| Prius Main Forum This is a discussion on Cracked Windshield within the Prius Main Forum forums, part of the Toyota Prius Forums category; I have a 2004 Prius with a cracked windshield that needs to be replaced. I live in CA. in the ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have a 2004 Prius with a cracked windshield that needs to be replaced. I live in CA. in the So. Bay. I've never had to replace a windshield, so with you help I need to educate myself. I understand after market glass is less expensive than factory glass. Other than price, is there a difference between the two types of glass? Should the moulding be replaced or can the existing moulding be used? It would be convenient to have a mobile unit come to my house for the repair. Is there an advantage to my taking the car to the shop? Is it customary for the repair place to give some type of waranty on their work? I appreciate your suggestions or recommendations. Thanks. |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | It's hard to say with the Prius. I had to replace the windshield on my last car (long after the warranty was gone). The cost was way below the deductable so I paid for it myself. My insurance company recommended a place which did the repair in the parking lot where I worked. They did have a warranty. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(aaf709 @ Apr 3 2006, 03:25 PM) [snapback]234355[/snapback]</div> Quote:
| Senior Member Join Date: Dec 2003
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Yep, first try repair. But if repair isn't possible, call one of the outfits that come to your place. I find they are the cheapest as well as being convenient. One decision you want to make is whether to get a faded tint on the top. I didn't want it but got it anyway on my last car and grew to like it alot for the way it blocks the sun. And don't move the car for 24 hours after the install so the glue can dry well. This is important because if you move it and weaken the glue that might make the car not as strong in an accident. Another good reason to have it done at your place. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | there are 2 "dam's" used on the Prius windshield when it's replaced. An upper and and a outer. Part #56118-63010 and the outer Part #56117-63010 These go behind the glass when it's replace. Just make sure if your using an aftermarket "NAGS" windshield that the glass shop replaces the dams. I'd quote prices but my price list is too old now. |
| | #6 | |||
<div class='quotetop'>QUOTE(tmorrowus @ Apr 4 2006, 04:47 PM) [snapback]234970[/snapback]</div> Quote:
The windshield is beyond repair and needs to be replaced. Thanks for the tip of having a mobile unit replace the windshiled. I'll take your advise. thanks <div class='quotetop'>QUOTE(Frank Hudon @ Apr 4 2006, 07:01 PM) [snapback]235013[/snapback]</div> Quote:
Thank you so very much for the information regarding replacing the two "dams". I assume dams and the moulding are different? When I call for estimates, I'll tell them that I want both dams replaced. I plan on using after market glass as it's less expensive. Other than price I don't know if there's any other difference. You mentioned after market glass "NAGS", is that a type of glass that I should request? Thanks for your help. | |||
| Senior Member Join Date: Jan 2006 Location: Amsterdam, Netherlands
My Car: 2006 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I once had a Toyota Corolla which needed a new windscreen. I also had aftermarket glass been put in instead of an original windscreen an I regretted it! With the original windscreen the image was sharp from edge to edge, and the lines on the road were straight, even in the edges. With the aftermarket glass, the image near the edge of the winscreen was unsharp, and lines on the road were bent. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I just had my windshield replaced in my 06 #8 by All Star Glass in San Diego. A car threw a large bolt into the window on Monday. They took an hour and did a great job. Cost my insurance company $ 395.00 because the guy that did it did not have insurance (he got a ticket from the cops instead). Don't try and do it yourself, it's just too hard. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(scarlet0314 @ Apr 6 2006, 01:15 PM) [snapback]235950[/snapback]</div> Quote:
| Member Friends: 0 | I live in MA and our insurance covers all glass replacement 100%. Also if the weather is cold you want to take the car to the shop otherwise the adhesive might not cure properly and yes they should replace the moulding around the windshield. If your insurance covers it make sure you get Toyota glass |
| Hatchback all its cracked up to be? | sailatinu | Prius Main Forum | 59 | 08-01-2008 12:20 AM |
| iPhone cracked | Presto | Fred's House of Pancakes | 6 | 08-26-2007 12:02 PM |
| Fog Light Cracked | jaeco | Prius Main Forum | 5 | 06-25-2007 04:52 PM |
| HID all it's cracked up to be? | Beacher | Prius Main Forum | 40 | 10-18-2005 10:31 PM |
| Cracked windshield report: replacement in Wisconsin <ouch | MadDebSalsa | Care, Maintenance and Troubleshooting | 11 | 04-08-2005 11:56 AM |
