Prius Main Forum This is a discussion on TPMS considerations when replacing '06 OEM tires within the Prius Main Forum forums, part of the Toyota Prius Forums category; After taking delivery of my '06 Seaside Pearl #8, I plan on going to Discount Tire Center and replacing the ...
Old 01-13-2006, 01:18 AM   #1
acousticbiker
After taking delivery of my '06 Seaside Pearl #8, I plan on going to Discount Tire Center and replacing the OEM Integrities with a set of GY Assurance ComforTreds (I'll get a $30 trade-in for each tire). When replacing just the tires (and not the rims/wheels), are there any special precautions that need to be taken to be sure the tire pressure monitoring system stays intact?
I've asked this question before but haven't gotten any clear, definitive answers. To those who have done this, any special instructions to be given to the tire installers? I asked my dealer if they would swap the tires out, but they said it would be cheaper for me to go to DTC.
2006 Seaside Pearl Bisque #8
acousticbiker is offline
Old 01-13-2006, 10:45 AM   #2
Krash
I hope somone has info on this subject because I'm planning to do the same.
I'm afraid the workers at the DTC won't have a clue that those stems are probably fragile, and has been noted very expensive, reportedly $106 each!
Also, what's the procedure for resetting the TPMS?
BTW, acousticbiker, the local store here in Tucson gave me a price of $204 for the trade.
How does that compare to your quote?
Krash is offline
Old 01-13-2006, 04:00 PM   #3
acousticbiker
[snapback]189182[/snapback]
They actually haven't given me a final quote yet, but $80 per ComforTred and credit of approx $30 per Integrity. That comes about to about $200. Does your price include DTC's replacement plan ($12/tire or something like that)?
Old 01-13-2006, 10:06 PM   #4
rick57
You must be careful when changing tires on the new Prius. The TPWS ( Tire Pressure Warning System ) is the same as used on other Toyota's; Tundra,Sequoia,Tacoma. It has been out for a few years,so many tire places should have run into them. But if not here goes.
First let all the air out of the tires. When empty,remove the nut holding the valve stem and let it fall in the tire. There is a washer under the nut,don't lose it!The valve stem is attached to the transmitter. If you don't drop it into the tire,the attachment that removes the bead as the tire rotates around will break off the transmitter. With it inside the tire,it is safe to remove the tire like any other.
When putting on the new tire,reinstall the transmitter/valve stem back into the wheel ( don't forget the washer! ).Torque the nut to 35 foot pounds. When reinstalling the tire,make sure that the transmitter/valve stem is away from the tire changer attachment. With the tire now mounted,air up to the proper PSI ( factory specs are 35 front,33 rear ).
My opinion is to suggest that the place doing the tire swap contact the nearest Toyota dealer if unsure. They should be able to copy off the steps from the Repair Manual for them to follow. If you want,I can try and send you the pages in PDF. PM me if interested and we can try, .
Rick Angles
Toyota Master Diagnostic Technician
Toyota Hybrid Technician
Germain Toyota
Columbus, Ohio
rick57 is offline
Old 01-13-2006, 10:11 PM   #5
Aaron144
Thanks for the great info rick57!!!
Aaron144 is offline
Old 01-13-2006, 10:32 PM   #6
offersk
You might want to consider having the dealer swap your tires BEFORE you take delivery. I got my 06 Prius last week. I had the dealer install Michelin Harmony's for about $112 each and got a credit of a little more than $60 per Integrity tire. Cost me $208 total for the swap and was no aggravation for me.
offersk is offline
Old 01-14-2006, 08:02 AM   #7
rick57
[snapback]189573[/snapback]
I agree.A lot of dealers also sell tires and will price match the competition,I know we do. That may save some head aches here,
rick57 is offline
Old 01-14-2006, 08:04 AM   #8
rick57
Also,if you are interested in the PDF pages,you might send me a PM with your email.I don't think there is a way to attach the file to a PM.If you know a way tho,let me know, .
rick57 is offline
Old 01-14-2006, 06:36 PM   #9
Krash
[snapback]189405[/snapback]
acousticbiker, thanks for the tip on the replacement plan. I'd never heard about it. I'm sure if you don't know to ask. they won't volunteer any info on it.
Does sound like $200 is in the ballpark though.
Krash is offline
Old 01-14-2006, 06:43 PM   #10
Krash
Originally posted by rick57@Jan 13 2006, 08:06 PM
You must be careful when changing tires on the new Prius...
...They should be able to copy off the steps from the Repair Manual for them to follow. If you want,I can try and send you the pages in PDF. PM me if interested and we can try,  .
[snapback]189571[/snapback]
rick57, Super Info! I'd very much like to get a copy of the PDF so I can give a printed copy to the techs at DTC.
I think you can just add the attachment, but just in case I'll PM you.
Krash
Krash is offline
Replacing Tires geologyrox Prius Modifications 19 10-27-2007 11:19 AM
Battery life considerations tekn0wledg Prius Technical Discussion 7 08-20-2007 11:45 AM
Winter Tires and TPMS Niji Prius Main Forum 1 08-02-2007 12:30 PM
TPMS for '05 and below hobbit Prius Modifications 3 07-17-2006 08:34 PM
Replacing tires -- is a wheel alignment necessary? bookrats Care, Maintenance and Troubleshooting 4 11-07-2005 01:43 PM
