Prius Main Forum This is a discussion on Clear bra vs. front-end mask for '06 Prius within the Prius Main Forum forums, part of the Toyota Prius Forums category; I had tried (unsuccessfully) to install a factory front-end bra on my '06 Prius. As others have noted in PC, ...
Old 05-25-2006, 05:43 PM   #1
etw934
I had tried (unsuccessfully) to install a factory front-end bra on my '06 Prius. As others have noted in PC, Toyota has modified the '06 Prius by adding a new air dam or spoiler under the front bumper, so that one can no longer attach the hooks to the bottom of the front bumper. The parts counter guy had told me that I had to take off this air dam or spoiler to fasten the hooks and then reattach the air dam. This would in essence clamp the fasteners of the bra between the air dam and the bumper, making it a complete hassle to remove the bra for washing the car or when the bra gets wet in the rain.
I heard about the 3M "clear bra" (ScotchGard Paint Protection film) from PriusChat.com. After checking it out on the 3M website and searching on Google, I had it installed two days ago at Sun Dimmers in Van Nuys, CA. Joe Angel did the installation and did meticulous and very careful work on my car. The price out-the-door" was$400 for coverage of the front bumper, hood, side of the front fenders below headlights, door edging on all 4 doors, both rear view mirrors and top of the rear bumper below the tail gate.
The film is almost invisible on the car. From a distance of 4 to 6 feet, one cannot see it at all. Up close, one can see the edges of the film but this is not at all objectionable. This is on a Super White car, which other posters had said might be more challenging regarding appearance.
I would unequivocally recommend Sun Dimmers to those in the Los Angeles area.
etw934 is offline
Old 05-25-2006, 06:19 PM   #2
ciparis
ciparis's Avatar
Strange... it worked on my '06. I did make sure the part number ended in 050 --- which is specific to the '06. The bottom clips were the trickiest, but they fastened.
My local quote (found via 3M.com as well, before I bought the bra) was $600 for similar coverage. I tried buying it myself (from clearmask.com) and installing it, but that was a disaster (luckily it was "only" $139 for the best film). Then I went and bought the bra, and while it was a pain to put on, it looks good, and I feel much better about it than my crappy attempt at clear film protection.
Incidentally, black is probably the worst thing to try a do-it-yourself film application on, since it shows every flaw and spec of dust so easily. It would have to be absolutely perfect for me to be satisfied.
ciparis is offline
Old 05-25-2006, 09:33 PM   #3
Howard
Howard's Avatar
The bra did not fit my 2006 Prius either. How did you install the lower portion of the bra? Please provide a picture if possible.
Thank you.
<div class='quotetop'>QUOTE(ciparis @ May 25 2006, 03:19 PM) [snapback]261074[/snapback]</div>
Howard is offline
Old 05-26-2006, 02:10 AM   #4
H2OSkier
Joe at Sundimmers did my clear bra too, can't say enough good things about Joe and his work.
Ken
H2OSkier is offline
Old 05-26-2006, 02:20 AM   #5
ghostofjk
Unrepentant Nattering Nabob of Negativism (V.P. Spiro T. Agnew)
That's the best clear bra price I've seen on PC for all the coverage you got. It's so good that if I had access to an installer charging that, I'd ditch my vinyl black bra and do that instead.
ghostofjk is offline
Old 05-26-2006, 12:48 PM   #6
etw934
The part number that I had bought for my '06 Prius also ended in 050 but it just would not fit. Would like to know how you got the bottom clips attached without removing the air dam/spoiler.
etw934 is offline
Old 05-26-2006, 06:03 PM   #7
quadling
Does anyone know of a reputable clear-bra dealer in the New England area?
quadling is offline
Old 06-07-2006, 08:09 AM   #8
quadling
Thumbs up
I looked at a clear bra installed on a BMW and noticed that since the bra on the hood only came up about halfway, there was a small but distinct "wax line" where the plastic ended and the rest of the hood began (the wax was visible on the edge of the plastic.)
I recall that the clear bra pieces I saw discussed on the forum also did not cover the entire hood, so I wonder if this "wax line", on any area covered, is noticed as an issue?
Thanks.
quadling is offline
Old 06-07-2006, 09:17 AM   #9
dbaro
Where exactly did they fasten under the front of the car?
dbaro is offline
Old 06-07-2006, 06:14 PM   #10
mtsarpilot
<div class='quotetop'>QUOTE(H2OSkier @ May 26 2006, 12:10 AM) [snapback]261209[/snapback]</div>
Ken
For those of you that have a Clear Bra put on, how far up the hood did you extend the Clear Bra? Or said differently, how wide of a piece of clear material was used? The local shop here is saying 24", to just above the headlights, is sufficient. Does this match what you all have found to be a good amount of surface coverage?
Thanks,
Joel
mtsarpilot is offline
front end mask linerjia Prius Main Forum 3 07-07-2007 11:07 PM
Help with front mask . . . xbdude Prius Main Forum 6 02-18-2006 07:09 PM
Where can I get clear mask for Prius in San Diego? sunnysandiegan Prius Main Forum 2 02-08-2006 06:37 PM
Front-end mask Leomania Care, Maintenance and Troubleshooting 1 03-10-2005 09:38 PM
Front Mask for the Prius stuffmanca Care, Maintenance and Troubleshooting 12 10-15-2004 02:34 PM
