| Prius Main Forum This is a discussion on '06 backup camera bug within the Prius Main Forum forums, part of the Toyota Prius Forums category; To all '06 HF package owners, Have you noticed the bug in the backup camera. If you change the setting ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | To all '06 HF package owners, Have you noticed the bug in the backup camera. If you change the setting on the display during backing up, the camera will not turn on unless you turn off and restart the car. Even if you try to push shifter to R again. Certainly a bug and not a feature. |
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 9 | Quote:
Does it not return to the camera display if you take it out of R and then put it back into R? And just to satisfy my curiosity... what is it you're doing with the display while backing up? I might be missing out on some good fun here! | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Just innocently backing the car up, and decide to turn on or off the fan of the heater/AC.Tried to re-shift to R, and still no camera. Car needs to be turned off and restarted to restore camera view. Could be annoying to folks in cold climes during the winter. I find the camera useful for a quick view, but generally rely on the rear view and the side mirrors. I trick I have found useful after parking is to shift R and see that the car is pulled far enough forward pat the end of the parking lines. Nice. But I have put 2" bubble mirrors on the left and right side mirrors for the perfect parking job. Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | So if you go to N or D that solves the problem. I will try that. Thanks. Quote:
You could also put in a button. | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | DoH!!! Alright disaster averted.... A case of RTFF. Read the forum first (or Read the ...ing Forum) Quote:
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Same thing happens on the 04s if you have contrived to activate the built in programing. I guess that you should not be fussing around when you are backing up! Going to a Nav window fixes it. |
| Senior Member Join Date: Oct 2005 Location: SF, CA
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Putting it out of reverse and back into reverse should return the camera view. I brought this up in the past: http://priuschat.com/index.php?showtopic=16987&hl= | |
| Always On Backup Camera | walker.627 | Prius Modifications | 9 | 06-19-2008 09:35 AM |
| Backup camera | qbee42 | Prius Technical Discussion | 4 | 06-29-2007 10:34 AM |
| Backup camera | macrobass | Audio and Electronics | 2 | 04-30-2007 12:05 AM |
| Backup Camera | wardog | Prius Main Forum | 7 | 11-25-2005 06:45 PM |
| Backup Camera | bruceha_2000 | Audio and Electronics | 8 | 08-10-2005 04:13 PM |
