Prius Main Forum This is a discussion on Connecting Treo 650 within the Prius Main Forum forums, part of the Toyota Prius Forums category; Originally posted by pjconner @Mar 7 2006, 09:34 AM Check your private message box.  I sent you my email.  Maybe ...
Old 03-07-2006, 11:43 AM   #11
dbermanmd
Originally posted by pjconner@Mar 7 2006, 09:34 AM
Check your private message box.  I sent you my email.  Maybe we can both sit in our cars and figure this out.
[snapback]221645[/snapback]
E-mailed you back.
I cant begin to thank you for your kindness.
David
dbermanmd is offline
Old 03-07-2006, 01:05 PM   #12
letsail
I had a similar problem with my Verizon 650. I was totally frustrated with it UNTIL I learned I had to make a call from the phone to "activate the pairing."
dbermanmd:
NEXT question: once you get the car paired with the phone and have a connection established, have someone else call you. See if your car/phone drops the first call and takes the second. No warning. The first call is just gone.
I have this problem. It might be a problem with bluetooth. Or it might be the car. Has anyone else had this problem?
letsail is offline
Old 03-07-2006, 02:14 PM   #13
jrfaris
jrfaris's Avatar
[snapback]221755[/snapback]
This is the call waiting problem. If you dial *70 before making an important call you disable call waiting for that call and any incoming calls will go to voice mail. No good solution if the first call is an incoming call. Searching on call waiting will bring up several posts on the subject.
jrfaris is offline
Old 03-07-2006, 03:09 PM   #14
dbermanmd
dbermanmd:
It never pairs - it is always in search mode.
David
Old 03-07-2006, 04:41 PM   #15
dbermanmd
David
[snapback]221832[/snapback]
I hate to show my ignorance so all but...
I tried calling after going through the setup procedure I cant make a call through it and the MFD lists my telephone as available...
Where am I going wrong
David
Old 03-07-2006, 09:38 PM   #16
dbermanmd
dbermanmd:
It worked
I made a call after doing everything as instructed - and.... IT WORKED
My daughter then happened to call and it picked her right up. No dropped calls at all. In fact she said that I sounded better using the Prius's microphone than I did using my phone :P
Now I just have to figure how to get my address book and speed dial stuff to pair
I do love these smilely faces
And a big thank you to to my buddy who I spoke to tonight. THANKS
David
Connecting to a PC 08NWPrius Prius Technical Discussion 2 10-15-2007 09:23 AM
Static when connecting Treo via aux and using charger simulatenously acousticbiker Audio and Electronics 2 12-16-2006 06:39 PM
difficulty connecting up Treo 650 ?? ramarren Audio and Electronics 6 08-21-2006 06:06 PM
Connecting an IPOD to the AUX adapter tullynoon Prius Main Forum 1 06-01-2006 08:07 AM
Connecting to the 12V battery on the 2005 K6YXH Audio and Electronics 3 01-19-2005 08:10 PM
