Prius Main Forum This is a discussion on '06 Battery Replacement within the Prius Main Forum forums, part of the Toyota Prius Forums category; I have been looking around and saw some posts of replacing the aux battery in the 00 - 03's but ...
Old 06-05-2006, 06:13 PM   #1
TheParadox66b
I have been looking around and saw some posts of replacing the aux battery in the 00 - 03's but nothing really after that?
has anyone changed an 06 battery for some higher Ah or CA/CCA? Can you do the miata battery "Mod" with an 06?
What are the dimentions on an 06' aux battery
TheParadox66b is offline
Old 06-05-2006, 07:13 PM   #2
Brian K
Why do you need cold cranking amps in a car that doesn't require cold cranking? A deep cycle battery is more along the lines of what the Prius requires.
Brian K is offline
Old 06-05-2006, 07:28 PM   #3
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
I can can see a use for a larger battery if you wanted to run the radio in the ACC position longer than you could with the original battery.
aaf709 is offline
Old 06-05-2006, 07:59 PM   #4
Brian K
True, but cca wouldn't be what one would be looking for. That's a starter battery and they absolutely don't tolerate being drawn down, at least not if one is expecting a reasonable life from the battery. A higher amperage deep cycle would be the way to go for that.
Anyway, doesn't the charger work to recharge the 12v battery if acc mode is chosen? I don't know, I'm asking. If it does, then it's meaningless.
Brian K is offline
Old 06-05-2006, 10:23 PM   #5
Tideland Prius
Super Moderator
Tideland Prius's Avatar
Friends: 11
No. That's why in ACC mode, the car shuts itself off after 1 hr. I think someone here mentioned that the 12V would last in ACC mode with the radio cranked about 2-3 hours.
Tideland Prius is offline
Old 06-05-2006, 11:38 PM   #6
aaf709
aaf709's Avatar
Yes, there was a discussion about using a Prius to go to a drive-in, where they use FM to send the audio. You could have the radio on (with the MFD off) or you could stay in the "Ready" mode.
aaf709 is offline
Old 06-05-2006, 11:49 PM   #7
galaxee
running WOT until out of fuel
galaxee's Avatar
Nominated 5 Times in 3 Posts
Friends: 20
want a good battery? smack down some bucks for an optima.
galaxee is offline
Old 06-06-2006, 02:11 AM   #8
hobbit
hobbit's Avatar
yeah, but *which* optima, that will fit in the hole and present
the same "pencil posts" to the stock lugs? I was just looking into
this last night but couldn't quite determine which one might be
the closest match...
_H*
hobbit is offline
Old 06-06-2006, 11:23 AM   #9
TheParadox66b
<div class='quotetop'>QUOTE(hobbit @ Jun 6 2006, 02:11 AM) [snapback]266533[/snapback]</div>
_H*
hob -
Please please please let me know which one you get and how close it comes if you replace, or how much you had to mod you car/battery area. thanks
<div class='quotetop'>QUOTE(Brian K @ Jun 5 2006, 07:59 PM) [snapback]266324[/snapback]</div>
brian -
You are absolutely correct, having a higher CCA gives me no advantage... but i do want something higher Ah Rating, which i guess i got my terms mixed up, i just kinda assumed higher cc/cca means higher Amp Hours.
I don't think the 12v aux batt gets recharged in ACC Mode, that would make the aux batt kinda silly, maybe toyota put it there as kinda a backup or something to jump the car on ???
My 2006 Super White Prius
|[ Mod ]| RustStop Rust Inhibitor RS-4 ]|[ Secret Radar Detector ]|
|[ Mod ]| LED interior Lighting
|[ Mod ]| Window Tinting 15% on all
|[ Mod ]| Infinity Kappa Audio - love the difference
|[ Mod ]| B-Quiet Sound Deadening Doors & Floor
|[ In Progress ]| OEM Fogs with HID Bulbs
|[ In Progress ]| CarPC, Processor & flat panel needed!! Any idea on flat panel?
|[ In Progress ]| Sub woofer Install
|[ In Progress ]| JL Cleansweep
Old 06-07-2006, 12:16 AM   #10
galaxee
galaxee's Avatar
Friends: 20
optima does make 12v batteries- they were designed for hondas originally. they are group 51 and group 51R- don't recall which is the correct one. the only difference is that the + and - terminals are reversed on one of them.
the battery is small enough to fit into the area. it may be taller- and if that's the case the existing setup may not hold it. then you'd have to change the holddown bracket bar and maybe extend the post that it screws down to.
galaxee is offline
12v Battery replacement? Bob Allen Prius Technical Discussion 7 11-18-2007 07:53 AM
Battery replacement greenjack Prius Main Forum 2 07-09-2007 11:54 AM
12V Battery replacement DLangdon Care, Maintenance and Troubleshooting 2 01-03-2007 10:39 AM
Is a replacement 12V battery necessary? magneto99 Care, Maintenance and Troubleshooting 4 12-12-2006 11:08 AM
Battery Replacement insolarman Prius Modifications 17 04-12-2005 12:50 AM
