Prius Main Forum This is a discussion on 25% Improvment in MPG....Thank You! within the Prius Main Forum forums, part of the Toyota Prius Forums category; Have had my Prius for a month, at beginning MFD consistantly in low 40's. After reading (studying?) the tips posted ...
Old 04-27-2006, 10:05 PM   #1
j24816
Have had my Prius for a month, at beginning MFD consistantly in low 40's. After reading (studying?) the tips posted at PriusChat MFD milage is now in low 50's, a 25% improvement. My MFD estimates are spot-on with actuals (99.7% of measured milage).
The big hitters for me:
1) Changed route to work. Previous route was loaded with stop signs, usually backed up 4-5 deep leading to multiple starts from a dead stop. Current route, while not a bargain with 35 red lights and 14 stop signs over 9 grueling miles (~30 minute commute), greatly reduced the number of short stops.
2) I allow significant space between me and car in front, reducing the amount of braking I have to do. Also, generally travel slower.
3) If no-one is behind me, on a downhill stop sign, I let gravity get me going. This seems somewhat extreme to me, but I suspect in this crowd I am safe.
4) I think twice before taking a short trip, and delay the trip if not truely needed.
I would not have suspected a car could have such impact of behavior.
Thank you to all who have shared their knowledge, it is much appreciated....
--John
j24816 is offline
Old 04-27-2006, 10:13 PM   #2
Bill Lumbergh
USAF Aircraft Maintainer
Bill Lumbergh's Avatar
Package: #1
No, no.....thank YOU for practicing good fuel management. As long as your techniques don't obstruct traffic, you're doing everyone a favor.
I've been known to watch my rear view mirror as much as the road in front of me. When I notice no one behind me, I'll coast for up to a quarter mile, gradually losing speed, as I approach a stop sign or red light.
Bill Lumbergh is offline
Old 04-27-2006, 10:44 PM   #3
highroute
highroute's Avatar
<div class='quotetop'>QUOTE(j24816 @ Apr 27 2006, 07:05 PM) [snapback]246415[/snapback]</div>
Wisdom! Ultimately, it's not about miles per gallon; it's about gallons. Maybe delay the trip, maybe combine that trip with another trip ...
highroute is offline
Old 04-27-2006, 10:56 PM   #4
j24816
arggg......I misspelled truly. I hope my daughter does not see this!
j24816 is offline
Old 04-27-2006, 11:16 PM   #5
tripp
tripp's Avatar
Given the craziness of your commute with all of its stops and starts you might consider the EV mode switch (comes in a variety of types with different costs and levels of difficulty to install). It MIGHT help you improve your MPG a little more, plus its loads of fun.
If yer interested just use PC's search feature and you'll find a pile of threads.
tripp is offline
Old 04-28-2006, 12:17 AM   #6
hdrygas
OK I did the same thing... in Spades. I actually researched the topographical change on maps! Yes I am sick. I have now 2 stop signs and 6 stop lights. I can usually cruse through at least 2 or 3 of the stop lights. Gradual up and down hills a great to work and only a few tenths of a mile greater than the usual route that involves 2-3 miles at 50 mph. Makes a big difference.
hdrygas is offline
Old 04-28-2006, 12:49 AM   #7
richard schumacher
ichorous liquor
Note that if your new route is a sufficiently greater distance you may be using more gasoline in total even though the MPG figure is better:
6 miles @ 40 MPG burns 0.16 gallon
9 miles @ 50 MPG burns 0.18 gallon
richard schumacher is offline
Old 04-28-2006, 02:12 AM   #8
ghostofjk
Unrepentant Nattering Nabob of Negativism (V.P. Spiro T. Agnew)
<div class='quotetop'>QUOTE(j24816 @ Apr 27 2006, 07:56 PM) [snapback]246439[/snapback]</div>
NOW you've misspelled "arggh"--there's an "h". :P
Let me be sure I've got this right. You now have 49 lights or stop signs---in 9 miles---an average of 5.5 per mile---and this is an IMPROVEMENT over your old route?
Yumpin' Yiminy.
ghostofjk is offline
Old 04-28-2006, 05:01 AM   #9
hobbit
hobbit's Avatar
When waiting for people ahead of you to pass through a stop sign,
you certainly don't have to punch it hard enough to light the
engine. Just drift up on electric, and wait till you can get a
"good burn" for best efficiency afterward...
_H*
hobbit is offline
Old 04-28-2006, 11:04 AM   #10
daniel
Cat Lovers Against the Bomb
daniel's Avatar
Since moving to Spokane I almost never take the freeway. I get significantly better mpg on the surface roads, and it's almost always shorter. All I need to do is allow a bit more time.
daniel is offline
