| Prius Main Forum This is a discussion on What grade of gas do you pump? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Originally posted by Gen2 @Mar 22 2006, 04:12 PM Although Toyota does state in their documentation that the compression ration ... |
| View Poll Results: What grade of gas do you pump? | |||
| I pump 87 | | 160 | 91.43% |
| I pump 89 | | 10 | 5.71% |
| I pump 93 | | 5 | 2.86% |
| Who cares! | | 0 | 0% |
| Voters: 175. You may not vote on this poll | |||
| | #51 | |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
My Acura MDX was designed for premium fuel, but the ECU can retard the timing to prevent pinging when you put regular in it. I get about 10% better fuel economy on premium (due to the timing advance), so as long as premium is less than 10% more expensive than regular (as it is now), I put premium in it. Most cars that were designed for premium, but which can run on regular behave similarly to this.
__________________ 2009 Toyota Camry Hybrid Black (hers) JBL Audio, Bluetooth, Moonroof, Alloy Wheels, Pink Fuzzy Dice on rearview mirror 2005 Driftwood Pearl Pkg #6 (mine) Katzkin Leather Interior Diamond Audio D661s Component Speakers JL Audio 8W3 Subwoofer JL Audio CleanSweep CL441dsp MTX Thunder 564 Amp 4x100 watts MTX Thunder 421D Amp 1x300 watts OEM Sirius Tuner 2004 Super White Pkg #9 (hers) - sold | |
| | #52 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi Guys! I use 87 only cos it's what the manual sez. Also, I bought the car coz it runs on 87 which is the cheapest. This topic is crazy. We are mostly tight-wads, anyway. Why bother. I will bet if there was 80 at a lower price, and the Prius manual says to use it, y'all will use it!! Trust your Toyota maker!! ![]() |
| | #53 | |
Keep your motor oil changed every three months. That's what keeps the motor clean!! Don't be ripped off!! Andy | |
| | #54 |
| Senior Member Join Date: Apr 2004 Location: Harrisburg, PA
My Car: 2004 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | "Humm.. I believe the prius has a high compression ratio... what is it?... 12:1 or so? Yet I've heard it does not better.... of course the atkinson engine is a whole different animal. " I want to say the Atkinson cycle has a high-expansion ratio, not high compression ratio. I'm actually not sure what that should mean but I'm sure someone here can comment... |
| | #55 | |
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 21 | Quote:
i'm actually from WI, and i've never seen 89 as regular. maybe it's an IL thing? or they've changed things since i've been home? (argh, i've been gone too long) i know kwik trip a few years back decided to price regular and midgrade the same, when i lived in la crosse. maybe that had something to do with it? ah, now i'm just blathering. ![]() i wouldn't worry too much, no need to go to extremes here. it's not like you're dropping 93 in there right? if you do get one of those "engine failed to start" codes after long term use (can be caused by high octane), then i'd consider going a little farther to get 87.
__________________ black 2005 prius, tweaked just the way i like it my diagnostic guy on electronics: "lack of troubleshooting ability is due to a high common sense rejection ratio." | |
| | #56 | |
| nacreous lacquer Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| | #57 |
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | I'm now using 85 octane with no noticable penalty of any kind. I'm half way through my second tank. Woohoo, I can save an extra $1 at the pump. Richard, that's interesting. I read somewhere that Snaab or Volvo was developing an engine to run on E85 that had very high compression ratios to compensate for the lower energy density of E85 vs Gasoline. |
| | #58 | |
| Senior Member Join Date: Sep 2005 Location: Central Texas
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(tripp @ Apr 24 2006, 08:15 PM) [snapback]244669[/snapback]</div> Quote:
Say tripp.. does that have even more ethanol than 87?... if so, are you getting worse mileage and so not really saving a buck? | |
| What grade gasoline do you use | priussoris | Fuel Economy | 43 | 10-05-2007 05:31 PM |
| Alleged Actual Answers to Sixth Grade History tests | larkinmj | Fred's House of Pancakes | 7 | 06-28-2006 09:18 AM |
| Fuel Grade Prices | hycamguy07 | Fred's House of Pancakes | 2 | 03-31-2006 03:05 AM |
| What grade of fuel works best for you? | HAMMER55 | Prius Main Forum | 26 | 11-05-2005 11:29 AM |
| Can the Prius handle the Sunol Grade? | rwithop | CA - San Francisco Bay Area | 6 | 05-17-2005 01:20 AM |
