drivers?
2) Do those reporting problems believe that Toyota is not aligning them properly when delivered or is the Prius unable to hold a steady alignmen?
I'd love to hear your opinions on this. Thanks in advance!
Tom - KN6VV
<div class='quotetop'>QUOTE(fishertheband @ Dec 20 2005, 11:51 PM) [snapback]176655[/snapback]</div>
Hi,
kn6vv is offline
Old 06-19-2006, 10:20 PM   #16
tumbleweed
tumbleweed's Avatar
I have been fighting an alignment problem with mine for the last month or so, I have had five alignments and have another scheduled. I found one Toyota dealer whose alignment equipment was wrong by a tenth of a degree or more for the toe measurement. This is enough to cause quite a bit of tire wear and make the car very difficult to drive. When I called to give them a heads up they became quite defensive and refused to admit they might have a problem with their equipment. So don't believe what your told unless you can have it verified by another shop. The best alignment technicians I have been able to find around here are at a tire dealer that has fairly new Hunter equipment.
Rear wheel alignment can be a real problem, there are no adjustments. The Toyota region here will want to replace the rear axle beam if it's way out which mine was. That's when my problems started because the new axle made the car extremely unstable. The rear toe went from toed in to much on one side to toed out to much on the other. Problem is toed in is stable; toed out is unstable. I went from having one of the best driving Priuses to one of the worst. But it is now "in spec" just barely but it's in so the Toyota dealer really doesn't want to do any more with it. Now it will change lanes without moving the steering wheel when it's a bit windy out.
Thanks to some badly needed expert advise from a couple of Prius Chatters (Galaxee and DH) I am trying to fix the problem myself with shims. The Toyota dealer won't help because manufactured shims are apparently unavailable for the Prius. They either can't or will not try to make any.
I tried to buy shims from a couple of the dealers mentioned here but neither will answer emails.
If I were on my own I think I would have to sell the car But thanks to Galaxee and DH and some old timers that work at alignment shops around here I think I'll be able to fix it.
former Prius owner, waiting for a G III
present car BMW 3 series
tumbleweed is offline
Old 06-19-2006, 10:46 PM   #17
galaxee
galaxee's Avatar
Friends: 21
<div class='quotetop'>QUOTE(kn6vv @ Jun 18 2006, 11:04 PM) [snapback]273274[/snapback]</div>
well my husband is a mechanic at a dealership, and he does see more problems with prius alignments than with other cars. the back wheels are just annoying because they're not adjustable, and the fronts lose alignment pretty easily. he's given it plenty of thought and his theory is that the difference in brake force application in regenerative vs conventional braking cause this phenomenon.
cars are not aligned as a part of the predelivery inspection. however, they do offer one free alignment early in ownership because it's known that the tie-downs on the shipping truck can f up the alignment during transit.
black 2005 prius, tweaked just the way i like it
my diagnostic guy on electronics:
"lack of troubleshooting ability is due to a high common sense rejection ratio."
Old 06-20-2006, 02:23 AM   #18
tmorrowus
In case you don't know: Most tire/alignment places will sell lifetime alignment for under $200. I paid $160, and others have paid significantly less. I bought the package and got my money's worth by having alignment checks done at 10k, 20k, and 30k miles. The alignment tested within specs at 10k and 20k, but at 30k needed a significant correction on the front.
Also, some places will sometimes offer free or low cost alignment checks. Getting the alignment done at the dealer seems to be most unreliable and most expensive.
My experience with the Goodyears is that they wear fast but evenly with rotation. I got 30k miles on mine and the wear was very even. I inflated to 42/40.
If you find the front are wearing faster than the rear, an obvious workaround is to check tire depth often and rotate as soon as they start getting worse in the front. At least that way you'll go twice as long before needing replacements.
But I've never heard of alignment causing the inside and outside to both wear before the middle, I've only heard of underinflation causing that. You might consider inflating to the maximum rated tire pressure if this continues; even if underinflation isn't the root cause it should help even the wear.
tmorrowus is offline
Old 06-20-2006, 08:32 AM   #19
tnthub
tnthub's Avatar
If the inside and outside edges of the tread pattern are what is worn, the cause is likely too little air pressure. When a radial tire has too little air it is prone to cupping when weight is transferred onto that tire. I am not an expert on the Prius but I have heard of front tire wear complaints and my normal response would be for a few folks to add a couple of pounds and see what happens. Dealer recommened pressures are a guideline, not an absolute.
I am one of those idiots who plays with tire pressures frequently and I have a decent amount of practice with different tires, different sidewalls, bias and radial designs... But limted experience with the prius.
What I do know is this... If a tire is at the proper inflation for the vehicle, and I assume the proper size tire for the rim, then as weight increases or decreases on the front of the car, the footprint, or contact patch area, has a constant pressure all the way across. Too much air and the contact is greater in the middle of the patch and too little air results in more contact at the outside edges and less in the center.
Air pressures on a standard radial tire, even slightly less than normal, may result in poorer cornering. Too much air pressure can potentially result in a harsher ride and less traction, especially in a front wheel drive vehicle under acceleration as the weight is offloaded from the front to the rear.
Avoid gas station tire gauges. Buy your own gauge and only use that one. I like the digital gauges that will read in 1/2 pound increments and are backlit for night use. If you are serious about tire pressure check the tires when you fill the tank which isn't very often in a Prius. You do not need to buy an expensive gauge, just one that works the same way every time. It only needs to be consistent in relation to inself to be of value.
2002 Champion New England Dragway
2001 GM High Tech Shootout Winner
1999 Champion Oxford Dragway
http://www.tntdragracing.com
tnthub is offline
Tire Tread wear flareak Care, Maintenance and Troubleshooting 21 10-14-2008 05:19 PM
tire wear Dennis A. Care, Maintenance and Troubleshooting 6 07-27-2007 05:18 PM
Tire Wear Info and Winter Tire questions mrv Care, Maintenance and Troubleshooting 7 11-22-2005 08:18 PM
Tire wear info and winter tire questions mrv Prius Main Forum 1 10-09-2005 02:11 PM
irregular front tire wear jrjohnson Care, Maintenance and Troubleshooting 8 06-28-2004 11:51 AM
