Prius Main Forum This is a discussion on POI Navigation Problem within the Prius Main Forum forums, part of the Toyota Prius Forums category; Does anyone know how to cancel the POI icons when you are using the route guidance feature in the navigation ...
Old 05-04-2006, 08:33 PM   #1
Scott_W
Does anyone know how to cancel the POI icons when you are using the route guidance feature in the navigation system? I activated it a while ago while in guidance mode and can not turn it off now. I have no problem deleting POI's when I am not using route guidance. Anytime I am on a freeway or expressway in guidance mode, the screen halves and list all the exits. It is most frustrating. Thanks in advance. (the car is 'O6 and I think has a #8 package )
Scott_W is offline
Old 05-04-2006, 09:33 PM   #2
IsrAmeriPrius
Progressive Member
IsrAmeriPrius's Avatar
<div class='quotetop'>QUOTE(Scott_W @ May 4 2006, 05:33 PM) [snapback]249966[/snapback]</div>
Does anyone know how to cancel the POI icons when you are using the route guidance feature in the navigation system?[/b]
Just tell the car: "POI off." It normally works for me.
IsrAmeriPrius is offline
Old 05-04-2006, 09:34 PM   #3
Friends: 5
<div class='quotetop'>QUOTE(Scott_W @ May 4 2006, 08:33 PM) [snapback]249966[/snapback]</div>
That's the standard mode for highway navigation. It normally shows the next three exits on the right half of the screen. If you want to change the display mode, touch the display format button which is about 2/3rds the way down on the left margin. It pops out to show all of the various screen formats, so you can pick one more to your liking. It's all described in the NAV manual.
qbee42 is online now
Old 05-04-2006, 09:46 PM   #4
Scott_W
<div class='quotetop'>QUOTE(IsrAmeriPrius @ May 4 2006, 09:33 PM) [snapback]249992[/snapback]</div>
"POI off" will not work for me while I am in guidance mode. I just thought that it was showing me exits for the gas stations and food POI icons I could not deactivate. I'll try the other view mode for deleting the exits view anyway.
Scott_W is offline
Old 05-05-2006, 10:22 AM   #5
IsrAmeriPrius
Progressive Member
<div class='quotetop'>QUOTE(Scott_W @ May 4 2006, 06:46 PM) [snapback]250001[/snapback]</div>
Try deactivating the POI feature by the use of the voice command before entering the guidance mode. Also, there is a menu item that allows you to disable the POI while in in the guidance mode. I think it is accessible by touching the Route button, but I am obviously not in the car right now and I am too lazy to go down to the garage to perform some experimentations. If I remember, I'll play with it later and post another message.
Justice, justice you shall pursue. (Deuteronomy 16:20)
Old 05-05-2006, 01:17 PM   #6
Rancid13
Cool Chick with a Black Prius
Rancid13's Avatar
Package: #8
Send a message via AIM to Rancid13 Send a message via Yahoo to Rancid13
Use the voice command feature, and tell it "Remove all icons". That has worked for me many times.
Rancid13 is offline
Old 05-05-2006, 04:41 PM   #7
IsrAmeriPrius
Progressive Member
OK, I have done some experimentation when I drove the car this morning.
Press the Map View button on the NAV screen, the Show POI Icon button on the next one and the POI Off on the screen which follows. That should do it.
navigation system problem please help! statultra Prius Technical Discussion 2 06-27-2007 10:43 PM
Navigation problem fphinney Prius Main Forum 7 09-18-2006 01:54 PM
Navigation Problem Fixed cne0233 Prius Main Forum 0 04-27-2006 08:39 PM
Navigation System Problem? alcor Care, Maintenance and Troubleshooting 5 03-28-2006 08:07 PM
Navigation System Problem? alcor Prius and Hybrid News 0 12-31-1969 07:00 PM
