| Prius Main Forum This is a discussion on Parking Brake within the Prius Main Forum forums, part of the Toyota Prius Forums category; Since I don't know what type of winter weather you get in Iowa, my rule of thumb is as follows: ... |
| | #11 |
| Senior Member Join Date: Nov 2004 Location: Maplewood, NJ
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Since I don't know what type of winter weather you get in Iowa, my rule of thumb is as follows: If it is cold and wet never set the parking brake unless it is absolutely required (facing up or down a hill). If the cable gets wet and you set it, with the temperature at freezing or lower the cable might freeze and you won't be able to release the parking brake when you want to get going. |
| | #12 |
My Car: 2004 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | I figure they are called "parking" brakes for a good reason. My dad taught me to use them all the time, so I do. In temps from -40 up here to much less frigid temps in Utah, I've never had a problem, except on one vehicle. My 2000 GMC Sierra had 4 wheel disk brakes with rear "drum in hat" parking brake, and that design was remarkably unreliable. For some reason at -30 C or colder, it would be sluggish to release. Never had that problem with any other vehicle. If you regularly - all the time - use parking brakes, the cables should never seize up. If you never use them, then after say 3-4 years encounter a very steep hill you have to park on, more than likely the parking brake will seize once you apply it. Case in point: my 1984 Ford F-150, purchased new, parking brake always used. Rust Checked yearly until 1997, and it still has the original factory parking brake cables. YMMV.
__________________ 2004 Toyota Prius "B", Tideland Pearl 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion |
| Parking Brake Pedal Pad | EnsPulver | Care, Maintenance and Troubleshooting | 2 | 09-29-2007 08:44 PM |
| poll do you use your parking brake? | priussoris | Prius Main Forum | 53 | 05-18-2007 11:00 PM |
| Parking brake questions | alasnik | Prius Main Forum | 5 | 12-26-2006 06:51 PM |
| Do you always use the parking brake? | Oxo | Prius Main Forum | 34 | 11-02-2005 12:42 AM |
| Parking Brake vs Parking Button | Kablooie | Prius Main Forum | 36 | 04-23-2004 02:30 AM |
