| Prius Main Forum This is a discussion on 2006 Prius shudder when braking within the Prius Main Forum forums, part of the Toyota Prius Forums category; I've been driving my 2006 Prius for about 3 weeks and put on little over 1000 miles. I keep noticing ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I've been driving my 2006 Prius for about 3 weeks and put on little over 1000 miles. I keep noticing that whenever I brake, the car seems to shudder. It doesn't seem to be switching from gas/electric as noted by other postings. Does anyone else notice this? Is this normal for break in period? |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Is this your first prius ? If so, teh regen braking takes a little getting used to. Basically, you dont need to be slamming the brakes with as much force as you may be used to on vehicles with conventional systems. |
| Senior Member Join Date: Jan 2006 Location: Somerville, MA
My Car: 2006 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | A shudder could also mean that your wheels are not alirgned. But I do agree that the regen braking felt slightly different then normal braking so it could be related to that. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I definately notice this on my husband's Lexus 400h (hybrid) but on my new Prius I can't feel that at all! The Lexus dealer said it was normal - basically the effect of having the braking energy converted to battery power. |
| Join Date: Aug 2005 Location: Ladera Ranch, Orange County, CA
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Yes, we experience the "grabby" feeling in our 2006 at very low speeds. You almost always get one "grab" when transitioning from regen to friction brakes at around 7 or 6 miles per hour. But we have also noticed that if you are creeping along in slow traffic by slightly lifting your foot from the brake (as you might with any car with an automatic transmission), we can get a repetitive creep-grab-creep-grab feeling at about 3mph. I don't remember this from our 1000+mi test drive of a 2005 Prius rental, but then that was mostly highway miles and we may not have noticed every idiosyncrasy. Another way to tell when you are transitioning from regen to friction, if you tune in your hearing, is to listen for the whine of the inverter. - Bob R. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | When I slow down... I usually push the brake very slightly and I can feel a long gradual deceleration which I know is not using the friction brakes at all... but instead is using regenerative braking. Then at 7mph, even though my foot pressure does not change at all... I can feel a slight release, and then a re-application of brakes when the regerneraive brakes dissengage, and the friction brakes kick in. /Jim |
Kirk San Jose | |
| slight "shudder" | plantz | Care, Maintenance and Troubleshooting | 3 | 08-05-2007 01:51 PM |
| Prius Braking | gjnheimes | Prius Modifications | 4 | 07-31-2007 12:09 PM |
| New Prius - braking | jimfnc | Prius Main Forum | 4 | 05-28-2007 02:37 PM |
| 01 prius steering shudder | statultra | Prius Technical Discussion | 3 | 10-14-2006 06:13 PM |
| Prius handling, sway on braking | fogdrop | Prius Modifications | 8 | 06-13-2005 10:01 AM |
