Prius Main Forum This is a discussion on Disabling reverse beep/seatbelt beep on an 06' within the Prius Main Forum forums, part of the Toyota Prius Forums category; I only noticed it after I turned off the reverse beep; but the border around the "R" in the instrument ...
LinkBack (1) Thread Tools
Old 01-08-2006, 08:16 PM   #21
QED
QED's Avatar
I only noticed it after I turned off the reverse beep; but the border around the "R" in the instrument cluster blinks when you are in reverse.
I haven't seen that mentioned and it's not in the manual (did it always blink? learning something new every hour ).
I have conditioned myself to double check what gear I am in before letting up off the brake. Now with the Prius, a glance at the instrument cluster will quickly confirm which gear you are in. The blink is very eye catching. I definitely don't miss the BEEP .
"Keys?...We don't need no stinking keys!"
QED is offline
Old 01-09-2006, 04:51 AM   #22
Paradox
BourbonEnthusiast
Paradox's Avatar
I have got to be doing something simple wrong or it doesnt work... I start the car, cylce thru the ODO from odometer to a to b and back to odometer and turn the car off. Restart the car, hold down the ODO button for 10-15 seconds and while still holding shift into reverse and then press Park. Nothing... Tried again doing the same thing but didnt press park after shifting into reverse, nothing... I dont know, any tips?
Paradox is offline
Old 01-09-2006, 10:43 AM   #23
priusblue
[snapback]186389[/snapback]
Disabling Reverse Beep
• Power on the car, Cycle ODO/TRIP, stopping on ODO, Power off the car.
• Power on, within 6 seconds, hold ODO for at least 10 seconds.
• While still holding ODO shift into Reverse and back into Park.
• b-on shows on speedometer display, press ODO to cycle to "b-off".
Do you see the "b-on" on the speedometer? You can then release and press ODO again to see the "b-off"
priusblue is offline
Old 01-19-2006, 09:59 AM   #24
Begreen
Begreen's Avatar
Originally posted by JackDodge@Jan 7 2006, 06:48 AM
that's for sure.  The Prius is so quiet that it's difficult to get used to.  You have to be a little more alert than someone in a gas-only vehicle.  I just wish that they'd give you some settings to play with so that you could make the reverse beep less annoying.
[snapback]185319[/snapback]
I would really rather the beep was outside, at the rear of the car. I would still hear it, but the safety value would be much better for warning pedestrians. Has anyone done or conisdered this modification?
Begreen is offline
Old 01-19-2006, 10:16 AM   #25
gjertsen
gjertsen's Avatar
Originally posted by Paradox@Jan 6 2006, 05:00 PM
I read somewhere on PC how to disable the annoying reverse beep and seatbelt beep but I guess it was for the 04/05 model.  I tried the procedure on my 06' and didn't have any success.  I may have very well done it wrong so if it is the same procedure please describe in detail what has to be done and if there is a new procedure for the 06' anyone have a good tech who told them how to do it yet?  And if so please share it with us!
Also, on a side note, anyone know if coastaletechs's EV mod works on an 06' yet?
[snapback]185000[/snapback]
See this thread for complete details... it worked for me in my new 06. I think there may be caveats I've read about maybe the doors needing to be closed, and maybe no passenger in the passenger seat... not sure about that. The dealer you bought from should be able to help you out, if it comes to that.
gjertsen is offline
Old 01-19-2006, 11:10 AM   #26
Clar
Clar's Avatar
Originally posted by duanerw@Jan 8 2006, 07:03 PM
I disabled the backup beep on my 05 and unable to do it with the 06.I checked with
the service mgr and he said if i disable it i will void the warranty.I have seen that
posted here a few months ago and didnt believe it.  now i do and will let well enough
alone. you can do as you please but check it out first............
[snapback]186118[/snapback]
re-enable the beep before you ask 'em to do warranty works.
I disabled the beep the 2nd day I got my car. Didn't have the time to disable it on the 1st day.
Clar is offline
Old 01-19-2006, 12:47 PM   #27
flynz4
[snapback]193188[/snapback]
Mine came with the reverse beep and seat belt beep already dissabled when I bought it as far as I know. Heck... I dont even know how to use the "beep removal" wrench. That is my story and I am sticking to it... espcially if they tried to deny a warrany claim.
Speaking of which... my reverse beep and driver seatbelt beep are now disabled... but when I was driving to work yesterday with my backpack on the passenger seat... about half way to work the passenger seatbelt alarm started going crazy. Do the driver and passenger seatbelt alerts need to be dissabled independently?
/Jim
flynz4 is offline
Old 01-19-2006, 11:32 PM   #28
sheri
Same for me. Try as I might, I can't get my '06 into b-off mode.
sheri is offline
Old 01-20-2006, 01:53 AM   #29
flynz4
[snapback]193783[/snapback]
I have an '06 package 8... and it worked perfectly for me.
/Jim
flynz4 is offline
Old 01-27-2006, 02:42 AM   #30
m8cca
I have 06' pkg 8 and same procedure works for me.
When disabling the passenger belt beep, you can just sit on the passenger seat to perform the sequence. You don't actually have to get the car to start(ready), just pressing power twice to get to the odo/trip display would work fine. (better if you are doing this in a closed garage so engine won't kick in at some point.)
The driver seat initial beeps is mandated by law I believe which is why it can't be disabled like the reminder beeps.
m8cca is offline
LinkBack to this Thread: http://priuschat.com/forums/prius-main-forum/13834-disabling-reverse-beep-seatbelt-beep-06-a.html
Xoost.com This thread Refback 04-24-2008 03:24 PM
[ KB ] How to eliminate Reverse Beep & Seatbelt Beep Danny Knowledge Base Articles Discussion 51 04-25-2008 11:03 PM
Is disabling reverse/seatbelt beep reversible? acousticbiker Prius Main Forum 4 07-08-2006 11:54 PM
Disabling the seatbelt beep - on a Corolla? EmptyG Audio and Electronics 0 06-29-2006 12:37 PM
Disabling Seatbelt Beep DougSlug Prius Modifications 6 04-03-2006 11:32 PM
Disabling the reverse beep (and seatbelt beep) dougkm Prius Main Forum 1 12-01-2003 07:42 AM
