| Prius Main Forum This is a discussion on Mud Flaps, and where to buy them within the Prius Main Forum forums, part of the Toyota Prius Forums category; Originally posted by parrot_lady @Jan 18 2006, 12:24 PM The rear tires need to be dismounted to do this. [snapback]192495[/snapback] ... |
| | #21 | |
I respectfully disagree... While the rear Mud Guards recommend removing the rear tires and drilling a hole on the outside edge, I found it far better and sturdier to drill a hole on the inside bottom edge behind the tire. It is a little snug with the drill, but you can drill the holes just fine without removing the tires. This way the Mud Guards are attached at the top middle and inside bottom edge, rather than top, middle, and outside bottom edge. They fit perfectly and secure, and do not move. | |
| | #23 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Ok, I jumped in and installed my mudguards today. They look sharp. I do see where having an inside screw on the rear flaps would be nice. I may add one. |
| | #24 |
| Senior Member Join Date: Feb 2006
My Car: 2004 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Got 'em from Toyota Depot, but BEWARE: Though price is listed at $31.13, the cheapest shipping is $24! And the full box weighs less than 3 lb. So you'll do just as well paying $43 to Metro. Easy install, easy drill thru plastic only, fit well. Could be a little bigger. |
| MUD FLAPS | seaside man | Prius Main Forum | 6 | 08-29-2006 11:27 AM |
| Mud Flaps | Realcrose | Prius Modifications | 2 | 01-17-2006 06:34 AM |
| Mud Flaps. | Limitz | Prius Main Forum | 7 | 07-18-2005 01:04 PM |
| Looking for Mud Flaps for 03 Prius | pnelson | Prius Main Forum | 1 | 02-26-2005 02:22 AM |
| Mud flaps for a 2004? | mikepaul | Prius Modifications | 122 | 12-19-2004 07:53 AM |
