| Prius Main Forum This is a discussion on 42/40 = uneven tire wear or unsafe? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Does anyone know if running at 42/40 (on any tires) will wear the center before the outer edges of the ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Does anyone know if running at 42/40 (on any tires) will wear the center before the outer edges of the tire? If the tread is wearing unevenly, it would indicate that the tire isn't contacting the ground optimally, so that would be a safety issue. I'm just wondering because it's quite a bit higher than the recommended 35/33 pressure. I've been running at 42/40 for a while now, and I love the increased MPG and handling, but I'm wondering if I'm sacrificing safety and/or tread life at the same time. Thanks! |
| Join Date: Oct 2005 Location: Winters, CA: Prius capital of US. 30 miles W of Sacramento
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I ran 40/38 on my '02 for 54K mi. and the wear was perfectly even. Those were Bridgestone Potenzas, too, not a very good tire otherwise. And yes, technically safety could be a slight factor---mostly, I think, in the event of having a slight bounce if you drove over something, thus temporarily losing grip with that wheel, instead of "squishing" over it. |
| BourbonEnthusiast Join Date: Sep 2005 Location: SI, NY
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Picked up my 06' yesterday and checked the pressure after the car sat several hours. They had 31 all around... So I got my portable little compressor out and riased em' right up to 37/35. I'm nervous about running 42/40 or even 40/38... No one who runs that high and has had their car say 2 years now has experienced early wear of their struts etc? I live in NYC and hitting the inevitable pothole(s) around here can be a bitch on the suspension and running that high, well, can it really be good? |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | My integrities wore more out the outer edges than the center...I religiously maintained 42f/40r pressure. I've had my Prius for over 2 years and have no issues with struts/handling and have never heard a report of any issues. Modern steel belted radial tires should have no issues of crowning/center wear at the pressures we're talking about here. |
My Car: 2004 Prius Package: Pioneer #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | It's a non-issue. Pressure all the way up to the maximum is what a good quality tire will maintain its shape at nowadays. After 30,000 miles with my HydroEdge tires running at 44/42, the wear is still even all the way across the surface. The days of rounding tires are just bad memories from decades past. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'll second Evan's response - I kept my stock Integritys at 42/40 for 50k and they still wore out on the edges first. Started to become evident at 25k or so. I was scared to go higher, but wondered if I could even out the wear. |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | edge wear is normal under all conditions if the tires are not properly rotated and balanced. front tires will wear on the edge faster and this wear is FASTER for underinflated tires. normal for ANY other pressure. that is why front to rear rotation is critical. a rebalance is recomended for each 25-33% of usable tread wear loss. edge wear occurs while turning and can not be avoided. for most tires, a small amount of overinflation will slow the wear down. the rears because they are pulled around the corner with minimal weight on them, dont distort and dont wear on any spot unevenly
__________________ My 2006: Last tank 463.1 miles @49.2 pump (49.4 computer) 4.22 cpm winter mpg 50.70 summer mpg 54.59 lifetime: 33,038.3 miles 52.79 mpg pump (54.04 mpg computer) 5.74 cpm My 2007 Zenn Driven 5849 miles, 2.00 cpm/ 105 mpg (at $2.05/gal), 4.04 miles/ Kwh Savings over my Prius $300.79 The Corolla...567.79 The REAL SAVINGS from not driving Corolla 657.39 +Prius= 958.18 (excludes maintenance costs...would be unfair to ICE vehicles) My Plate: DUALPWR (Dual Power) |
| Wildly Uneven Tire wear | FL_Prius_Driver | Care, Maintenance and Troubleshooting | 14 | 09-05-2007 05:25 AM |
| tire wear | Dennis A. | Care, Maintenance and Troubleshooting | 6 | 07-27-2007 05:18 PM |
| Front Tire Wear | fishertheband | Prius Main Forum | 18 | 06-20-2006 08:32 AM |
| Tire Wear Info and Winter Tire questions | mrv | Care, Maintenance and Troubleshooting | 7 | 11-22-2005 08:18 PM |
| Tire wear info and winter tire questions | mrv | Prius Main Forum | 1 | 10-09-2005 02:11 PM |
